ryanr256 #1 Posted June 24, 2019 Finished putting a Newell 256k RAM upgrade into a 1200xl. Flipped the rocker on the surge protector to test the install and I get nothing. Try the 2 1050s plugged into the same strip and nope, no power either. So, I take my spare PS and plug it directly into the wall. The 1200xl's power led comes on. Plug the PS into the surge protector (I should have known better, I know) and I hear a "click" and no power. Looks like they may have just blown a fuse. I'll have to cut them open to find out. Damn. -Bob Quote Share this post Link to post Share on other sites
ChildOfCv #2 Posted June 24, 2019 Maybe the surge protector has done its surge protection duty and now needs a decent burial? Or maybe I misunderstood the series of events... Quote Share this post Link to post Share on other sites
+DrVenkman #3 Posted June 24, 2019 Dump the power strip and plug One of the 9VAC bricks right into the wall. Measure the unloaded output of the transformer. It should read around 10.5VAC unloaded. If it does your brick is fine. 1 Quote Share this post Link to post Share on other sites
ryanr256 #4 Posted June 24, 2019 (edited) 4 hours ago, ChildOfCv said: Maybe the surge protector has done its surge protection duty and now needs a decent burial? Or maybe I misunderstood the series of events... The surge protector is the issue. Yes, it needs a decent burial. 1 hour ago, DrVenkman said: Dump the power strip and plug One of the 9VAC bricks right into the wall. Measure the unloaded output of the transformer. It should read around 10.5VAC unloaded. If it does your brick is fine. I'm not getting anything out of the bricks. That's why I'm hoping it's just a blown fuse. -Bob Edited June 24, 2019 by ryanr256 Quote Share this post Link to post Share on other sites
_The Doctor__ #5 Posted June 24, 2019 32 minutes ago, ryanr256 said: The surge protector is the issue. Yes, it needs a decent burial. I'm not getting anything out of the bricks. That's why I'm hoping it's just a blown fuse. -Bob Almost to a certainty, as I've yet to see burned up wingdings in any Atari step down transformer block since 1978. It's going to be the fuse, a joint, connection, sometimes a wire or connector/plug. Always an easy fix costing zero to little for a fix. 1 Quote Share this post Link to post Share on other sites
ryanr256 #6 Posted June 24, 2019 1 hour ago, _The Doctor__ said: Almost to a certainty, as I've yet to see burned up wingdings in any Atari step down transformer block since 1978. It's going to be the fuse, a joint, connection, sometimes a wire or connector/plug. Always an easy fix costing zero to little for a fix. The tough part is going to be breaking into the brick. I should be able to cut through the plastic pretty easily though. -Bob Quote Share this post Link to post Share on other sites
_The Doctor__ #7 Posted June 24, 2019 (edited) I've posted how to open them as had others, and some pictures as well, if done carefully you won't really notice they were even opened. Pictures of opened stepdown transformer block case https://atariage.com/forums/topic/131012-power-supply-question-800-810/?do=findComment&comment=3709599 several more such pictures and threads covering this including other styles, screws under the feet, glued, etc. are on the forums. I posted the last one I remembered anything about. Edited June 24, 2019 by _The Doctor__ 1 Quote Share this post Link to post Share on other sites
ryanr256 #8 Posted June 24, 2019 54 minutes ago, _The Doctor__ said: I've posted how to open them as had others, and some pictures as well, if done carefully you won't really notice they were even opened. Pictures of opened stepdown transformer block case https://atariage.com/forums/topic/131012-power-supply-question-800-810/?do=findComment&comment=3709599 several more such pictures and threads covering this including other styles, screws under the feet, glued, etc. are on the forums. I posted the last one I remembered anything about. Thanks for the info. -Bob Quote Share this post Link to post Share on other sites
Gunstar #9 Posted June 24, 2019 (edited) I have a couple of them I blew the fuses on; as others have said, the most likely culprit. I also had to cut them open, using my trusty Dremel. I really wasn't worried about how they looked though, since they are always tucked away under the desk or whatever, so I just wrapped them in duct tape. I did use black duct tape though. I suppose I could have glued them or whatever, but they are easily opened again now if I should blow the fuses again. Edited June 24, 2019 by Gunstar Quote Share this post Link to post Share on other sites
