--- Ω ---
Whatever happened to that mini flat 32K expansion?
A while back someone was selling a teeny tiny flat 32K only memory expansion.  Does anyone remember who, where or for how much?
The one from Italy?
Sent from my LM-G820 using Tapatalk
Just now, arcadeshopper said:
The one from Italy?
I'm not exactly sure.  All I remember is that it was tiny and flat.  IIRC it looked like it had four flat memory chips on it as well.
Sounds like the one from Italy. It used surface mount chips and had no further expansion.
That might be it.  Do you have a link?
That RAMPACK from Hungary really interests me, but at the same time it's little scary, because I wonder if it's easy to remove without breaking it.
Was a micro 3D printer case ever made for it?
6 minutes ago, --- Ω --- said:
Any assembled?
I would have to check.  not sure where they are.  I may have assembled one. but not sure.
Sure!  Let me know, I can hold off a day or two until you find out.
i may know where they are.  If they are not there then I probably will not find them until I move next few months.  i'll let you know in a bit.
Cool thanks!
18 minutes ago, --- Ω --- said:
Cool thanks!
i found the chips but no boards.  next time I do an order (not sure when) I can order some boards.
Thanks but, I'll probably go with something (I'll see what develops) within the next two or three days.
I have this board for the internal mod. Also have one assembled but will need to be installed in a consoleab422da915f94a0264052362842cd5cb.jpg
Thanks Greg, I think for this application, I need to go with an easily removable option.  I might have considered going with another internal unit, (gave the last one away as a Secret Santa Christmas present) but I've been unable to source another suitable replacement TI console for a future upgrade expansion project.
I've never heard of a 3D case for the unit pictured below, but I'm thinking some black or silver cardstock cut down and folded properly might slide easily over the top and down the sides protecting the unit somewhat.  Using a hole punch for the light would work too.
12 minutes ago, arcadeshopper said:
Also I have the jedi32k's in stock.. for easier use..and a nice case too
Yeah, but I already have an entire 32K/TIPI sidecar setup that I don't want to use on this unit, because I may possibly give it away at a later date.  I just  need a *cheap* bare bones 32K.
