Europatari #1 Posted August 16, 2019 hello People, i want to play some other Pong sports games except just pong, but they are all 2 Player only is it possible to take the Computer AI from the 1 Player Pong mode and paste it to the 2 player Games/Modes? Quote Share this post Link to post Share on other sites
Supergun #2 Posted August 16, 2019 If it were that easy, then wouldn’t Atari have done it and implemented it into the game? 2 Quote Share this post Link to post Share on other sites
Tangentg #3 Posted August 16, 2019 My favourite game variation is the foosball one and it's probably less straightforward to align "one of the paddles, probably the closest one" with the ball in that variation. Quote Share this post Link to post Share on other sites
Europatari #4 Posted August 17, 2019 9 hours ago, Tangentg said: My favourite game variation is the foosball one and it's probably less straightforward to align "one of the paddles, probably the closest one" with the ball in that variation. exactly, do you think, that by that way, the computer ai would work Quote Share this post Link to post Share on other sites
root42 #5 Posted August 17, 2019 Time for a machine learning AI running on a Pi with camera and attached to the paddle/joystick port! 1 Quote Share this post Link to post Share on other sites
Nukey Shay #6 Posted August 17, 2019 1 hour ago, Europatari said: exactly, do you think, that by that way, the computer ai would work No need to theorize. Other "robot" games were not incorporated because the "AI" is very dim...and is only designed to handle up/down movement. The program depends upon if bit4 is set in Ram address $97, put there by the game select table at $F712-$F742 (even # addresses), to check if the "robot" should be in control of the left paddle in the left port. The game is easily hacked to always have the robot present: Always take the branch at $F14B, and never take the branch at $F1F0 Hockey seems to be a -little- playable, but it's still easy to beat. Robot Olympics.bin 1 1 Quote Share this post Link to post Share on other sites
Europatari #7 Posted August 17, 2019 (edited) Thank You but it should work with a joystick, because if i put the game on the atari flashback portable, then you cannot steer it Edited August 17, 2019 by Europatari Quote Share this post Link to post Share on other sites
Europatari #8 Posted August 18, 2019 23 hours ago, Nukey Shay said: Always take the branch at $F14B, and never take the branch at $F1F0 yeah, but then the right paddle isn't steerable. how can i fix this? Quote Share this post Link to post Share on other sites
Nukey Shay #9 Posted August 18, 2019 Works fine here. Remember that this made for the paddle controllers. Stella automatically selects paddle controllers when a Rom that it knows about needs them. Hacking a game in any way, Stella would then fail to recognize it...and default to joystick control. So you need to reset the Rom as needing paddle controllers in Stella's (game properties) menu. No such menu exists for the AFP, so the game itself needs to be hacked to use joystick control. This is far more complicated than activating the robot in all variations. Since the latter does not work all that well as an opponent anyway, I'll pass. This hack was just to demonstrate what the robot player is like in other variations...playable in Stella or actual hardware just fine. Quote Share this post Link to post Share on other sites
Europatari #10 Posted August 18, 2019 that entire problem got fixed i can finally play the game, but after i score for the first time, then the player stops to serve here is the rom however Video Olympics AI.bin Quote Share this post Link to post Share on other sites
+stephena #11 Posted August 18, 2019 2 hours ago, Nukey Shay said: Remember that this made for the paddle controllers. Stella automatically selects paddle controllers when a Rom that it knows about needs them. Hacking a game in any way, Stella would then fail to recognize it...and default to joystick control. So you need to reset the Rom as needing paddle controllers in Stella's (game properties) menu. The next version of Stella actually has some fairly sophisticated autodetection for paddles and certain other controllers. So changing the ROM will no longer do this; paddles should continue to work. Unless of course the code that's removed is what actually reads from the paddles; that's what Stella is searching for to know that paddles are required! 1 Quote Share this post Link to post Share on other sites
Europatari #12 Posted August 19, 2019 19 hours ago, stephena said: The next version of Stella actually has some fairly sophisticated autodetection for paddles and certain other controllers. So changing the ROM will no longer do this; paddles should continue to work. Unless of course the code that's removed is what actually reads from the paddles; that's what Stella is searching for to know that paddles are required! yeah, maybe that is the problem with the original version like i said, i fixed that version below to work on the afbp 2017, but the only problem is: after i score for the first time, then the computer player stops to serve Quote Share this post Link to post Share on other sites
Europatari #13 Posted September 6, 2019 any help here? after i score for the first time, then the computer player stops to serve Quote Share this post Link to post Share on other sites
Mark loves Stella #14 Posted September 11, 2019 On 8/16/2019 at 9:07 AM, Europatari said: hello People, i want to play some other Pong sports games except just pong, but they are all 2 Player only is it possible to take the Computer AI from the 1 Player Pong mode and paste it to the 2 player Games/Modes? I wrote an AI pong game with Batari Basic some time ago that I just called Tennis. Press the player 2 button to start a game against the CPU. If you are using Stella, F3-F8 change paddle and ball size as well as speed and trajectory. Quote Share this post Link to post Share on other sites
Europatari #15 Posted September 13, 2019 On 9/11/2019 at 4:15 AM, Mark loves Stella said: I wrote an AI pong game with Batari Basic some time ago that I just called Tennis. Press the player 2 button to start a game against the CPU. If you are using Stella, F3-F8 change paddle and ball size as well as speed and trajectory. not a bad thing, but it lacks all the other video olympics sports, such as soccer, hockey, handball, foozpong and basketball Quote Share this post Link to post Share on other sites
Tangentg #16 Posted September 27, 2019 (edited) I mean, what I said was my cents about the AI matter. That it's not so straightforward to implement. But that's been dealt with now. Edited September 27, 2019 by Tangentg Quote Share this post Link to post Share on other sites
