zbyti Posted June 27, 2020 Share Posted June 27, 2020 (edited) begin repeat until false; end. Mad Pascal Compiler version 1.6.4 [2020/06/25] for 6502 Compiling hello.pas 6 lines compiled, 0.64 sec, 4875 tokens, 387 idents, 155 blocks, 5 types ZPAGE: $0080..$00D7 RTLIB: $2000..$1FFF SYSTEM: $2030..$2033 CODE: $2000..$204A DATA: $204B..$2056 m 80 0080: 00 00 56 20 00 00 00 00 00 00 00 9E 93 00 00 00 ♥♥V ♥♥♥♥♥♥♥←╋♥♥♥ 0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 ♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥◆ 00A0: 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ♥◆♥♥♥♥♥♥♥♥♥♥♥♥♥♥ 00B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥ 00C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥ 00D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥ 00E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥ 00F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥♥ ; ------------------------------------------------------------ org $80 fxptr .ds 2 ; VBXE pointer psptr .ds 2 ; PROGRAMSTACK Pointer eax .ds 4 ;8 bytes (aex + edx) -> divREAL edx .ds 4 ecx .ds 4 bp .ds 2 bp2 .ds 2 TMP ztmp ztmp8 .ds 1 ztmp9 .ds 1 ztmp10 .ds 1 ztmp11 .ds 1 STACKORIGIN .ds STACKWIDTH*4 zpend ; ------------------------------------------------------------ ax = eax al = eax ah = eax+1 cx = ecx cl = ecx ch = ecx+1 dx = edx dl = edx dh = edx+1 org eax FP1MAN0 .ds 1 FP1MAN1 .ds 1 FP1MAN2 .ds 1 FP1MAN3 .ds 1 org ztmp8 FP1SGN .ds 1 FP1EXP .ds 1 org edx FP2MAN0 .ds 1 FP2MAN1 .ds 1 FP2MAN2 .ds 1 FP2MAN3 .ds 1 org ztmp10 FP2SGN .ds 1 FP2EXP .ds 1 org ecx FPMAN0 .ds 1 FPMAN1 .ds 1 FPMAN2 .ds 1 FPMAN3 .ds 1 org bp2 FPSGN .ds 1 FPEXP .ds 1 .ifdef MAIN.@DEFINES.S_VBXE opt h- ins 'atari\s_vbxe\sdxld2.obx' opt h+ .endif ; ------------------------------------------------------------ Exactly as @tebe said: ZPAGE: $0080..$00D7 unfortunately it does't look like dynamically allocated memory. Edited June 27, 2020 by zbyti 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 28, 2020 Share Posted June 28, 2020 (edited) According to @tebe the best we can get so far is: mp with -zpage:A9 but this also is collide with well known free $CA..$CF. We have to transfer the addresses from $Ax and $CA ..$CF below during translations. Edited June 28, 2020 by zbyti 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted June 29, 2020 Author Share Posted June 29, 2020 (edited) Ok, I understand. There will have to be some way to transfer these addresses during translation to properly compile Action! code. I can now understand why code I tested (FUNCtion returning result in $A0) didn't work. Ow, can you please enlighten me what is the purpose of memory addresses $CA..$CF in Action!? Edited June 29, 2020 by Gury Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 (edited) @Gury I think moving $Ax should be optional as a flag, because the problem will only occur if the code will be a Action! source with parameterized =*. Action! RUNTIME in Effectus don't use $Ax at all, only some custom PROC/FUNC may will. Effectus itself is not burdened with such problem and We can write programs in accordance to the new standards. $CA..$CE according to some materials is the only free space on the zero page above the $80 available to the programmer (when the Action! environment exists in memory), I used this cells. Edited June 29, 2020 by zbyti $CA..