Mr Robot Posted August 31, 2019 Share Posted August 31, 2019 I used the U1MB from my NTSC 800XL when I made my 1088XEL and now I can't use my XL any more. I got it from Sloopy with the U1MB already installed and I never got the replaced chips. If anyone has spares they'd be willing to part with, please let me know, I'd love to get the machine working again. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted August 31, 2019 Share Posted August 31, 2019 I think I have some. pm me. paul Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 1, 2019 Share Posted September 1, 2019 I have GAL16V8's that I can program to become XL MMU's if needed. 3 Quote Link to comment Share on other sites More sharing options...
Marius Posted September 1, 2019 Share Posted September 1, 2019 I can confirm what Nezgar wrote. A GAL can be programmed to become a 100% compatible XL MMU. I have done it too in the past. Works excellent in one my 800XL's. 3 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 2, 2019 Share Posted September 2, 2019 On 8/31/2019 at 8:29 PM, Nezgar said: I have GAL16V8's that I can program to become XL MMU's if needed. A PAL16L8 works as well. (It is the original part). Not that it matters, a GAL is just fine to use. 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 2, 2019 Share Posted September 2, 2019 On 9/1/2019 at 1:29 AM, Nezgar said: I have GAL16V8's that I can program to become XL MMU's if needed. can this be done in HxD? if so, should IC type be selected as 20 pin DIP? and how easy is it to extract the IC information from a good MMU? Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 2, 2019 Share Posted September 2, 2019 47 minutes ago, brenski said: can this be done in HxD? if so, should IC type be selected as 20 pin DIP? and how easy is it to extract the IC information from a good MMU? I don't believe an MMU can be "extracted" - it basically had to be reverse engineered so that when programmed into a PAL or GAL, it would produce the same effect as the original. The venerable TL866 supports this GAL with the available JEDEC files. The original XL/XE is credited to @bob1200xl in 1999, and the XEGS one @tf_hh posted earlier this year does not internally credit an author. The source files are actually just text files you can view with notepad, etc. Here's my sources: XL/XE: https://atariage.com/forums/topic/155863-mmu-chip-needed/?do=findComment&comment=1911484 XEGS: https://atariage.com/forums/topic/290832-atari-xe-game-system-help-with-keyboard-issue-not-the-mylar/?do=findComment&comment=4271375 So really, all that's missing is the original 1200XL MMU, but who would want that! ? 1 Quote Link to comment Share on other sites More sharing options...
