Sign in to follow this
Joel D. Park
Simple Electronics Question.
I have an 11 pin connector like this, on a PCB on an Arcade Game.
(This should probably go in Arcade stuff, but I hoped for a response before I go home after work).
11| N/C
10| N/C
9 | Jump & Start
8 | Kick
7 | N/C
6 | Punch
5 | Left
4 | Right
3 | Up
2 | Down
1 | GND
To activate any one of the switches, all I should have to do is connect them to the Ground?? Is that correct?? For example, if I want to press the Kick button, all I would do is connect pin 8 to pin 1 and it would be just like pressing kick??
I'm pretty much positive that that is correct.
11| N/C
10| N/C
9 | Jump & Start
8 | Kick
7 | N/C
6 | Punch
5 | Left
4 | Right
3 | Up
2 | Down
1 | GND
That is correct.
That is the standard way I have seen it done. You can also find them with a diode in line paralell with the switch. I have taken them out before and not ever had a problem, but someone put them in there for a reason.
Just thought I would mention it if you saw them there (Asteroids cocktails have them that way, wierd)
Cassidy
What I have is a Pit-Fighter pcb, the start button is part of the Thrid player's controls. My Jamma cabinet only supports player 1 and 2, I was hoping that I could just build a single button into this socket for starting the game but it doesn't seem to work.
I tried the cross over but it didn't seem to press the button, do the buttons need power or something coming into them as well??
I may have just not got a good connection.
