Sign in to follow this
Polish.Gasoline
Voltage regulator
I have a light sixer and it won't turn on. The voltage regulator got fried. I'm just curious how to fix this on the pcb. It got burnt after I used a crappy soldering iron trying to attach an led. Yes, if there is any way to remedy this let me know.
The screen flashes as soon as I put power to the wall after that nothing.
It's been a learning experience folks.
7805 +5V VOLTAGE REGULATOR 3-PIN TO-220 MC7805ACTG 5V? Does it make a difference which 7805 I use?
Also what would be a good guide for making my own composite mod? I wouldn't mind making one similar to best electronics.
Edited by Polish.Gasoline
As long as the regulator is a 7805 in a TO220 package and not the lower current 78L05 in a TO92 package you should be ok (although I always found the voltage regulation on those made by ST to be poor)
Either of the two 7805's listed at the top of the web page will do.
Personally, I would go for the MC7805ACTG, although it has the lowest current capabilities of the three (still twice what you need) that means it also has the best regulation and ripple rejection for a smoother supply voltage.
