Sign in to follow this
Shift838
Geneve 9640 DIN Video to DB9
I was thinking for all the Geneve users out there that may have a RGB monitor and hate soldering the din connector to cables.
So... I came up with this.  a standard din 8 pin that is used on cables will solder directly on one side and on the other a  DB9 Male.  Plugs right in to the Geneve then you can make your own cables easily with db9 connectors.
Edited by Shift838
I have ordered a few.  a Geneve'r will need to make their own cable for the DB9 but it's a hell of a lot easier than messing with the DIN connectors.
I got the test boards in.  Put one together and decided to interface it with a GBSGenie EVPC board with a GBS8200 since I had an awesome case for use for the GBS8200 from Corei64 (HERE).  I just had to drill a hole for the audio pigtail.
the DB9 converter board fits nicely on the back of the Geneve video socket.  I have used a small pigtail for audio.
See pics.  It works great with the Geneve.  Good clear picture and hooked up VGA!
