shiz Posted July 15, 2019 Share Posted July 15, 2019 I bought a Intellivision a while ago but the controllers don't seem to work exactly. Side buttons and membrane have been cleaned but I'm not really sure if they are broken or not pressed well enough, the d-pad doesn't seem to respond at all. Any way to fix this? Also is there a way to make the RF signal better? It's a bit too faint. Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 15, 2019 Share Posted July 15, 2019 What model intellivision? Are you getting passed the titlescreen? Is there any correct response from any controller input? What cartridges do you have to test with? Quote Link to comment Share on other sites More sharing options...
shiz Posted July 16, 2019 Author Share Posted July 16, 2019 On 7/15/2019 at 6:00 PM, mr_me said: What model intellivision? Are you getting passed the titlescreen? Is there any correct response from any controller input? What cartridges do you have to test with? First model, PAL. I'm using the LFO flashcart. It does react to some buttons but it's hard to select anything. Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 17, 2019 Share Posted July 17, 2019 (edited) You'll need the "enter" button or a side button to start a rom file from ltoflash. Put one rom file and no folders to make it simple, PGA Golf would be good for testing. Do you have any regular cartridges? If nothing works, you can try unplugging one of the controllers for testing. Regarding the faint signal, your TV could be tuned slightly off, or the master clock crystal in the intellivision could be out of tune, and probably other possible explanations. Edited July 17, 2019 by mr_me Quote Link to comment Share on other sites More sharing options...
shiz Posted July 18, 2019 Author Share Posted July 18, 2019 On 7/17/2019 at 2:04 AM, mr_me said: You'll need the "enter" button or a side button to start a rom file from ltoflash. Put one rom file and no folders to make it simple, PGA Golf would be good for testing. Do you have any regular cartridges? If nothing works, you can try unplugging one of the controllers for testing. Regarding the faint signal, your TV could be tuned slightly off, or the master clock crystal in the intellivision could be out of tune, and probably other possible explanations. I tried but now I can't see anything. On my CRT it's just all kinds of snow but none of which you can tell what's happening. How common/uncommon are those French RGB Intellivisions? I'm thinking of taking one of those instead of having to deal with this shit. Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 18, 2019 Share Posted July 18, 2019 What did you try exactly? Quote Link to comment Share on other sites More sharing options...
shiz Posted July 18, 2019 Author Share Posted July 18, 2019 57 minutes ago, mr_me said: What did you try exactly? I turned the console on Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 18, 2019 Share Posted July 18, 2019 Does the screen flash when you press reset? Quote Link to comment Share on other sites More sharing options...
shiz Posted July 19, 2019 Author Share Posted July 19, 2019 16 hours ago, mr_me said: Does the screen flash when you press reset? Depends on what you mean by flash, when I press reset, the screen disappears for a sec or 2 and I the same thing as in the pic. Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 19, 2019 Share Posted July 19, 2019 (edited) Yes, that's a flash. Seems like it got worse since you first posted. Most likely the intellivision is getting correct power from the power supply board. You can check voltages with a voltmeter. You'll find specs here. https://console5.com/wiki/Intellivision Some pal/secam/rgb intellivisions have a lot of extra circuitry between the stic and video out. You can visually inspect it all. I'd start with the voltages coming to the main board. Edited July 19, 2019 by mr_me Quote Link to comment Share on other sites More sharing options...
