Sign in to follow this
kl99
Extended Basic - Is this a Syntax Error or an Interpreter Bug?
Posted (edited)
Hi Guys,
yesterday I have run into a nasty Syntax Error in Extended Basic, which also occurs in RXB.
I don't understand it and wonder if the line really contains a Syntax Error or this is a Interpreter Bug.
Version 1:
1 IF A=1 THEN 2 ELSE FOR I=1 TO 2 :: PRINT I :: NEXT I
2 END
Version 2:
1 IF A=1 THEN 2 :: FOR I=1 TO 2 :: PRINT I :: NEXT I
2 END
Both versions complain about a Syntax Error in Line 1.
I would like to analyze it with the help of you and maybe RXB can be even fixed.
Edited by kl99
It is not a bug. The XB manual clearly states on page 95: “The IF-THEN-ELSE statement cannot contain DATA, DEF, DIM, FOR, NEXT,
OPTION BASE, SUB, or SUBEND.”
...lee
  • Thanks 3
I ran into this in the 10 line programming challenge. I think TI was being overcautious. By turning off prescan in line 95 the following runs as expected.
90 A=2 :: I=1
95 [email protected]
100 IF A=1 THEN 200 ELSE FOR I=1 TO 2 :: PRINT I :: NEXT I
200 PRINT "LINE 200"
But it's easy enough to fix this by breaking up the line:
100 IF A=1 THEN 200
110 FOR I=1 TO 2 :: PRINT I :: NEXT I
  • Like 4
