RSS Bot Posted May 15, 2019 Share Posted May 15, 2019 I rewrote my wall checks for t-states and removed the IY and IX registers which should also improve speed. I also added an extra check so now walking through walls has been fixed in 4 directions. As soon as I implement the 4 diagonal directions I will post another update for you to test. Plenty of advice, some from Nanochess....thank you... I incorporated some of his input with what I already coded because I have to use IN A, (DATA_PORT) In order to use different pattern sets for the Super Game and different types of barriers. The Bridge is still a problem but I think I have a solution that may work. If not then it will just be a skinny bridge. I think I will be forgiven as long as it works. http://atariage.com/forums/blog/763/entry-15869-been-a-few-days-since-updates/ Link to comment Share on other sites More sharing options...
