Sign in to follow this
hloberg
Who created TI-99 BASIC, TI or MS?
Based on the current information, that theory makes the most sense to me too. Every couple of years we get one new piece of evidence before the thread is buried. ;)
I just tried to add the new material three times to the Wiki TI-BASIC page and Wiki rejected the sources each time. Now which source they rejected is unclear. So, for now, I have just removed the references already in the article about the origins of TI-BASIC so at least the article isn't giving bad information.
I work with Wiki to get the full update as soon as I can figure it out.
Wiki didn't like my article. but they did let me take down all the info about the origins of TI BASIC.
That is why I don't contribute to wikipedia.  You can prove seven ways to sunday that what you have written is factually correct, if the current maintainer of the article gets their knickers in a twist, it will never see the light of day. Too many axes being honed and polished over there, not enough concern about being actually informative.
1 hour ago, RXB said:
What people say and what actually happened are not the same.
Quite correct. Our memory of an event is often different from someone else’s memory of the same event. Which is why in a trial, forensic evidence is usually more reliable than eye witness evidence.
All about CALLs in 990 TI BASIC
The CALL syntax, in 99/4A BASIC and Extended Basic, matches the syntax used in TI BASIC for the 990 minicomputer.  So TI BASIC was designed for named subprograms well before the 99/4A.
It's clear to me that the 99/4A TI BASIC and Extended BASIC were a deliberate subset of 990 TI BASIC with few differences. While reading about the CALL syntax, I also read that 990 TI BASIC used RADIX 100 (with an important feature for DECIMAL type.)
I played with 990 TI BASIC yesterday on Dave Pitt's excellent 990 simulator with DNOS. Basic is already installed. However, it is not clock-speed accurate (it runs fast) so timing BASIC benchmarks is silly. https://www.cozx.com/dpitts/ti990.html
In the TI BASIC Reference Manual, 1-Dec-83:  http://www.bitsavers.org/pdf/ti/990/basic/
Page 9-3 describes the DEF statements, which may have a return type, or be multi-line.
Page 9-5 describes the CALL/SUB/SUBEND statements.
Page 11-6 describes how to CALL assembly language routines from 990 TI BASIC, and explains the Radix 100 format of parameters.
The CALL/SUB statements, which may have variable types declared:
SUB HSTEP(REAL A, INTEGER B, REAL C)
IF A=0 THEN SUBEXIT
C = A * 2^(B/12)
SUBEND
REAL X = 220
INTEGER N = 5
REAL Y
CALL HSTEP(X, N, Y)
An optional type after SUB can set one type for all parameters.
ESUB is used instead of SUB to write subroutines that have external visibility. The ESUBs are callable from other programs.
Page 9-3 describes the DEF statements, which may have types or be multi-line:
DEF AVG(X,Y) = (X+Y)/2
DEF REAL PI = 3.1415926535
X = AVG(A,B)/PI
or
DEF XYZ(A,B,C)
XYZ = A + B + 2
FNEND
One of TI's examples of a multi-line DEF is the square root algorithm (also explained to students in TI Learning Center's DC AND BASIC ELECTRICITY textbook.)
CALL assembly
Section 11-6 describes how to add assembly language routines to 990 TI BASIC and explains the Radix 100 format.
Calling assembly routines is not like  99/4A TI BASIC:
LIBRARY "*pathname"
CALL ".ASMBLY"(A$, A, B, C)
where pathname is your assembled and linked code, for example .ASMBLY where "." is the path and ASMBLY is the file. The * indicates that the routine should persist in memory.
The first two words of the file are a BLWP vector; BASIC overwrites the workspace pointer at load time. There is one routine per file. Assembly subroutines return with RTWP.
Some important assembly libraries distributed with TI BASIC were the .SORT library and keyed file database. These accessed operating systems features (in particular the SORT facility was a system process, multitasked.)
BASIC parameters are passed to the assembly routine in a 18-word block of memory. Continuing the example:
REAL A
INTEGER B,C
WP-36 Number of parameters
WP-34 2 bits for each parameter type:
00 end of list
01 integer
10 real or decimal
11 string
WP-30 pointers ...
For the example above,
>0004
>E500  * b'11100101 00000000 codes for string, real, int, int
>0000
ptr to A$
ptr to A
ptr to B
ptr to C
>0000
Figure 11-1 goes on to unpack the variable formats in memory. In particular, it describes RADIX-100 format for REAL. Integers are 16 bits.
REALs are stored in the quite familiar 99/4A format. As we know, the mantissa bytes range from 0-99, wasting a bit per byte (1.3 bits to be pedantic). TI BASIC represents type DECIMAL by using 6 leftover bits to store the number of significant decimal places! (+13 to -13) This feature was omitted from 99/4A floating point, but I find satisfaction that the Radix 100 designer originally make good use of all the bits.
990 TI BASIC used Radix 100 format for REAL and DECIMAL, not the the-standard IBM format used on the 990 elsewhere.
Next steps
Find a way to disassemble the 990 TI BASIC interpreter!
which is why I put all the evidence we had from both sides, but they didn't like it. I got no feed back of what they didn't like but my guess is the interviews off Atariage wasn't 'authoritative enough'. but the interviews is all I have for the side that TI created TI BASIC. SO, I got them to take all the reference down of it's origin. At least that's something.
On 9/17/2019 at 1:28 PM, hloberg said:
Interview with Herman Schuurman who had a 36 years career at Texas Instruments, from November 1977 to his retirement in 2013. In March 1978 he got promoted to be Lead Programmer for the Consumer Products Group in Lubbock.
Herman's a cool guy.  I worked with him up until he retired.  Knowing TI, I wouldn't be surprised if Microsoft ended up working on a project adjacent to the one TI shipped.
I also worked with Karl Guttag.  He had indicated to me (back when we were both still at TI) that he thought Microsoft had actually done the BASIC for the Home Computer.  I wonder if he'd conflated the 99/4 with the 99/7 as Herman suggests?  Karl was on the VDP side of things (and later CPU, with the TMS9995), while Herman was right in the thick of things in Lubbock.
