cbmeeks Posted June 25, 2019 Share Posted June 25, 2019 I'm a fan of Gateway 2000. Don't ask me why....I guess it's the cow logo. I'm not sure if this qualifies as "Classic Computing" but a while back I was at a thrift store and saw a Gateway computer (after they dropped the "2000") that was a Pentium 4, 256 MiB RAM and 1.5 Ghz CPU. It has two DVD drives and a floppy drive. It was dirty but it cleaned up nice and works great. It's a small tower model and I already had a PS/2 Gateway keyboard. Oh, and it only cost $4.99. So, one of the first things I'm using it for is to read many of my old IDE hard drives since my modern computer is SATA only. But when I'm done with that, I'm looking for suggestions. I thought about making it a bench computer for random work but that seems a little boring. I already have a 486 for DOS gaming (which I prefer) and I'm not into modern shooters. Another idea was to put some form of BSD on there (which I am a fan of) and use it for a small server. But that seems boring too (especially since I have better computers for this). I guess I could make it another DOS gaming PC since it's physically smaller than my 486. But I would have to drastically slow it down somehow. Suggestions? Thanks! Quote Link to comment Share on other sites More sharing options...
carlsson Posted June 25, 2019 Share Posted June 25, 2019 Perhaps there are some Windows 98 or XP games that are not modern shooters you would like to play? How about other software that doesn't exist for newer operating systems? There used to be a lot of tools for disk manipulation, early emulators, hardware interfaces to various EPROM programmers, scanners and more that no longer are supported on recent systems. It doesn't say if you already have a good working XP class system for such purposes, otherwise it would kind of make sense, in particular if you can fit a 5.25" drive into it and perhaps have some older computers using MFM formats which you could write with Omniflop/Omnidisk/something in Linux. 1 Quote Link to comment Share on other sites More sharing options...
mr_me Posted June 28, 2019 Share Posted June 28, 2019 Windows 95/98 games are usually the problem on a modern computer. Dosbox handles dos games quite well. Like Carlsson suggests make it a 2000 era gaming computer. Quote Link to comment Share on other sites More sharing options...
Keatah Posted June 28, 2019 Share Posted June 28, 2019 (edited) Make it a utility/experiment computer. By conventional wisdom it doesn't qualify for classic status yet. But it will. We still have to get past the original Pentium, and then the PII and PIII. Edited June 28, 2019 by Keatah Quote Link to comment Share on other sites More sharing options...
boxpressed Posted June 28, 2019 Share Posted June 28, 2019 Phil's Computer Lab on Youtube has some nice videos on using a P4 system to play retro games. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 29, 2019 Share Posted June 29, 2019 5 hours ago, Keatah said: Make it a utility/experiment computer. By conventional wisdom it doesn't qualify for classic status yet. But it will. We still have to get past the original Pentium, and then the PII and PIII. I have an AMD K6-III+ running as a Solaris server. Does that count as a classic? Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted June 29, 2019 Share Posted June 29, 2019 I have a 2.4GHz IBM P4 and it would be great for Win 95/98 and XP games. It's only lacking in graphics atm. It can handle anything released for 95/98 but it's not going to be able to play any games like Doom 3 without a better GPU. It's only got a 64MB Geforce card. 5 hours ago, Keatah said: Make it a utility/experiment computer. By conventional wisdom it doesn't qualify for classic status yet. But it will. We still have to get past the original Pentium, and then the PII and PIII. I have an AMD K6 200MHz (first generation K6) and I consider that system classic as it only has MS-DOS 6.22 installed (no Windows). Oldest game I've played on it without speed issues was the 1985 DOS port of Ms. Pacman. Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted June 29, 2019 Share Posted June 29, 2019 (edited) Also I've ran DOS (via Win 98) on a 2GHz dual core system before... the only issue was sound since the board was PCI/PCIe only there as no way to use an ISA Sound Blaster (Sound Blaster Live (PCI) FM emulation would be set to an IRQ that I could not access in DOS mode). Doom did run fine (without sound though). Edited June 29, 2019 by DragonGrafx-16 Quote Link to comment Share on other sites More sharing options...
20ohm20 Posted June 29, 2019 Share Posted June 29, 2019 A 1.6GHz P4 w/2GB of RAM and WinXP was used in my MAME cabinet for several years. I'd probably still be using it if one of the DIMM sockets on the motherboard didn't stop working. Quote Link to comment Share on other sites More sharing options...
SSG Posted July 3, 2019 Share Posted July 3, 2019 Windows 95 would require a special Patch to make it work, but i managed to get it to work. Fire up Age of Empires and call it a day! 2 Quote Link to comment Share on other sites More sharing options...
