Sign in to follow this
Karl G
Dumb DASM Question
How can I get rid of warnings about undefined symbols that are used for conditional assembly. For example, I have the following in my code:
 ifconst RANDOM_PLAY
    jsr SubGetRand
 else
    lda SWCHA
 endif
I'll either define the RANDOM_PLAY symbol or leave it commented before that depending on the behavior I want. This works fine, but the assembler gives warnings about missing symbols. is there any way to suppress these warnings, or a better way to accomplish the above that doesn't generate the warnings?
Personally, I'd do something like
MODE_Random_Play = 1
MODE_Not_Random = 2
.if GAME_MODE = MODE_Random_Play
   jsr SubGetRand
.else
   lda SWCHA
.endif
disclaimer: I don't use dasm, so YMMV
I use this and don't get any warnings:
    IFCONST AFP_TARGET
        IF AFP_TARGET != 1
            lda #%00000010
            sta VBLANK
        ENDIF
    ENDIF
Then tried adding a new reference I know doesn't exist:
    IFCONST TEST_0987654321
        ECHO "defined"
    ENDIF
Still no warnings. Are you sure it's not caused by something else?
Dasm version: DASM 2.20.11 20171206
Edited by azure
The symbol list only normally shows up on a successful assemble when using the -v3 or -v4 switches. If that's the issue, just use a lower verbosity.
Or maybe you mean that all of these non-problem symbols show up in the unresolved list when there's a problematic unresolved symbol that prevents assembling?
In that case, you could define all of the constant options early on in your code, and just test their values instead. That way they're defined either way.
RANDOM_PLAY = 0
  ;bunch of code
  if RANDOM_PLAY == 1
    jsr SubGetRand
 else
    lda SWCHA
 endif
Good solutions, both. I probably don't need the verbosity that high most of the time, and I didn't think about testing for the value of the constant instead of its existence. Thanks!
