StupidEggplantThatNeverPosts Posted June 12, 2019 Share Posted June 12, 2019 I'm trying to make a home console port of Space Race using visual batari basic. (Its my first time coding a game). I'm coding my game. Everything is going fine, but when I compile and then attempt to test the game with Stella, an error message appears in Stella. Fatal Error Invalid Instruction. So I tried it with Z26. But when I compile and open the game, instead of opening the game, it opens to a black screen with the word jammed at the bottom. Please help me. I looked everywhere but I haven't found a way to fix this. Quote Link to comment Share on other sites More sharing options...
KevKelley Posted June 12, 2019 Share Posted June 12, 2019 You might have to post the code for specific solutions. 1 Quote Link to comment Share on other sites More sharing options...
StupidEggplantThatNeverPosts Posted June 13, 2019 Author Share Posted June 13, 2019 You might have to post the code for specific solutions. I’m pretty sure it’s not the code thats the issue. It’s likely either the emulator or the bin file. I had no issues compiling it. Quote Link to comment Share on other sites More sharing options...
willymanilly Posted June 13, 2019 Share Posted June 13, 2019 (edited) I doubt it's the emulator. Sounds like the compiled code is hitting one of the 6502 JAM instructions which effectively kills the cpu from fetching new instructions. http://forum.6502.org/viewtopic.php?f=1&t=1409&view=previous The only way to restore the cpu to a valid state once it's jammed on real hardware is sending a reset signal to the cpu. The error message you are seeing is alerting you to the fact the cpu has attempted to execute one of the JAM instructions and is now in an unresponsive state. VICE actually has test programs to ensure once a JAM instruction is executed the cpu indeed remains frozen. These test programs show that jam instructions can be compiled with no issues. https://sourceforge.net/p/vice-emu/code/HEAD/tree/testprogs/CPU/cpujam/ Edited June 13, 2019 by willymanilly 1 Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 13, 2019 Share Posted June 13, 2019 If you don’t want to post the code, you could always PM it to me and I could take a look and see if I notice anything that might be causing the problem. If I find something, I’ll add the error and the fix to the bB page. 2 Quote Link to comment Share on other sites More sharing options...
StupidEggplantThatNeverPosts Posted June 30, 2019 Author Share Posted June 30, 2019 On 6/12/2019 at 11:16 PM, willymanilly said: I doubt it's the emulator. Sounds like the compiled code is hitting one of the 6502 JAM instructions which effectively kills the cpu from fetching new instructions. http://forum.6502.org/viewtopic.php?f=1&t=1409&view=previous The only way to restore the cpu to a valid state once it's jammed on real hardware is sending a reset signal to the cpu. The error message you are seeing is alerting you to the fact the cpu has attempted to execute one of the JAM instructions and is now in an unresponsive state. VICE actually has test programs to ensure once a JAM instruction is executed the cpu indeed remains frozen. These test programs show that jam instructions can be compiled with no issues. https://sourceforge.net/p/vice-emu/code/HEAD/tree/testprogs/CPU/cpujam/ And how do I fix the issue with these programs? Quote Link to comment Share on other sites More sharing options...