Austin Posted July 3, 2019 Share Posted July 3, 2019 (edited) If you are leaning towards using it as a gaming rig, then I'd recommend Windows 98 SE. You can still use your 486 machine for many DOS titles, but then use the '98 machine for running later era DOS games with faster load times and higher resolutions. You obviously also get the benefit of being able to play Windows-based titles. Since Windows '98 is a 16/32-bit hybrid, you can run a larger amount of Windows titles than you would be able to with just '95. There is also USB support and you can use some more modern game controllers on it, not to mention be able to transfer data to it via a USB thumb drive. It's quite the flexible setup once you get it up and running. I have close to an equivalent system running Windows 98 SE (Athlon XP, 2.1ghz) and it's my favorite system out of the various older rigs I have built (the other two being a Windows 95 machine with a Pentium 200 and a Windows XP/7 with a decade old Phenom II quad core). It covers such a wide gamut of titles, from early '90s DOS games to some mid 2000's titles (Painkiller from 2004 runs fantastic on it, for instance). I did add a Radeon 9550 256mb GPU which helps considerably on the Windows side, and if you wanted to do something similar to yours, GPUs from the mid 2000's aren't in big demand at the moment and are pretty cheap (like, $15 - $25 for a really solid card). Edited July 3, 2019 by Austin 4 Quote Link to comment Share on other sites More sharing options...
MrMaddog Posted July 7, 2019 Share Posted July 7, 2019 On 7/2/2019 at 11:36 PM, Austin said: If you are leaning towards using it as a gaming rig, then I'd recommend Windows 98 SE. You can still use your 486 machine for many DOS titles, but then use the '98 machine for running later era DOS games with faster load times and higher resolutions. You obviously also get the benefit of being able to play Windows-based titles. Since Windows '98 is a 16/32-bit hybrid, you can run a larger amount of Windows titles than you would be able to with just '95. There is also USB support and you can use some more modern game controllers on it, not to mention be able to transfer data to it via a USB thumb drive. It's quite the flexible setup once you get it up and running. I'd also recommend dual booting 98 SE & XP since XP is recommended for playing early-to-mid 2000's games that won't run on Win 98 (artifical check) or even modern PC's that are 64-bit. With both OS's, you'll have the best of all the 32-bit Windows games. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted July 7, 2019 Share Posted July 7, 2019 Most Windows 98 games run just as well or better in XP. The exceptions are those games that require hardware with no XP drivers such as Aureal Vortex sound cards. Windows 98 is a versatile OS because of it can play DOS games. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 7, 2019 Share Posted July 7, 2019 gut it and put a modern system in the retro case, suprised the boat anchor actually still works pentium 4's were in that magical time where all the capacitors were made out of lead and snot and had a 3 year lifespan just sitting in the box 1 1 Quote Link to comment Share on other sites More sharing options...
Austin Posted July 8, 2019 Share Posted July 8, 2019 9 hours ago, MrMaddog said: I'd also recommend dual booting 98 SE & XP since XP is recommended for playing early-to-mid 2000's games that won't run on Win 98 (artifical check) or even modern PC's that are 64-bit. With both OS's, you'll have the best of all the 32-bit Windows games. I'd say dual booting can be worth the trouble, absolutely, if the system is strong enough to handle the XP era of games well. In this case I'd probably pass on it. With a 1.5ghz P4 most if not all of those games that won't function in Windows '98 aren't going to run well on this system anyway, so dual booting isn't worth the trouble. (Doom 3 is one of those games that won't play on Windows 98, but it needs a much heftier setup to be worth the hassle). Quote Link to comment Share on other sites More sharing options...
Nebulon Posted July 23, 2019 Share Posted July 23, 2019 You could: - Run MAME32 v.35 on it and play classic 80s arcade games. - Mess around with Photoshop CS2 or an old version of Illustrator. - Run LightWave 5.6 and experiment with the neat-o Hypervoxel textures (and other textures that are fairly unique to that version of the software). - Cleanly rip audio to MP3 using AudioCatalyst or other similar apps from the early 2000s. - Record audio with an old version of Sound Forge or Acid (back when they were owned by Sonic Foundry). - Burn audio CDs reliably (if you're still using CDs). - Use old computer emulators on it (like the Tandy Color Computer 2 and 3 emulators). http://www.classiccmp.org/cpmarchives/trs80/mirrors/www.discover-net.net/~dmkeil/coco/index.htm or maybe an older version of AppleWin: https://mirrors.apple2.org.za/ftp.apple.asimov.net/ - Simply enjoy having an XP32 machine around. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 23, 2019 Share Posted July 23, 2019 (edited) 5 hours ago, Nebulon said: - Simply enjoy having an XP32 machine around. does anyone really enjoy that? XP is truely a garbage OS that people only love due to it being around their entire childhood or stockholm syndrome it was piggy when it came out and did nothing better than 2k, it held back any modern hardware it was installed on when it died, and it had more holes than swiss cheese which just made it run even slower when they plugged another cork in the rotting corpse but it had that useless fugly UI and that down syndrome dog going for it Edited July 23, 2019 by Osgeld 1 1 Quote Link to comment Share on other sites More sharing options...
