10 Line XB entries: 10Liner 49er AND Gladiator
FarmerPotato
Joystick required.
Dig down.
Find the gold squares.
version 1
10 DIM A$(24)::W$="   a              aa aaa a a ahhhhxhxhxxxhhhhhxxhxhhxxxxhhxxxphpxpphhhxxxppxxxhppppxxppppx"::_=1::@=24
20 CALL CLEAR::CALL SCREEN(:: CALL COLOR(9,13,_)::CALL COLOR(10,7,_)::CALL COLOR(11,12,_)::CALL COLOR(12,15,_)::CALL COLOR(13,6,6)
30 F$="FFFFFFFFFFFFFFFF"::CALL CHAR(96,"18183C5A5A182858"&F$)::CALL CHAR(104,"55AA55AA55AA55AA")::CALL CHAR(112,F$)::CALL CHAR(120,F$)
40 FOR I=_ TO @::FOR J=_ TO 14::A$(I)=A$(I)&SEG$(W$,INT(RND*16+I*3),2)::NEXT J::PRINT A$(I)
50 NEXT I::FOR I=_ TO 5::DISPLAY AT(I,_):A$(I)::NEXT I::FOR I=6 TO @::CALL HCHAR(I,3,128,28)::NEXT I
60 C=16::R=4::CALL SPRITE(#1,96,14,R*8-7,C*8+9)
70 CALL JOYST(_,X,Y)::C1=C+X/4::R1=R-Y/4:: IF X<>0 AND C1>_ AND C1<28 THEN C=C1 ELSE IF R1>3 AND R1<@ THEN R=R1
80 IF SEG$(A$(R),C,_)="p" THEN G=G+_::DISPLAY AT(_,_) SIZE(3):G :: CALL SOUND(100,262,0,327,2,409,4) :: CALL SOUND(100,262,2,330,4,415,6)
90 IF R>4 THEN A$(R)=SEG$(A$(R),_,C-_)&CHR$(128)&SEG$(A$(R),C+_,28-C)
100 CALL LOCATE(#1,R*8-7,C*8+9)::FOR I=R-_ TO R+_::DISPLAY AT(I,C-_) SIZE(3):SEG$(A$(I),C-_,3)::NEXT I::GOTO 70
version 2. Graphic chars! Two color sprite! Rocks are unbreakable!
10 DIM A$(24)::W$= "    a  aa aahaahhahhhhhhhhhhhhhxhhxxxhhxhhxhpxxhxppxppxhhxhpxhhxxxxpp"&RPT$("x",16)::_=1::@=24::C=16::R=4
20 CALL CLEAR::CALL SCREEN(:: CALL COLOR(9,13,_,10,7,15,11,12,16,12,15,2,13,6,2)::F$=RPT$("F",16)::RANDOMIZE
30 CALL CHAR(96,"000C020509100000F00FF00FF00F1818606000FC606090D8",104,"33CC33CC33CC33CC",112,"FFDF8FDFFFFFFFFF",120,"74FAFA7A2AA98522",128,F$)::FOR I=_ TO @
40 K=I*3-2::E$=SEG$(W$,K,_)::A$(I)=E$::FOR J=_ TO 13::A$(I)=A$(I)&SEG$(W$,INT(RND*16+K),2)::NEXT J::A$(I)=A$(I)&E$::PRINT A$(I)
50 NEXT I::DISPLAY AT(_,_) SIZE(12):"10LINER 49ER"::FOR I=6 TO @::CALL HCHAR(I,3,129,28)::NEXT I::CALL SPRITE(#1,96,2,25,137,#2,98,16,25,137)
60 CALL JOYST(_,X,Y)::C1=C+X/4::R1=R-Y/4
70 IF X<>0 AND C1>_ AND C1<28 AND SEG$(A$(R),C1,1)<>"x" THEN C=C1 ELSE IF Y<>0 AND R1>3 AND R1<@ AND SEG$(A$(R1),C,1)<>"x" THEN R=R1
80 G$=SEG$(A$(R),C,1)::IF R>4 THEN A$(R)=SEG$(A$(R),_,C-_)&CHR$(128)&SEG$(A$(R),C+_,28-C)
90 CALL LOCATE(#1,R*8-7,C*8+9,#2,R*8-7,C*8+9)::FOR I=R-_ TO R+_::DISPLAY AT(I,C-_) SIZE(3):SEG$(A$(I),C-_,3)::NEXT I::IF G$<>"p" THEN 60
100 G=G+_::DISPLAY AT(_,25) SIZE(4):G :: FOR I=2 TO 14 STEP 2::CALL SOUND(-200,262,I,330,I*2,415,16)::NEXT I::GOTO 60
version 3. Press fire to dynamite! You get 5.
