hloberg
harware keyboard problem, this ones strange
Just got a new beige, I don't think it's a QI as I don't see it on the motherboard, anyway only the 1, lowercase t and 0 work? I opened it up and it's not a bad keyboard. I disconnected the keyboard from the motherboard tested shorting across the pins on the board that connect the keyboard ribbon cable. only certain pins work. I cleaned the pins very well. tested again, still only certain pins work. I even tested shorting across the resistors that lead to the pins to make sure it wasn't a dirty pin issue. same thing. I looked the motherboard over for bad traces and don't seem to see any, of course some really small one could be getting past me. Note; the box had sever water damage but the machine turns on just fine, takes a cartridge (of course can't do anything except console BASIC since can't press 2).
Any ideas?
Any ideas?
9901 bad?
Sent from my LM-G820 using Tapatalk
6 minutes ago, FarmerPotato said:
I think you described that you disconnected the keyboard, and touched pins together to mimic keys pressed?
In that case most likely the 9901 chip is bad.
ugh, what I thought but not what I wanted to hear. I think I'll bring it to Austin with me.
Explains why the guy sold it to me for just a little above the cost of shipping. The @@#&(# probably knew it was bad but didn't list it for parts or repair.
oh well, it'll make a good electronics project to see if I can get it working again.
13 minutes ago, arcadeshopper said:
9902 bad?
you sell them?
We can get one out of a scrap 4A for you.
Otherwise it's about $3-$5 from China, $30 domestic.
I forget whether it's soldered or socketed, but no problem, we can desolder at the Hackerspace.
Soldered
2 minutes ago, arcadeshopper said:
Soldered
not one of my favorite things to do but I have desoldered and soldered in sockets on boards before. I be sure to bring some sockets.
sounds like a plan. thanks.
OK. We have a really nice Hakko desoldering vacuum gun and ChipQuik. Makes it a breeze. Bring a 40 pin socket.
40 pin, will do.