ChildOfCv #10 Posted June 24, 2019 6 hours ago, ryanr256 said: The surge protector is the issue. Yes, it needs a decent burial. But... is the surge protector more than a MOV/breaker-protected power strip? Because I can't see how something like that can destroy a power supply. 1 Quote Share this post Link to post Share on other sites
_The Doctor__ #11 Posted June 24, 2019 (edited) 21 minutes ago, ChildOfCv said: But... is the surge protector more than a MOV/breaker-protected power strip? Because I can't see how something like that can destroy a power supply. If the strip is live or reversed in polarity depending on how it is switched.... plugging in the device side of the block while still plugged into the strip 'you think is off but is not' can pop a fuse... If the strip has no off switch or the off switch is stuck in the on position the same thing can occur. Edited June 24, 2019 by _The Doctor__ Quote Share this post Link to post Share on other sites
ryanr256 #12 Posted June 25, 2019 5 hours ago, ChildOfCv said: But... is the surge protector more than a MOV/breaker-protected power strip? Because I can't see how something like that can destroy a power supply. The surge protector is old. The power supplys were plugged into the surge protector and into the 1200xl/1050s. I turned the surge protector on and the power supplys died. I don't know if a spike from turning the surge protector on caused the issue. Once I open one of the power supplys and am able to easily replace a fuse I can do more testing. I should be able to work on this before the weekend. -Bob Quote Share this post Link to post Share on other sites
_The Doctor__ #13 Posted June 25, 2019 fuse type is a pig tail, you will need a soldering iron, I suggest putting in a re-settable breaker or fuse holder so you can change the fuse at will in the future... 1 Quote Share this post Link to post Share on other sites
ryanr256 #14 Posted July 12, 2019 I'm bringing this back up because, well, I'm an idiot. No, seriously. IDIOT. I hope you all won't revoke my hobbyist card over this. The reason the fuses popped on the power supplies is that I had left the bottom half of the shielding in place and the metal was shorting the pins on the power input. Damn. I cut open one of the bricks and soldered in a new fuse. It popped as soon as I turned on the 1200XL. I put in a new fuse, disconnected the cord from the computer and plugged in the brick. The fuse held. I measured the voltage (AC) at the plug and it was 10.4 volts. I said to myself, "OK something's going on with the computer. A simple memory upgrade shouldn't cause a short in the power." That's when I realized what was happening. So, I get to wear the idiot tag for a while. Now I'll find a fuse holder and a project box to put the guts of the brick in. Damn. -Bob Quote Share this post Link to post Share on other sites
_The Doctor__ #15 Posted July 12, 2019 If you were careful, you can just glue or screw the bricks back together... It probably won't even be noticed. Quote Share this post Link to post Share on other sites
ryanr256 #16 Posted July 12, 2019 20 minutes ago, _The Doctor__ said: If you were careful, you can just glue or screw the bricks back together... It probably won't even be noticed. On this one I wasn't careful. I used a dremel to cut the case. I will be less destructive with the others. -Bob Quote Share this post Link to post Share on other sites
manterola #17 Posted July 14, 2019 I tried cutting with a knife and force a little with a screwdriver. Bad idea, it was to tight and glued together that the plastic broke (not the glue). The good part is that I replaced the fuse and now I have a new power supply for my xf551. 1 Quote Share this post Link to post Share on other sites
ryanr256 #18 Posted July 15, 2019 On 7/13/2019 at 8:44 PM, manterola said: I tried cutting with a knife and force a little with a screwdriver. Bad idea, it was to tight and glued together that the plastic broke (not the glue). The good part is that I replaced the fuse and now I have a new power supply for my xf551. I did the same. That's why I used the Dremel to cut it open. I could still probably tape it back together. I do want to add a fuse holder to it. -Bob Quote Share this post Link to post Share on other sites
