sparkdrummer
BOOT WON'T BOOT
I have discovered an odd problem using BOOT with different flavors of XB like RXB and MECHATRONICS for examples.
Using RalphB's excellent FinalGrom  I have loaded up RXB and selected an Extended basic program from my my Boot menu - after doing so BOOT complains No Ex-Basic, press any key.
Same thing happens when trying the Mechatronics version. Others may as well?
Super Extended Basic works fine, as well as TI's v110.
Is BOOT looking for a specific version of XB?
I am using V 12/13/89 version of BOOT.
Are you using the original version of Mechatronics XB or are you using the II Plus version? The earlier one should respond like the normal XB (or the Exceltek or MicroPAL versions, as all were licensed copies of TI XB). You might want to try the Winkler XB3 and Tony's XB 2.7 as well. There aren't a lot of compatibility issues between older programs and different flavors of XB, but we definitely need to document them when they do show up.
Older versions of RXB have a different address that Boot goes to that was modified for RXB.
BOOT just took for granted every XB version would have ZERO CHANGES.
Instead of using the GROM header for what address to start at, BOOT screwed the pooch and just jumps to a oddball address.
It is like not expecting any changes to all XB versions and should always remain the same, also why some XB fail to boot properly.
What every program like BOOT or FW should do is look at the GROM header and use that address,
THAT IS THE REASON FOR THE HEADER IN THE FIRST PLACE!!
I would like everyone to remember way back in 1996 I proposed a standard for GROM access and everyone ignored me
at that standards meeting. Guess they should have listened to me.
Edited by RXB
Based on what I know from my work with BOOT and MENU, you cannot use the GROM header to execute the steps necessary to intercept the "DSK1.LOAD" process.  BOOT does use the header address to start the cartridge normally.  Don't conflate the two processes as they take different paths to starting XB.
A 'simple' test might be to sector edit BOOT, replacing the standard XB address with the modified RXB address.
(I won't argue the merits of expecting XB to remain the same; it is just as perilous as similar arguments about ignoring or changing the rules for DSR access, hardware conventions, etc. )
What would be the point of upgrades if everything has to remain exactly the same?
What actually could be upgraded?
As for the GROM header you have to access GROM to execute XB so that routine is already there they are just to lazy to look.
No, this is not about laziness.  There are TWO DIFFERENT processes involved. The process BOOT uses to 'trick' XB into loading a program via the "DSK1.LOAD" mechanism does NOT follow the same execution path.
I did not say everything has to remain exactly the same.  Please re-read my original post.
Here is the basic routine from MENU.  Location >63D1 is expected to contain a 'GOSUB' to >64DE. If not found, menu (or boot) tells the user there is no (compatible) XB cartridge.
       BL   @GRMCUR     Get current Grom address
       MOV  R1,R4       Save it
       LI   R1,>63D1    We want to see if at Grom >63D1 there is a GOSUB @>64DE
       BL   @GRMADR     So, set Grom Address at >63D1
       BL   @GETGRM     Read 2 bytes at Grom >63D1
       CI   R1,>648E    Is there a GOSUB @>64DE?
       JEQ  MYINT1      Yes, jump
       MOV  R4,R1       No, restore old Grom address and exit
       JMP  MYINT2
(Edit: Added cartridge address test for completeness)
XBPROG LI   R1,>6372
       C    R1,@CARTAD
       JEQ  RUNXB
Thinking about this a bit more...
Even though the menu load routine doesn't rely upon the GROM header address, Rich is right about there being a hard-coded address problem.
The GROM header startup address is hardcoded in MENU (and presumably BOOT), which in turn is used to detect the XB cartridge BEFORE the load is attempted. (This was implemented to stop users from mistakenly trying to load an XB program when the cartridge wasn't selected/inserted.)
RXB and other variants may have different and/or additional menu selections and corresponding different startup addresses.  There are a few ways to get around this.  The first would be to disable the GROM header test; if the user tries to load an XB program with the wrong cart, let the crash happen.  Another option would be to tailor BOOT to look for your chosen cartridge.
RXB 2015E (in Classic99) appears to use a startup address of 7EA3 for the first menu selection.   XB uses 6372.  If you search the BOOT program for 6372 and replace it with 7ea3, conceivably BOOT will load the XB program.
