rcamp48 #1 Posted July 21, 2019 Well, I got Spy Visits Spy BBS to work, but only at 300 BAUD with Forem ST, apparently the new version has a modem string command for setting NvRam to 19200, but the UDS 10 does not like it, I had to set the baud rate to HST as the read.me file in the BBS software said, instead of setting it to 19200, it does work at 300 baud, so you guys CAN look at it, seems to transfer faster than 300 Baud however, don't know what is up there, I am working on a few screens while the BBS is up, the IP address is 99.250.141.63 port 1989 as you are arriving in the good ole days of 1989, you will see when you log on. Color codes do not seem to work on my end, I might have to change them. Anyways give it a try while I am making new screens. Russ Quote Share this post Link to post Share on other sites
rcamp48 #2 Posted July 21, 2019 If anyone has tried and got cut off due to max calls I will fix that also telnet has to be put in there somehow...………….Russ PS: I am working on the BBS so it will be back up in 30 mins Quote Share this post Link to post Share on other sites
rcamp48 #3 Posted July 22, 2019 I am working on the BBS so its down until I go to bed , whenever that is as I need to work on the Mega ST4, making color screens with IGS Quote Share this post Link to post Share on other sites
rcamp48 #4 Posted July 22, 2019 BBS works at speeds faster than 300, it says 300, but is likely 19200 as that is what I set it for, lots of changes coming.... Russ Putting lots of work into it. Quote Share this post Link to post Share on other sites
rcamp48 #5 Posted July 22, 2019 I am now making changes to the source from Forem ST , changing a few things , find out what I have changed and hope that it still works. I am using DevPac to compile the source and I used Easy Rider 4 , English version with the convert program to get the source from the forem.tos file. Quote Share this post Link to post Share on other sites
ataricrypt #6 Posted July 22, 2019 I look forward to trying this Quote Share this post Link to post Share on other sites
rcamp48 #7 Posted July 22, 2019 I have a problem, I am running Forem ST on my Mega ST4, and the free memory it shows is a negative number, thats why I was having problems. Is there a fix for that ??? Russ Quote Share this post Link to post Share on other sites
Wally1 #8 Posted July 22, 2019 Best of luck with this, Russ. Is this a dialup? Thanks, Wally Quote Share this post Link to post Share on other sites
rcamp48 #9 Posted July 22, 2019 No its Telnet and I am switching to BBS Express , setting it up as we speak ..... I may be able to get a modem online too with the PC Quote Share this post Link to post Share on other sites
+DarkLord #10 Posted July 23, 2019 Lots of Express users around (both past and present) so if you have questions, just fire away. Quote Share this post Link to post Share on other sites
JohnPolka #11 Posted July 23, 2019 21 hours ago, rcamp48 said: No its Telnet and I am switching to BBS Express , setting it up as we speak ..... I may be able to get a modem online too with the PC Are you sure? I was just on an hour or so ago and you were still running FoReM ST. -JP Quote Share this post Link to post Share on other sites