10 DIM A$(24):: W$= "    aa aa aahaahhahhhhhhhhhhhhhxhhxxxhhxhhxhpxxhxppxppxhhxhpxhhxxxxpp" &RPT$("x",16) ::_=1::@=24::C=16::R=4:$=CHR$(128)::M=999
40 K=I*3-2::E$=SEG$(W$,K,_)::A$(I)=E$::FOR J=_ TO 13::A$(I)=A$(I)&SEG$(W$,INT(RND*16+K),2)::NEXT J::A$(I)=A$(I)&E$::DISPLAY AT(I,1):A$(I)
60 CALL JOYST(_,X,Y)::C1=C+X/4::R1=R-Y/4::CALL KEY(_,K,S)::IF K=18 AND D<5 THEN CALL SOUND(M,-6,0)::A$(R1)=SEG$(A$(R1),_,C1-_)&D$&SEG$(A$(R1),C1+_,28-C1):=D+1::GOTO 90
80 G$=SEG$(A$(R),C,1)::IF R>4 THEN A$(R)=SEG$(A$(R),_,C-_)&D$&SEG$(A$(R),C+_,28-C)
  • Like 4
incredible 10 lines program, second version is much better!
but i am blocked, can't be continued and I can't go on the left border :P
I decided it should be hard to get all the gold. Like 'Klondike Solitaire'.
No you can't go on the edge columns 1 or 28. I put borders of rocks from row 13 down to indicate that. I made sure there was no gold in columns 1 or 28. Just for you Ciro! (But it made the game difficulty harder!)
How the maze generation difficulty happens:
In the string W$, there are 23 groups of 3 characters plus 16 'x', Corresponding to 24 lines of the screen.
You can see the structure better with commas between every third char:
W$
   , a , aa, aa,haa,hha,hhh,hhh,hhh,hhh,hxh,hxx,xhh,xhh,xhp,xxh,xpp,xpp,xhh,xhp,xhh,xxx,xpp,xxxxxxxxxxxxxxxx
 row:2   3   4   5   6   7   8   9  10  11  12  13  14  15  16  17  18  19  20  21  22  23  24
Space is blank, a is tree, h is dirt, x is rock, p is gold.
The first char of each group (position K) is the edge border for that row. See E$ . So line 1 has a space, line 5 has dirt, line 13 has a rock.
30 K=I*3-2::E$=SEG$(W$,K,1)
The other chars are chosen two at a time from the group of 16 starting at K:
If you want to make the game easier, change the double 'xx' (rocks) to 'hx' or 'hh'. Especially that 'hxx' at row 12 can create a lot of difficulty for you!
Just for you, in version 3, I found a way to add Dynamite in line 60. It was tough, I kept getting LINE TOO LONG, but there it is. Dynamite away!
Thank you for all the feedback. I am done now!
Inspired by 'Gladiator' (arcade) and 'Swashbuckler' (Apple II) and Video Brain Gladiator (oh god), here is Gladiator:
Instructions: Use joystick to move left or right, and raise shield up or down. Press fire, along with up or down, to ready your sword ; release fire to make an attack. If you get past your opponent's defenses, you defeat them. If your opponent's trident blocks your sword, or your shield blocks their trident, you both live another round. Otherwise you will die, nameless Gladiator.
Gladiator
It's kind of rough in the combat resolution. I'm putting it aside for a bit.
10 CALL CLEAR::CALL SCREEN(::CALL MAGNIFY(2)::S=2::T=1::R=80::C=128::Q=160::E=2
20 CALL CHAR(113,"003030300000000000000030303000000000000000303030",116,"2556360A06060A0A090F661F66060A0A00090606076E1665")
30 CALL CHAR( 97,"606848706070506860604078606050D86060406070686070",100,"1819121C101814641818101E1030484C30302030303E186C")
40 CALL CHAR( 105,"102040000000000000000000007000000000000000000070", 108,"020408000000000000000000000E0000000000000000000E")
50 CALL SPRITE(#1,104+S,12,R-4,C+6,#2,112+T,7,R-1,C-1,#3,96+S,2,R,C,#4,115+E,16,R,Q)
60 L=K::CALL JOYST(1,X,Y)::CALL KEY(1,K,Z)::Y=2-Y/4::IF K=18 THEN S=Y ELSE IF L=18 THEN F=4::S=Y+3 ELSE T=Y::IF X THEN C=C+X ELSE IF S>3 THEN S=S-3::F=0
70 E=INT(RND*3+1):: Q=Q-1::CALL PATTERN(#1,104+S,#2,112+T,#3,96+S,#4,115+E)::CALL LOCATE(#1,R-4,C+6,#2,R-1,C-1,#3,R,C,#4,R,Q)
80 IF C+8+F<Q THEN 60 ELSE IF F AND S<>E+3 THEN 100 ELSE IF T=E OR S-3=E THEN C=C-8::Q=Q+8::GOTO 70
90 CALL COLOR(#4,9)::FOR I=1 TO 7::CALL SOUND(-100,999,2)::CALL SOUND(-100,880,::NEXT I::C=C-8::Q=Q+16::GOTO 50
100 CALL COLOR(#3,9)::FOR I=1 TO 7::CALL SOUND(-100,999-I*100,2)::NEXT I::C=C-16::Q=Q+8::GOTO 50