       MOV  R1,R4       Save it
       JMP  MYINT2
XBPROG LI   R1,>6372
       C    R1,@CARTAD
       JEQ  RUNXB
OK LOOK THERE IS NO GPL COMMAND AT >64D1 that is the wrong address.
This is a case of someone that does not know crap about the GPL code at all.
There is a GPL line at >64D0 i.e.
<0356> 64D0 06,80,24        CALL G8024             Is it?
But that is just >8024 so why not just go to >8024 instead of using >64D1? WTF is going on here?
You are talking to a guy that bought and owns the original XB 110 GPL source code since 1991
Also there is no command a >64DE so look at the original code for XB 110? i.e.
<0368> 64ED 44,F9           BR   G64F9
<0369> 64EF 0F,83    ILLST  XML  SCROLL            Scroll the screen for message
Again someone that has no freaking clue about GPL they just randomly picked address to use.
This is just picking bytes out of thin air not knowing what they do and expecting them to never change.
All of RXB source code has been posted since 2001 and I kept all the original Texas Instruments sections and commented them.
Nothing has been erased or is missing in RXB I just added * PATCH CODE * in the comments to show where this is done.
Here is most of the RUN command in GROM 3:
<0190> 6372 86,A3,70 TOPLEV CLR  [email protected]>0370           Initialize temp area
<0191> 6375 35,00,4D        MOVE 77,[email protected]>0370,[email protected]>0371
       6378 A3,71,A3
       637B 70
<0192>               * RXB MODULE PATCH CODE FOR RXB MODULE ********************
<0193>               *      ST   5,@KEYBD          Select full keyboard
<0194>               *      SCAN
<0195>               *      CZ   @KEYBD
<0196>               *      BR   G6388             99/4A Console?
<0197> 637C 06,7E,5C        CALL CART              * RXB PATCH CODE FOR CARTRIDE
<0198> 637F BE,A3,BB        ST   >01,[email protected]      Select 99/4A console
       6382 01
<0199> 6383 86,74    G6388  CLR  @KEYBD
<0200>               * RXB MODULE PATCH CODE FOR RXB MODULE ********************
<0201>               *      DST  NLNADD,[email protected]   Initialize edit-buffer start
<0202>               *      DST  NLNADD,[email protected]   Initialize edit-buffer end
<0203> 6385 31,00,02        MOVE 2,[email protected],@INTRIN Get address of ATNZZ
       6388 38,00,32
<0204> 638B B2,38,1F        AND  >1F,@INTRIN       Throw away the BR opcode
<0205> 638E A3,38,00        DADD >5B,@INTRIN       Address of polynomial constan
       6391 5B
<0206>               * RXB PATCH CODE *************
<0207> 6392 BE,A3,71        ST   >31,[email protected]      indicate try auto-boot
       6395 31
<0208> 6396 43,A5           BR   SZNEW
<0209>
<0210>                      AORG >03A5
<0211>               *----------------------------------------------------------
<0212>               * Add the following line for fixing "MEMORY FULL" error
<0213>               * occurring during MERGE execution will leave the file open
<0214>               * to disk DSR bug, 5/19/81
<0215> 63A5 86,A3,9E SZNEW  CLR  [email protected]          Initialize merged temporary
* Warning - Address not even in 0215
<0216>               *                              for PAB pointer
<0217>               *----------------------------------------------------------
<0218> 63A8 BE,73,88        ST   RSTK,@SUBSTK      Load base of subroutine stack
<0219> 63AB 06,69,17        CALL CHRTA2            Load character table
<0220> 63AE 86,45           CLR  @FLAG             Initialize flag byte
<0221> 63B0 87,46           DCLR @BUFLEV           Initialize crunch buffer leve
<0222> 63B2 06,80,12        CALL CLSALL            Close all open files
<0223> 63B5 86,34           CLR  @DATA             Initialize READ/DATA pointer
<0224> 63B7 BF,6E,09        DST  VRAMVS,@VSPTR     Initialize base of value stac
       63BA 58
<0225> 63BB BD,24,6E        DST  @VSPTR,@STVSPT    Save in permanent base
<0226> 63BE BD,A3,88        DST  @VSPTR,[email protected]
       63C1 6E
<0227> 63C2 06,68,C3        CALL INITPG            Initialize program & s.t.
