I am having a small issue with my code. I am trying to get the duck to stop when it reaches the top after hitting the flyaway state. However no matter what I try the code gets ignored.
Source Code
Relevant section
Any of you experts have any ideas on what's going on?
Edited by Mallard Games
Near label "SkipReverseDuckXVelocity" you are missing a "#", what you mean is probably:
ldx DuckState
cpx #STATE_DUCK_FLYAWAY
As is (cpx STATE_DUCK_FLYAWAY), you are comparing DuckState to the contents of address $02, which happens to be the collision register CXP0FB.
Edit:
This is really a common error and hard to spot, especially in your own code (this is a bit like proof reading your own text).
As you are already using upper-case constants for those values, setting up a regular expression search in your text editor to find any of those missing "#" may be a good idea. E.g.,
\sSTATE_\w*
meaning, we are searching for any words starting with "STATE_" and headed by a white-space character (like a blank).
Any hit should indicate one of those hard to catch errors.
(Alternatively, instead of using a regular expression, just search for " STATE_" [mind the blank!] with word-matching disabled. The regular expression is essentially the same, but matches both heading blanks and tabs. Moreover, you may extend it to match any of your constants at once, like \s(STATE|VALUE|POS)\w* ...)
Edited by NoLand
