a8isa1 Posted September 8, 2019 Share Posted September 8, 2019 (edited) I'm enjoying SDrive-MAX very much (as much as I did for classic SDrive). I've used most features SDrive-MAX has to offer but I have no idea how to use the Turbo feature of tape emulation. I assume Turbo means Turbo 2000 but I don't know if that's correct and I don't know the procedure of using these tapes. We didn't see them in North America, AFAIK. I don't know what format data file SDrive-MAX needs or where to get the files themselves. Would someone please provide me instructions? -SteveS Edited September 8, 2019 by a8isa1 Quote Link to comment Share on other sites More sharing options...
baktra Posted September 8, 2019 Share Posted September 8, 2019 I don't believe that SDrive-MAX can emulate Turbo 2000. I believe that it's turbo feature just speeds up the data transfer of the standard tape records from 600 bps to 1000 bps. The webpage says the following: Tape emulation (from V0.6): Click on the Tape: button and select an image Now you hold down the Atari START & OPTION and start the computer After the burp has been purged, press any key, then immediately after the sdrive-max to start To abort, hold down the Start button a little longer until the next block it will automatically rewind, and it can start over If desired, a 1000 baud turbo can be activated (from V0.7) To exit, simply exit The "image" to be selected is most likely a .cas file, there are many of them available in the internet archives. No info on supported chunks, but FUJI, baud, and data will work. Not sure about fsk. SDrive-MAX doesn't connect the MOTOR CONTROL signal, so the tape emulation is just rudimentary, but should be enough for simple single-stage and multi-stage booters. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 8, 2019 Share Posted September 8, 2019 (edited) yes that is the one sadness I have about the device, no motor/audio.... can't use it for the language/learning tapes... Edited September 8, 2019 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Fred_M Posted September 8, 2019 Share Posted September 8, 2019 Cas-files don't contain the audio of a dual track tape. If you want to use these in for example Altirra you need the Wav-files of the tapes Quote Link to comment Share on other sites More sharing options...
baktra Posted September 8, 2019 Share Posted September 8, 2019 (edited) 30 minutes ago, _The Doctor__ said: yes that is the one sadness I have about the device, no motor/audio.... can't use it for the language/learning tapes... Perhaps one day, there will be device with MOTOR CTRL and audio playback. Technically, it is quite feasible, but the number of potential users is negligible. Full tape emulation (including Turbo 2000) is more complex - the device would have to be built around something else than plain USB 2 Serial converter. I believe AtariMAX is selling something close to that. Their USB version of SIO2PC supports MCTRL and direct control of the DATA IN pin. Only small step to support .cas files with pwmX chunks. Edited September 8, 2019 by baktra Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 8, 2019 Share Posted September 8, 2019 (edited) 33 minutes ago, Fred_M said: Cas-files don't contain the audio of a dual track tape. If you want to use these in for example Altirra you need the Wav-files of the tapes I don't want to emulate, I want to facilitate, one SIO box to rule them all! stating the obvious... the wish is for both to be available from the SIO device as the mp3 or orbis file could be controlled with motor pausing the audio as well as the position within the CAS file... we should all know the CAS file doesn't contain the audio as it is written everywhere... and the tape layout is noted all over the place as well. What would make your thoughts go as to anyone thinking otherwise? Edited September 8, 2019 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted September 10, 2019 Author Share Posted September 10, 2019 I was totally confused by the Turbo button and the message "Sync Wait...". Baktra, thanks for clearing that up for me. I finally did get CAS files to work (most of the time). -SteveS Quote Link to comment Share on other sites More sharing options...
