Color used to print character
I have redefined characters to use as graphics. The following code creates my border using the letter Z redefined in blue.
115 COLOR 218:PLOT 0,0:DRAWTO 0,23:DRAWTO 19,23:DRAWTO 19,0:DRAWTO 0,0
I can use COLOR 90 (orange), 122 (green), and 218 (blue) for color registers 0, 1, and 2.
If I use COLOR 186 for color register 3 (inverse lower case) a blue colon is printed and not the red/pink redefined letter Z.
?#6;"inverse-lower-z" creates a red/pink border piece.
How do you use color register 3 (186 in this case) in the above code to create a border with the redefined character z?
Thanks
This listing:
10 GRAPHICS 1+16
20 FOR I=0 TO 255
25 IF I=125 THEN GOTO 40
30 COLOR I:PLOT I-(INT(I/20)*20),INT(I/20)
40 NEXT I
50 GOTO 50
gives:
So the 'Z's are at 90 = 0x5A (orange), 122 = 0x7A (green), 218 = 0xDA (blue) and 250 =0xFA (pink)
So as screen character for 'Z' is actually 0x3A, adding 0x00, 0x40, 0x80 or 0xC0 would give you the character in different colours
So the listing:
10 GRAPHICS 1+16
20 FOR I=0 TO 255
30 POKE PEEK(88)+256*PEEK(89)+I,I
40 NEXT I
50 GOTO 50
gives:
And here the 'Z's are at 58 = 0x3A (orange), 122 = 0x7A (green), 186 = 0xBA (blue) and 250 =0xFA (pink)
So it can be concluded the 'COLOR' value does not directly correlate with the screen-code values, so consistently either use COLOR/PLOT or POKEs.
Edited by Wrathchild
The chart shows the 'Z' character's color0-3 values at character 90 which is then repeated at 122 (lower z):
which mirror the 'COLOR' statements results first 3 values but appear to have got the color3 value wrong, especially the values for "C.3" in the right two grids are the same as "C.2" in the left two grids.
They should be updated to range from 224-255 instead.
7 hours ago, Wrathchild said:
This listing:
10 GRAPHICS 1+16
20 FOR I=0 TO 255
40 NEXT I
50 GOTO 50
gives:
So the listing:
10 GRAPHICS 1+16
20 FOR I=0 TO 255
40 NEXT I
50 GOTO 50
gives:
As wrathchild stated, please see this reference :
https://www.atariarchives.org/c2bag/page029.php
In OS graphics modes 1 and 2 the colour is decided by the top 2 bits of the "screen code".
The screen code is often not the same as ATASCII - this is by design because if you grouped ASCII into 2 lots of 64, like 0-63 and 64-127 you'd have the numbers and many of the punctuation symbols in one half and the upper/lower case characters in the other.
The way they did it gives you upper case, numbers and most of the special characters you need for everyday use.  Another side effect is Space becomes 0 so the clear-screen operation can be much the same between character and graphics modes, for what that's worth.
Normal Ascii sees such control characters with the low values (12) but Atari wanted the graphics characters and most of the existing control characters were a bit irrelevant to the computer so they just used "spares".
Really the biggest impact is probably the CR/LF difference, the other stuff doesn't seem to matter too much.
Is there a definitive table that provides all the correct values to use when use poke and color to display a character as a certain color register?
