Maury Markowitz #1 Posted September 19, 2019 There is an older 2012 thread on converting Atari BASIC programs to text format. At the time, it required the programs to be loaded into an emulator and then LISTed out to H Has there been: 1) any improvement in this? I would like to convert every file in the Antic Software Collection and any others one might suggest so this would be sometime time consuming 2) has someone already done this? Is there an archive of text format Atari BASIC programs out there? Quote Share this post Link to post Share on other sites
dmsc #2 Posted September 19, 2019 Hi! 37 minutes ago, Maury Markowitz said: There is an older 2012 thread on converting Atari BASIC programs to text format. At the time, it required the programs to be loaded into an emulator and then LISTed out to H Has there been: 1) any improvement in this? I would like to convert every file in the Antic Software Collection and any others one might suggest so this would be sometime time consuming I always use CHKBAS from here: https://www.atarimax.com/jindroush.atari.org/asoft.html It supports Atari BASIC, Turbo Basic (-tbs swtch), Basic XL (-bxl) and Basic XE (-bxe). 37 minutes ago, Maury Markowitz said: 2) has someone already done this? Is there an archive of text format Atari BASIC programs out there? Don't know, but there are a lot of sources over the web Have Fun! 1 Quote Share this post Link to post Share on other sites
Wrathchild #3 Posted September 20, 2019 What are we meaning by 'text format' here? Just a direct conversion of byte values, carriage return / line feed handling? 160 A=USR(ADR("hð(h…Ïh…Ωà…Í© …Ì¢ ¡Ì�ÎæÌÐ�æÍ¥ÍÉäð�æÎÐìæÏÐè` "),CHB) Displaying of graphical and inverse characters 'as-is'? (I can't recall the URL of the site which allows you to upload files and it converts to an image file, maybe jpg/png, or even a pdf) Or in a magazine/book type convention? 3100 PRINT:PRINT:PRINT" WHEN READY TO BEGIN TRANSMISSION[14 spaces][inverse] PRESS RETURN [inverse off]" For the latter, there doesn't appear to be a definitive convention for this that could, for example, be adopted by an emulator to import a text file or a separate program to convert to/from a BAS file. Quote Share this post Link to post Share on other sites
Madi #4 Posted September 20, 2019 (edited) 1 hour ago, Wrathchild said: What are we meaning by 'text format' here? Just a direct conversion of byte values, carriage return / line feed handling? 160 A=USR(ADR("hð(h…Ïh…Ωà…Í© …Ì¢ ¡Ì�ÎæÌÐ�æÍ¥ÍÉäð�æÎÐìæÏÐè` "),CHB) Displaying of graphical and inverse characters 'as-is'? (I can't recall the URL of the site which allows you to upload files and it converts to an image file, maybe jpg/png, or even a pdf) Or in a magazine/book type convention? 3100 PRINT:PRINT:PRINT" WHEN READY TO BEGIN TRANSMISSION[14 spaces][inverse] PRESS RETURN [inverse off]" For the latter, there doesn't appear to be a definitive convention for this that could, for example, be adopted by an emulator to import a text file or a separate program to convert to/from a BAS file. Use the stand alone PC utility MemoPad R26 , or use AtariGeezer's excellent PC utility ATRTools-027f madi Edit: To convert the tokenized or listed Basic file to PDF, use the attached ATASCIIView ATASCIIView.zip Edited September 20, 2019 by Madi Added ATASCIIView 3 Quote Share this post Link to post Share on other sites
Maury Markowitz #5 Posted September 20, 2019 16 hours ago, dmsc said: Hi! I always use CHKBAS from here: https://www.atarimax.com/jindroush.atari.org/asoft.html It supports Atari BASIC, Turbo Basic (-tbs swtch), Basic XL (-bxl) and Basic XE (-bxe). Fantastic, this is precisely what I need! Quote Share this post Link to post Share on other sites
Maury Markowitz #6 Posted September 23, 2019 So the code in question is so old that it will not run on any modern Windows machine. I downloaded the source, did some touchups for modern VS c++, and built a new version called ChkBase64. The name is inaccurate, it's really 32-bit as well, but it works. Is there a place I should upload the binary for other to use? Quote Share this post Link to post Share on other sites
+Roydea6 #7 Posted September 23, 2019 This thread would be appropriate for Atari related info.. Quote Share this post Link to post Share on other sites
Maury Markowitz #8 Posted September 23, 2019 2 hours ago, rdea6 said: This thread would be appropriate for Atari related info.. Uhhh, it is. This is a program that decodes Atari BASIC programs into text files. Quote Share this post Link to post Share on other sites
dmsc #9 Posted September 23, 2019 Hi! 3 hours ago, Maury Markowitz said: So the code in question is so old that it will not run on any modern Windows machine. I downloaded the source, did some touchups for modern VS c++, and built a new version called ChkBase64. The name is inaccurate, it's really 32-bit as well, but it works. Is there a place I should upload the binary for other to use? IMHO, the best is to attach the program here. Does anybody know how to contact the original author (Jindrich Kubec), for permission to release newer sources or move to github? I also have some local modifications correcting a few errors with Turbo-Basic XL sources. Have Fun! Quote Share this post Link to post Share on other sites
baktra #10 Posted September 23, 2019 (edited) 1 hour ago, dmsc said: Hi! IMHO, the best is to attach the program here. Does anybody know how to contact the original author (Jindrich Kubec), for permission to release newer sources or move to github? I also have some local modifications correcting a few errors with Turbo-Basic XL sources. Have Fun! The sources are under GPL, so if you release it under GPL at Github, you don't have to ask. AFAIK Jindrich left the scene with no intention of going back years ago. I believe his LI profile is this one: https://cz.linkedin.com/in/kubecj Not 100% sure, though. Edited September 23, 2019 by baktra Added li profile Quote Share this post Link to post Share on other sites