$CE info 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted June 29, 2020 Author Share Posted June 29, 2020 In this case it should be better to move $Ax automatically when parameterized =* FUNC/PROC is used. For other cases it should be optional; that is, writing Effectus code according to new standards using $Ex and beyond, or moving all $Ax to new address by option directive (if code includes $Ax addresses). For $CA..$CE ($CF?) it should be all automatic translation to new addresses. What do you think? Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 (edited) I think this issue should be last on Your list for now If high compatibility is Your main goal then yes, translation should change the $Ax automatically. $CA..$CE is marginal and programmer shold change such accurance manually, proper info about ZPAGE: $0080..$00D7 should be in Effectus readme.txt. Personally I'm going to use Effectus like Mad Pascal instead of Action! way, I just simply like the Action! syntax only Edited June 29, 2020 by zbyti what I like ;) Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted June 29, 2020 Share Posted June 29, 2020 yeah ok, no clue what that says, only able to make out a couple of those labels by similarity to other spoken/written language. Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 @_The Doctor__ Action! environment memory map. $CA..$CE is free. Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 (edited) Quote "such accurance" appearance Edited June 29, 2020 by zbyti typo 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 @_The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted June 30, 2020 Author Share Posted June 30, 2020 Zbyti, Action! man 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 1, 2020 Share Posted July 1, 2020 New binary for Linux with some bugfix and changed "translation only" flag from -nc to -t https://github.com/Gury8/effectus/pull/11 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted July 1, 2020 Author Share Posted July 1, 2020 Great work, zbyti! I checked the changes and it looks good. I tested new compiled version with example test-suit and all listings compiled with no error. 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted July 9, 2020 Author Share Posted July 9, 2020 New version 0.5.1 (link) New features INCLUDE directive supported: files can be included, starting in the same directory as main compiled listing code currently one level of included files is supported. This means only main listing program can read other files with the use of INCLUDE directive (this directive will be ignored in included files) file is ignored if it isn't found Example: INCLUDE "D1:LIBRARY.EFF" INCLUDE "H1:lib_test.eff" INCLUDE "TEST01.EFF" Shell parameter -nc flag changed to -t (Effectus only translate source to Mad Pascal) - changed by Zbyti IF condition operators AND and OR supported (every condition must be surrounded by () pair for the program to be compiled properly) Example: IF (SIZEP(3) = 1) AND (P0 = P0HPOS) AND (A = 2) THEN IF (T1 = 1) OR (T2 = 3) OR (isFlag = 0) THEN Bug fixes Proper parsing of FUNCtions inside IF condition block Proper handling of zero-page addresses from $A0 to $AF as parameters for machine language routines inside PROCedures and FUNCtions Code refactoring and bug fixes by Zbyti: doubled operator fix with all operands SHL -> LSH bug correction LSH -> SHR bug correction 4 Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 9, 2020 Share Posted July 9, 2020 Benchmark: YoshBenchPlus program YoshBenchPlus; uses crt; {$define FAST} {$ifdef FAST} var i : word absolute $e0; var a : word absolute $e2; var b : word absolute $e4; {$else} var i : word; var a : word; var b : word; {$endif} var rtClock : byte absolute 20; begin i:=0;a:=0;b:=0; Pause; rtClock := 0; while rtClock < 100 do begin Inc(a); b := a; Inc(b); a := b; Inc(i); end; WriteLn('YoshPlus - iterations in 100 frames.'); {$ifdef FAST} Writeln('Mad Pascal 1.6.4 opt'); {$else} Writeln('Mad Pascal 1.6.4'); {$endif} Writeln('Counter = ', i); ReadKey; end. SET $E=$2000 BYTE RTCLOK=$14 CARD I=$CA,A=$CC,B=$CE PROC WAIT=*(BYTE F)[$18$65$14$C5$14$D0$FC$60] PROC MAIN() I=0 A=0 B=0 WAIT(1) RTCLOK=0 WHILE RTCLOK<100 DO A==+1 B=A B==+1 A=B I==+1 OD PRINTC(I) RETURN DO A==+1 B=A B==+1 A=B I==+1 UNTIL RTCLOK=100 OD DO A==+1 B=A B==+1 A=B I==+1 IF RTCLOK=100 THEN EXIT FI OD Mad Pascal 1.6.4 Zero Page: 41933 WHILE Action! 3.6 Zero Page: 39802 WHILE Action! 3.6 Zero Page: 40488 UNTIL Action! 3.6 Zero Page: 38498 EXIT Effectus 0.5.1 Zero Page: 41933 WHILE Effectus 0.5.1 Zero Page: 41933 UNTIL Effectus 0.5.1 Zero Page: 39803 EXIT 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 9, 2020 Share Posted July 9, 2020 (edited) SET $E=$2000 BYTE RTCLOK=$14 CARD I=$CA,A=$CC,B=$CE PROC WAIT=*(BYTE F)[$18$65$14$C5$14$D0$FC$60] PROC MAIN() I=0 A=0 B=0 WAIT(1) RTCLOK=0 A==+1 B=A B==+1 A=B I==+1 [$A9$64$C5$14$D0$D8] PRINTC(I) RETURN 2000: 18 CLC 2001: 65 14 ADC $14 ;RTCLOK+2 2003: C5 14 CMP $14 ;RTCLOK+2 2005: D0 FC BNE $2003 2007: 60 RTS 2008: 4C 0B 20 JMP $200B 200B: A0 00 LDY #$00 200D: 84 CB STY $CB 200F: 84 CA STY $CA ;LOADFLG 2011: 84 CD STY $CD 2013: 84 CC STY $CC 2015: 84 CF STY $CF 2017: 84 CE STY $CE 2019: A9 01 LDA #$01 201B: 20 00 20 JSR $2000 201E: A0 00 LDY #$00 2020: 84 14 STY $14 ;RTCLOK+2 2022: E6 CC INC $CC 2024: D0 02 BNE $2028 2026: E6 CD INC $CD 2028: A5 CD LDA $CD 202A: 85 CF STA $CF 202C: A5 CC LDA $CC 202E: 85 CE STA $CE 2030: E6 CE INC $CE 2032: D0 02 BNE $2036 2034: E6 CF INC $CF 2036: A5 CF LDA $CF 2038: 85 CD STA $CD 203A: A5 CE LDA $CE 203C: 85 CC STA $CC 203E: E6 CA INC $CA ;LOADFLG 2040: D0 02 BNE $2044 2042: E6 CB INC $CB 2044: A9 64 LDA #$64 2046: C5 14 CMP $14 ;RTCLOK+2 2048: D0 D8 BNE $2022 204A: A6 CB LDX $CB 204C: A5 CA LDA $CA ;LOADFLG 204E: 20 E6 A4 JSR $A4E6 2051: 60 RTS Action! 3.6 Zero Page: 39802 WHILE Action! 3.6 Zero Page: 40488 UNTIL Action! 3.6 Zero Page: 38498 EXIT Action! 3.6 Zero Page: 41932 ML Edited July 9, 2020 by zbyti ML 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted July 9, 2020 Author Share Posted July 9, 2020 Great stuff, zbyti. So, to my understanding these tests show that, Mad Pascal and consequently Effectus are very fast Action! with ML is nearly as fast. Btw, on my site, your Linux compilation is ready for downloading. 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 9, 2020 Share Posted July 9, 2020 (edited) For the record it was 100 frames loop which gives 2 seconds in PAL Edited July 10, 2020 by zbyti 2 seconds in PAL 1 Quote Link to comment Share on other sites More sharing options...
mariusz-buk Posted July 10, 2020 Share Posted July 10, 2020 "Include" directive tested successfully on Mac. New 0.5.1 Mac version released. 2 Quote Link to comment Share on other sites More sharing options...
