Sign in to follow this
TGB1718
Ultimate 1M Upgrade Question
Now that I have one installed and working, I'm trying to find out how to access the extra memory banks, I assume it still
uses bank switching through $4000-$7fff as in the 130XE, but obviously there are not enough bits available in the PIA chips
to access 1Mb.
Does anyone have a link to the technical documantation for this upgrade, I've Googled, searched this forum etc. but all I can
find is installation instructions and a fine document 'Firmware Manual' which although extensive doesn't give this information.
Any help would be much appreciated.
Look in the U1MB section:
http://www.virtualdub.org/downloads/Altirra%20Hardware%20Reference%20Manual.pdf
All extended memory models and PORTB bit usage are described.
NOTE: Ultimate 1MB simply implements three common extended memory schemes, using identical bank selection techniques.
Edited by flashjazzcat
Many thanks, I already had that manual but didn't realise it had that information in it, looks like I should read it next time  :grin:
