rcamp48 #1 Posted July 20, 2019 Is anyone at all able to connect to my BBS, Spy Visits Spy BBS at 99.250.141.63 port 10001 ???? cannot connect locally or through my IP from my end Russ 1 Quote Share this post Link to post Share on other sites
Justin Payne #2 Posted July 20, 2019 No luck. No response. Quote Share this post Link to post Share on other sites
rcamp48 #3 Posted July 20, 2019 let me check the port and baud rate Quote Share this post Link to post Share on other sites
Justin Payne #4 Posted July 20, 2019 I'm just using Putty. Hopefully that works for you. If you need more, just let me know. Quote Share this post Link to post Share on other sites
rcamp48 #5 Posted July 20, 2019 Try it now , I was still connected Quote Share this post Link to post Share on other sites
rcamp48 #6 Posted July 20, 2019 Ya give it another try Quote Share this post Link to post Share on other sites
Justin Payne #8 Posted July 20, 2019 Hanging... Quote Share this post Link to post Share on other sites
rcamp48 #9 Posted July 20, 2019 OK I fixed part of the problem , it was set to min 9600 baud, that would do it Quote Share this post Link to post Share on other sites
Justin Payne #10 Posted July 20, 2019 Nope. Just getting a timeout now. Quote Share this post Link to post Share on other sites
Justin Payne #11 Posted July 20, 2019 You want to go skype? Quote Share this post Link to post Share on other sites
Justin Payne #12 Posted July 20, 2019 Texting would probably be faster. Quote Share this post Link to post Share on other sites
Justin Payne #13 Posted July 20, 2019 It says it's connected but it's not responding. I'm now trying Netrunner instead of Putty just to make sure. Quote Share this post Link to post Share on other sites
rcamp48 #14 Posted July 20, 2019 It is connecting but not doing anything Quote Share this post Link to post Share on other sites
Justin Payne #15 Posted July 20, 2019 Correct. I got something before. It was before you said, "OK I fixed part of the problem , it was set to min 9600 baud, that would do it" Quote Share this post Link to post Share on other sites
Justin Payne #16 Posted July 20, 2019 Ok, now I'm connected but no real prompt. I just change from VT-102 to ANSI. Quote Share this post Link to post Share on other sites
+Bikerbob #17 Posted July 21, 2019 (edited) never tried it.. but I guess you cannot go out and come back in to test yourself? because you are going out and coming in on the same address and port?? James Edited July 21, 2019 by Bikerbob Quote Share this post Link to post Share on other sites
Justin Payne #18 Posted July 21, 2019 5 hours ago, Bikerbob said: never tried it.. but I guess you cannot go out and come back in to test yourself? because you are going out and coming in on the same address and port?? James I've tested my Minecraft server using my external IP address so it's possible. I tried it again today and it still wouldn't connect. Quote Share this post Link to post Share on other sites
rcamp48 #19 Posted July 21, 2019 I can test it I have two machines but it sat on a BBS last night I forgot to put it back up before I went to bed, putting it back up now. I was able to connect to Dark Force BBS at 115200 Baud with Taz so I know the Lantronics is working. Russ Quote Share this post Link to post Share on other sites
+DarkLord #20 Posted July 23, 2019 Umm.... not sure about that 115200 baud there. Max at DarkForce is 19.2. Just sayin'. Quote Share this post Link to post Share on other sites