Nebulon Posted July 24, 2019 Share Posted July 24, 2019 42 minutes ago, Osgeld said: does anyone really enjoy that? XP is truely a garbage OS that people only love due to it being around their entire childhood or stockholm syndrome it was piggy when it came out and did nothing better than 2k, it held back any modern hardware it was installed on when it died, and it had more holes than swiss cheese which just made it run even slower when they plugged another cork in the rotting corpse but it had that useless fugly UI and that down syndrome dog going for it XP was slightly easier to troubleshoot from an I.T. perspective than 2000. I like both 2000 and XP though. By the time XP SP3 was released, it was a nice solid OS. I have zero complaints about it, and this is after supporting it for corporate I.T. (for over 6000 employees) for 5 years. Oh, and I like the look of the UI. As for functionality, it kicks the crap out of 8 and 10. 2 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 24, 2019 Share Posted July 24, 2019 (edited) 8 yes, 10 ... its like they took the best of 7 and the worst of XP least 10's search isnt functionally useless (what kind of file is it, where is it located, when was it modified what is part of the filename, what do you want to search for ... 25 min and 30 mouse clicks later, no search results... ITS A EFFIN TEXT FILE ON MY DESKTOP!) Edited July 24, 2019 by Osgeld Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 24, 2019 Share Posted July 24, 2019 If you wanted to play old computer games designed for windows, wouldn't windows 98 be more compatible than windows xp-32 or windows 2000? Quote Link to comment Share on other sites More sharing options...
Keatah Posted July 24, 2019 Share Posted July 24, 2019 Depends the exact era of games. Certain games may be made for 98 and others for XP. Quote Link to comment Share on other sites More sharing options...
carlsson Posted July 24, 2019 Share Posted July 24, 2019 Also depends on the hardware requirements. Some cards might have better drivers in XP than 98. For instance the on-board SiS graphics on an older Athlon XP board that I used to have (but which I unfortunately zapped a couple of years ago) had graphics drivers in 98 that every now and then would cause the screen to go completely funky, sometimes requiring a reboot to work. Years later when I installed a copy of XP, I found that the corresponding drivers for that OS were completely smooth, on the exact same hardware. But yes, I retain my opinion that if you got legacy hardware which might not be able to connect to a modern PC or for which there are no suitable drivers, a "tweener" like a Pentium 4 machine would come very handy if you're into vintage computering and tinkering, even if you're not strictly planning to play Windows based games. While from a software perspective, a 15 year old PC might be nearly the same as a brand new one (except slower and less memory capacity), from a hardware perspective the industry all the time keeps moving forward and assumes you will want to leap along at the same speed, leaving your old peripherals and software behind unless you stick around with obsoleted computers. Quote Link to comment Share on other sites More sharing options...
Austin Posted July 24, 2019 Share Posted July 24, 2019 11 hours ago, Osgeld said: does anyone really enjoy that? XP is truely a garbage OS that people only love due to it being around their entire childhood or stockholm syndrome It is great for compatibility with games of its era (2001 and on). Many titles designed with that OS in mind can exhibit stability issues and glitching when run in Windows 7 or Windows 10, so if you want the best experience for them then having an install with XP is worth it. It also has much better backwards compatibility support (Win 95, 98, etc) than 7 or 10. Diablo for instance glitched out completely for me in 7 and 10 both, but it's perfect in XP. I personally have a spare rig with XP and 7 on it to have all my bases covered. Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 24, 2019 Share Posted July 24, 2019 So a Pentium 4 PC, which are so common they are dirt cheap, with dual boot Win98 and WinXP, should run all games that don't run on a modern computer. Depending on the sound card, it could even run DOS games that aren't speed sensitive. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 25, 2019 Share Posted July 25, 2019 no not all xp machines will have drivers available for 98, there's a ton of difference from a machine in the 97-2001 era vs 2011 Quote Link to comment Share on other sites More sharing options...
