arcadeshopper
call load reference
I know i have this somewhere but can't find it easily.
anyone have a sheet of all the useful call loads?  I particularly need the disable/renable the quit key one.
here you go :)
XBASIC LOADS W/EXPMEM
  CALL LOAD(-31806,16)....... DISABLE QUIT KEY
  CALL LOAD(-31806,64)....... KILL SPRITES
  CALL LOAD(-31806,32)....... DISABLE AUTO SOUND PROCESSING
  CALL LOAD(-31806,128)...... DISABLE FCTN QUIT,SOUND,AND SPRITES
  CALL LOAD(-31806,0)........ RESTORE ALL OF THE ABOVE
  CALL LOAD(-31931,0)........ REMOVES XBASIC PROTECTION
  CALL LOAD(-31931,128)...... RESTORE XBASIC PROTECTION
  CALL LOAD(-32699,0)........ REMOVES XBASIC PROTECTION
  CALL LOAD(-32699,128)...... RESTORE XBASIC PROTECTION
SIZE COMMAND FOR BASIC W/EDITOR-ASSEMBLER.
  CALL INIT
  CALL PEEK(-31974,A,B)
  PRINT A*256+B-1776 (1776 OVERHEAD IN BASIC).
CALL FILES(0) COMMAND FOR BASIC W/ E/A , MINIMEM  OR XBASIC
  CALL LOAD(-31888,63,255)... THEN....  NEW         (OR EDIT MODE IN XBASIC) .
  CALL LOAD(-31888,55)....... THEN....  NEW OR RUN  (RESTORE DRIVES)
CHECK FOR "SPEECH SYNTHESIZER"
  CALL PEEK(-28672,A)...........
  Variable A returns a value of 255 or 96 Speech Synthesizer Attached
                                127 or  0 Speech Synthesizer Not Attached
CALL QUIT FROM PROGRAM
  CALL LOAD(-32630,128)...... Return to Title Screen (Graphics Not Restored)
                              1 for basic or 2 for XB as per normal.
  CALL LOAD(-31961,149)...... FOLLOWED BY "END" (MAYBE)
                              Same as above Except (Will Look for and Run
                              A Program called "LOAD" ELSE RETURN TO XBASIC
  CALL LOAD(-31961,51)....... FOLLOWED BY "END"
                              Return to Title Screen (Graphics Restored)
SET SPRITES FOR FASTER PROGRAM?
  CALL LOAD(-31878,X)........ X=Highest number of Sprites in use. FASTER?.
                              X=0 No Sprites are to be Used.
ODD EFFECTS
  CALL LOAD(-32572,1)........ Produces "MUSHY" Keyboard W/Improper char's
  CALL LOAD(-32572,128)...... Disables KEYBOARD COMPLETLY
  CALL LOAD(-31745,0)........ Frozen screen, Blanks Screen after a few seconds.
                              Restore : Title screen by pressing (FCTN -)
My favorite one is missing: 83C4 = -31804
This is the interrupt hook. You can instantly start a machine language program this way without using the DEF table. You should clear 83C4 as the first action.
