Omega-TI #1 Posted May 20, 2019 I cannot believe I never tried it before, probably because I never needed to before now, but if you have your TIPI on a networked drive, it'll work just fine with TI99Dir. Quote Share this post Link to post Share on other sites
FDOS #2 Posted May 20, 2019 I cannot believe I never tried it before, probably because I never needed to before now, but if you have your TIPI on a networked drive, it'll work just fine with TI99Dir. How do you do that? Isn't it installed in a TI PEB or connected to a specific 32K sidecar? Bill 1 Quote Share this post Link to post Share on other sites
+wolhess #3 Posted May 20, 2019 I cannot believe I never tried it before, probably because I never needed to before now, but if you have your TIPI on a networked drive, it'll work just fine with TI99Dir. Yes, Ti99Dir is a great support in programming on a real TI. I see all the directories on my TI system here and test on a second TIPI system. I use the tool to copy files between my TIPI systems and create a backup on the PC. The best, however, is a great overview if I show a listing in Ti99Dir. This helps to edit and troubleshoot the program. 3 Quote Share this post Link to post Share on other sites
Omega-TI #4 Posted May 20, 2019 How do you do that? Isn't it installed in a TI PEB or connected to a specific 32K sidecar? Bill Yes, but the TIPI has built in WiFi so... 1 Quote Share this post Link to post Share on other sites
+arcadeshopper #5 Posted May 20, 2019 How do you do that? Isn't it installed in a TI PEB or connected to a specific 32K sidecar? Bill TIPI automatically creates a samba (windows) file share called.. TIPI ..so you go to windows (or whatever os) click map network drives and go to \\tipi\TIPI\ and map it to a drive.. then access that drive from tidir Greg 2 Quote Share this post Link to post Share on other sites
