Nukey's Pacman 8K on Flashback
dr.geek
I tried playing Nukey's Pacman 8K on my Flashback 9 via SD Card and it refuses to work (I get a black screen with some random graphics at the top of the screen and a buzzing noise) - I have read where people have been playing it on FB9...My FB9 is an Australian model. Is there a differenece between the Australian and USA models?
Also having trouble with some homebrews (HALO 2600 for example)
Edited by dr.geek
  • 1 month later...
On 9/21/2019 at 3:23 AM, Nukey Shay said:
That's Dintar816's homebrew that people mentioned.
Flashback Portable refuses to run my hack, I never discovered why (it's not doing anything special).  I gather that FB9 is the same.
If your 8K hack isn't using enough of the second bank it won't run, if this is the case you could fill some of the extra space with data so the Portable will recognize the bank.
Does this rule apply to any bank? Should any of them have use to be recognized? How many KB is this possible?
The one rule is that there are no rules.  What works in one case might not in another.  Consider playfield register updates: at the latest, these must occur at specific cycle counts.  Most of the time the portable follows spec.  Other times, the cycle count needed will deviate for no discernible reason and need a bit of trial/error to fix.  CTRLPF is a real mind bender...often when called midscanline (or even at the end of a scanline), it will affect everything that had already been drawn.  And of course, VBLANK...no rhyme or reason why it pushes the display in some programs but not in others.
Yes it generally only affects homebrews and hacks since the commercial releases usually filled the banks, interesting detection method.
Chapter 17 has the details on how to add padding to get partially used banks to be recognized, Assembly or batari BASIC programs that are similarly affected can be fixed the same way:
http://relationalframework.com/Atari_Flashback_BASIC_Manual.txt
Thank you. Finally figured out how to do it.
  • 1 month later...
For any future necrobumps...
I believe that the portable's emulator treated this game as using Superchip Ram - effectively making all the bankswitch instructions and all other program code on the lowest page of Rom unable to execute.  I already had enough free space in both banks to keep the lowest page unused, so even if it still misreads it as a Superchip program, it doesn't matter.
