Sign in to follow this
walter_J64bit
Jag SD Cart with the BJL Modded Jag
I'll test mine out in a few minutes...
Not working here, can't say why so I'll wait until Saint chimes in.
Edited by neo_rg
Extra info
Hmm, it should work, really. I dont have a BJL ROM installed to look at it.
I got Protector SE specifically for the BJL support so that I wouldn't have to change the rom. Of course now I have a skunkboard, which has BJL support, so now I only use Protector to actually play the game. Does the JagGD have BJL support in it's boot menu? I suppose that even if it didn't, it would be super easy to run a BJL loader from SD.
I can't put coal in my warpcore either.
First world problems :P
You can upload and execute code via the usb port on the JagGD. I don't see BJL as particularly necessary?
True. And it's much faster than the BJL cable, as well as easier to get an appropriate cable. Someone with a BJL cable probably already has another way to use it, like I do. Even then, the USB is more convenient - I haven't used my BJL cable since getting my skunkboard, which I use through a USB cable.
Posted (edited)
I'd had the BJL rom Installed back when Jaguar Sector II was around there are a handful of games that don't work when using my BJL Jag but I like to use it just for giggles.
Edited by walter_J64bit
