StupidEggplantThatNeverPosts
Having Syntax Issue
I'm having a syntax error and I cant figure out whats wrong.
Heres the code:
 rem Generated 6/29/2019 7:26:11 PM by Visual bB Version 1.0.0.568
 rem **********************************
 rem *<filename>                      *
 rem *<description>                   *
 rem *<author>                        *
 rem *<contact info>                  *
 rem *<license>                       *
 set romsize 16k
 dim gamenumber=a
 dim swdebounce=b
 const scorefade=1
 scorecolor=$1a
 swdebounce=0
 gamenumber=1
titlepage
 gosub titledrawscreen bank2
 if gamenumber=1+switchreset then goto gamestart1
 if !switchselect then swdebounce=0
 if swdebounce>0  then swdebounce=swdebounce-1: goto titlepage
 if switchselect then swdebounce=30: gamenumber=gamenumber+1
 if gamenumber=7 then gamenumber=1
 goto titlepage
gamestart1
 playfield:
 ............XX.XX.XX............
 ....XXX.XXX.XX.XX.XX.XXX.XXX....
 ....X.X..X..XX.XX.XX.X.X..X.....
 ....XXX..X..XX.XX.XX.XXX..X.....
 ....X.X..X..XX.XX.XX.XX...X.....
 ....X.X..X..XX.XX.XX.X.X.XXX....
 ...........XX..XX..XX...........
 ..........XX...XX...XX..........
 .........XX....XX....XX.........
end
 COLUBK = $08
 COLUPF = $46
draw_loop
 drawscreen
 goto draw_loop
 bank 2
 asm
 incl
Does anyone notice whats wrong?