Gury Posted July 10, 2020 Author Share Posted July 10, 2020 (edited) Great! Mac version is more than welcome. Edited July 10, 2020 by Gury Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 10, 2020 Share Posted July 10, 2020 (edited) // Eratosthenes Sieve 1028 Benchmark uses crt; {$define FAST} const size = 8191; var flags: array [0..size] of boolean; rtClock: byte absolute $14; {$ifdef FAST} n: byte absolute $e0; k: word absolute $e2; count: word absolute $e6; {$else} n, k, count: word; {$endif} begin writeln('Mad Pascal 1.6.4 MASTER'); writeln('Eratosthenes 1028 Sieve Benchmark'); Pause; rtClock := 0; fillchar(flags, sizeof(flags), true); for n := 2 to 91 do begin if flags[n] then begin k := n shl 1; while k <= size do begin flags[k] := false; Inc(k,n); end; end; end; writeln(rtClock, ' frames'); count :=0; for k := 2 to size do begin if flags[k] then Inc(count); end; writeln(count, ' primes'); repeat until keypressed; end. SET $E=$2000 BYTE ARRAY FLAGS(8192) BYTE RTCLOCK=$14,N=$CE CARD COUNT=$CA,K=$CC PROC WAIT=*(BYTE F)[$18$65$14$C5$14$D0$FC$60] PROC MAIN=*() COUNT=0 K=0 WAIT(1) RTCLOCK=0 SETBLOCK(FLAGS,8192,'T) FOR N=2 TO 91 DO IF FLAGS(N)='T THEN K=N LSH 1 WHILE K<=8191 DO FLAGS(K)='F K==+N OD FI OD PRINTB(RTCLOCK) FOR K=2 TO 8191 DO IF FLAGS(K)='T THEN COUNT==+1 FI OD PRINTF("%E%U PRIMES%E",COUNT) RETURN Sieve 1028 Benchmark (less is better) Mad Pascal 1.6.4 36 frames Effectus 0.5.1 36 frames Action! 3.6 45 frames Edited July 10, 2020 by zbyti another benchmark 2 Quote Link to comment Share on other sites More sharing options...
Gury Posted July 10, 2020 Author Share Posted July 10, 2020 Most likely there will be additional examples folder consisting of benchmark tests, really interesting stuff. Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 10, 2020 Share Posted July 10, 2020 More detail sieve1028.pas SIEV1028.ACT 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 10, 2020 Share Posted July 10, 2020 (edited) OFF-TOPIC We have to be careful with using RUNTIME from the internet, some are real crap, e.g. the one I've used so far: PROC SetBlock=*(CARD a, l BYTE v) [$85$A0$86$A1$84$A2$A0$00$A5$A2$D0$04 $A5$A3$F0$16$A5$A4$91$A0$C8$D0$02$E6 $A1$C6$A2$A5$A2$C9$FF$D0$E7$C6$A3$38 $B0$E2$60] 11 frames in SIEVE 1028 benchmark Vs. originally 3 frames (Action! 3.6 cartridge). Still is a room to improve since Mad Pascal ended fill in 2 frames. RUNTIME.ACT Edited July 10, 2020 by zbyti OT 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 13, 2020 Share Posted July 13, 2020 (edited) On 7/10/2020 at 1:27 AM, Gury said: So, to my understanding these tests show that, Mad Pascal and consequently Effectus are very fast Action! with ML is nearly as fast. org $2000 .var i,a,b .word = $80 mwa #0 a \ mwa #0 b \ mwa #0 i wait loop inw a \ mwa a b inw b \ mwa b a inw i lda $14 \ cmp #100 bne loop jsr printf .by '% iterations',$9b,0 dta a(i) jmp * .proc wait lda:cmp:req $14 mwa #0 $13 rts .endp .link 'printf.obx' > m 80 0080: CD A3 9A 47 9A 47 00 00 00 00 00 9E 93 00 00 00 Edited July 13, 2020 by zbyti formatting 1 Quote Link to comment Share on other sites More sharing options...
