sage
avp alien hack (comlynx)
AVP Hacking
(some notes I wrote down years ago, think I might share them ...)
Using the "official" ROM from 1993.
Goal:
Find out why Alien mode is deactivated.
Activate Alien Mode in Menu. Maybe do a cheat for level select.
Help:
We know its there because someone (http://zenade.angelfire.com/AVP/lynx/avp.html) found out
how to activate it by patching into memory as well as selecting the level nr.
But this Cheat is not really telling where and how to patch ... 😞
We further know that it was possible to select the alien in the menu in older ROM versions.
(which I do not have available...)
Findings:
Alien Mode is in and "just" deactivated in the menu. It can be activated and the item picture in
the menu is appearing, too. There is some conditional branch before the picture is displayed. But
it is not clear yet what is this condition... My guess: COMLYNX Mode!
Comlynx? Indeed there is support for Comlynx in AvP!
Just connect a second lynx and one player can select marine while the other is predator.
But: It does not seem to work. At least not with my two Lynxes.
Add: With three Lynxes every player gets adifferent character ... means the Alien pops up in the menu as expected.
Investigating:
First, extract files from rom. We get something like 200 file entries, but a lot of them are zero entries.
File 0 is the title picture (as always).
Trivia: It is not a single sprite but four, background, alien, vs, predator are seperate sprites.
File 1: main code/basic fuction stays resident.
File 2,3,5,7: menu and actual game ... swapped in at the same address as needed.
File 2 contains Intro?
File 3 contains the selection menu!
File 5 is engine.
File 7 contains the Game Over screen. Remark: switched pics???
Most of the other files are sprite data, but sometimes with some additional data (table?) in front of it.
Lets concentrate on the file 3 and look for the menu selection part. And there it is...
        LDX $06
        LDA #$00
L2E22:
        ORA $0A,X
        DEX
        BPL L2E22
        BIT #$03
        BNE L2E6B
        BIT #$10 ; Left/Right
        BEQ L2E46
        LDA L2E7A ; CURRENT SELECTION
        DEC
        CPX #$02  ; And this is crazy... because x is always -1 here!!
        BPL L2E3B ; And this is crazy... if this should be cmp this makes more sence... but limits
        AND #$01  ; And this is crazy... the value to 0 and 1 for the selected character
        BRA L2E41 ; And this is crazy...
L2E3B:
        CMP #$00
        BPL L2E41
        LDA #$02
L2E41:
        STA L2E7A ; Store selection
        BRA L2E5F
L2E46:
        BIT #$20 ; Left/Right
        BEQ L2E5F
        LDA L2E7A
        INC
        CMP #$02  ; And this is crazy, too ... must be CPX as above??
        BPL L2E56 ; And this is crazy, too ... doesnt make sence
        AND #$01  ; And this is crazy, too ...
        BRA L2E5C ; And this is crazy, too ...
L2E56:
        CMP #$02
        BMI L2E5C
        LDA #$00
L2E5C:
L2E5F:
        LDA L2E7B ; Animation of Frame or similar?
        INC
        AND #$03
        STA L2E7B
        JMP L2DBF
        ; The following is interesting, too
L2E6B:
        LDX $07
        LDA L2E7A
        STA $10,X
        STA $AD
        JSR $058e
        JMP $1822
        ; And if we check a bit of code before, we find the following
        ; This is run when we first enter the menu...
        LDX $07
        TXA
        STA $10,X
        STA L2E7A
What do we learn from this?
a) there is a bug in the avp code ;-)
b) selection can be 0,1,2 BUT ther is this CPX on something which limits this to 0 and 1 (alien is 2!)
c) on start this value is read from $07
Some very nice piece of code is:
   LDX L2E7A
   LDY #$07
   LDA L2D88,X
   STA ($AB),Y
   LDY #$09
   LDA L2D8B,X
   STA ($AB),Y
   LDA $AB
   LDX $AC
   JSR $056e
this code is plotting the selection frame ... based on a three entry look-up table. three characters!
We learn: L056E is plotting a sprite! looking where it is used will find an additional piece of code
which draws one sprite only under a condition:
   LDA $06
   CMP #$02
   BMI L2DE4
   LDA #$b0
   LDX #$52
   JSR $056e
L2DE4:
What sprite is it? yes, the alien head for the menu. (not shown: right above that was the plotting of marine and predator)
What do we learn?
Based on the value of $06 the alien head is (not) shown in the menu.
The same value is used on some loop above the selection code to OR some values which are tested for left/right.
What does this mean, why do we want to make an OR if we have only one Lynx... and why is all this keypad reading and
storing (not shown at all) done so terribly complicated... based on some indizes... could it mean...yes indeed!!!
Checking the main code result in a lot of SERDAT occurances... means: COMLYNX code!!!!
=> a short check with two Lynxes, yes we have comlynx support.
And the complicated code for selection "just" synchronizes the selection between two(?) Lynxes.
Edited by sage
