Tempest Posted June 16, 2019 Share Posted June 16, 2019 It appears that the footer in the Dimension Theme is broken. It has the example/default information in it instead of real information. Quote Link to comment Share on other sites More sharing options...
Albert Posted June 16, 2019 Share Posted June 16, 2019 Thank you, I have fixed this by disabling the footer (for now). I do need to find an appropriate image to use in the header for that theme, though. As well as add a proper AtariAge logo to the header (this also goes for the Deflection theme). ..Al Quote Link to comment Share on other sites More sharing options...
Tempest Posted June 16, 2019 Author Share Posted June 16, 2019 As long as I got you here, is the 'My New Content' button (the one that showed you only the posts you made or replied to) coming back or has that functionality been rolled into something else? Quote Link to comment Share on other sites More sharing options...
Albert Posted June 16, 2019 Share Posted June 16, 2019 Click on the "My Activity Streams" link at the top of the page. You'll see several different queries, including "Content I Started" and "Content I Posted In". You can customize these to your liking and then save them as a new stream (that you can rename) as well. ..Al Quote Link to comment Share on other sites More sharing options...
Tempest Posted June 16, 2019 Author Share Posted June 16, 2019 2 minutes ago, Albert said: Click on the "My Activity Streams" link at the top of the page. You'll see several different queries, including "Content I Started" and "Content I Posted In". You can customize these to your liking and then save them as a new stream (that you can rename) as well. ..Al Ah. Many thanks. Quote Link to comment Share on other sites More sharing options...
Albert Posted June 16, 2019 Share Posted June 16, 2019 18 minutes ago, Tempest said: Ah. Many thanks. You're welcome! Quote Link to comment Share on other sites More sharing options...
