Sign in to follow this
Kalani
Are these Source ports feasible?
The source code  for the n64 mk trilogy and turbo graphix / neo geo source code for art of fighting. How feasible would porting either of those be? Mk trilogy is a early build?
I'm definitely not qualified to say but speculate it being harder to convert said source into something usable for the Jag than it would be to write something entirely from the ground up.
Does the source also contain all the original music and art assets?
IMHO you could reuse the "gameplay"/AI, but everything else must be redone, the Jaguar hardware it's very different to the other consoles.
Yes they do. The art of fighting  uses the turbo 16 asets.
The mk sources diffinately does https://archive.org/download/Various-Mortal-Kombat-3-Source-Code-Collection
Edited by Kalani
Sent before finished making reply
I wonder if something like Microwindows was adapted for the Jag if that would help ease the conversion.
I went through all 3 PC, PSX and N64 and none seem to include original artwork sources. The PC has a few screens for title and copyright text but nothing useful otherwise from the quick glimpse through it all. It does have all the sfx and music however.
Suppose there's this but I can't imagine it going well, especially without a ton of work involved: https://www.mortalkombatwarehouse.com/umk3/#title
Edited by Clint Thompson
Could they have been baked into the obj files?  They are substantially bigger than the corresponding ASM files. Ie Artbell ASM file is 390 bytes. It's obj file is substantially bigger. 332k
If so though the original separate artwork does seem to be not included. At least in the PC version.
Probably the case but no idea how to reverse/extract that. Even with assets extracted, I don't see anyone putting the time and effort into re-creating something like this when there are a dozen other perfectly good ports already in existence and effort better spent elsewhere for new or different games.
Wow you guys really overthink stuff around here. Clint you wouldn't need the specific graphics assets from these sources if you wanted to recreate Mortal Kombat on Jaguar. You could use the source code and adapt one of many M.U.G.E.N. .sff files to this source.
Literally EVERY Mortal Kombat character has been ripped for use with M.U.G.E.N. as well as all the healthbars and hitspark effects. Most of the .sff files are pretty small in size and usually in 8 bit 256 color.
Although, I wouldn't want to invest the time in reconstructing such a project either. Even with all of the graphics assets readily available it sounds like a PITA.
There was a guy here before who was heavily into Mortal Kombat and M.U.G.E.N. coding. He was a Jaguar fan. I don't remember his name but I'm willing to bet if anyone would be able to get this type of project going, it would be him
https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DC7w7g1_gSMA&ved=2ahUKEwiJ84SU8f3iAhUNLs0KHYe3B0EQwqsBMAF6BAgBEAU&usg=AOvVaw3C1UH9AwHHFJ7GnJrUTvd2 people are building the sources for n64.  Have you seen the mortal Kombat 2 plus or ultimate mortal Kombat 3 plus arcade rom hack.
What about art of fighting. It's code is 68k asm? Shouldn't it be the easier of the conversions. It's only three button punch kick shift-style/throw. Plus a taunt and start Which could be consolidated.
I believe that I read the 3do version used the PSX sources. If that's the case then it would probably  be easier to match up what goes where than using graphic rips.
If the obj files are there they might just be having it link the obj files instead of checking dependancies.
I will ask those that compiled the rom about the about the assets.  Maybe the assets where in original dump and not on the current upload.
large.Screenshot_20190626-124836.png.2d0e8d6d51e6c3b39fdc17cd6a3bffd7.png some one said check out .psi files.  https://www.google.com/amp/s/amp.reddit.com/r/DataHoarder/comments/9r0l0n/someone_on_4chan_leaked_source_codes_for_mortal/