<0228> 63C5 06,A0,18        CALL INTRND            Initialize random number
<0229> 63C8 8E,A3,71        CZ   [email protected]
<0230> 63CB 63,D3           BS   TOPL02            If need auto-boot
<0231>               * RXB PATCH CODE *************
<0232>               *      CLR  [email protected]          Won't ever need to do again
<0233> 63CD 43,D0           BR   G63D0
<0234>
<0235>               * RXB PATCH CODE ******************************************
<0236>                      AORG >03D0
<0237>
<0238> 63D0 06,64,8E G63D0  CALL AUTOLD            Attempt an auto-boot
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0015
EDIT-359
<0239>               *     Label TOPL02 is used by auto-boot in detection of err
<0240> 63D3          ERRRDY EQU  $
<0241> 63D3 06,6A,84 TOPL02 CALL G6A84             Say READY
<0242> 63D6 00              BYTE 0               *  returns to TOPL15
<0243> 63D7 06,68,C3 TOPL05 CALL INITPG            Initialize program space
<0244> 63DA 06,68,DC TOPL10 CALL KILSYM            Kill the symbol table
<0245>               * RXB PATCH CODE *************
<0246>               * TOPL15 AND  >F7,@FLAG         If error in UDF execution
<0247> 63DD 05,7E,14 TOPL15 B    MYSRCH
<0248> 63E0 BE,74,05 G63E0  ST   5,@KEYBD          Select full keyboard
<0249> 63E3 03              SCAN
<0250> 63E4 86,74           CLR  @KEYBD
<0251> 63E6 BE,73,88 TOPL20 ST   RSTK,@SUBSTK      Initialize subroutine stack
<0252> 63E9 BF,20,02 TOPL25 DST  NLNADD,@VARW      Screen addr = lower left corn
       63EC E2
<0253> 63ED 86,80,89        CLR  @RAMFLG           Clear the RAMFLG
<0254> 63F0 86,44           CLR  @PRGFLG           Make sure not in program mode
<0255>               * Check for auto-num mode
<0256> 63F2 DA,45,01        CLOG >01,@FLAG         If auto-num on
<0257> 63F5 64,1E           BS   TOPL35
<0258> 63F7 A1,14,0E        DADD @CURINC,@CURLIN   Generate new line number
<0259> 63FA D2,14,00        CGE  0,@CURLIN         >32767?
<0260> 63FD 64,05           BS   TOPL30
<0261> 63FF B2,45,FE        AND  >FE,@FLAG         If out of range->exit auto-nu
<0262> 6402 05,64,1E        B    TOPL35            Merge in below
<0263>               * Must be a long branch!!
<0264> 6405 D5,30,32 TOPL30 DCEQ @ENLN,@STLN       Line might exist
<0265> 6408 64,12           BS   G6412
<0266> 640A BD,4A,14        DST  @CURLIN,@FAC      Ready for program search
<0267> 640D 0F,7E           XML  SPEED
<0268> 640F 03              BYTE SEETWO          * Search for existence of line
<0269> 6410 65,1D           BS   EDTZ05            COND set = line found
<0270> 6412 0F,83    G6412  XML  SCROLL            Scroll to the next line
<0271> 6414 BD,5E,14        DST  @CURLIN,@ARG2     New line #
<0272> 6417 06,6F,BA        CALL DISO              Display the line number
<0273> 641A 91,20           DINC @VARW             Following by a space
<0274> 641C 44,20           BR   G6420
<0275> 641E 0F,83    TOPL35 XML  SCROLL            Scroll the screen
<0276> 6420 BE,A2,E1 G6420  ST   >9E,[email protected]    Display the prompt character
       6423 9E
<0277> 6424 06,6A,76        CALL G6A76             Read in a line
<0278> 6427 06,D0,AF        CALL SAVLIN            Save input line for recall
<0279>               *    Crunch the input line
<0280> 642A 86,22           CLR  @ERRCOD           Assume no-error return
<0281> 642C BF,0A,08        DST  CRNBUF,@RAMPTR    Initialize crunch pointer
       642F 20
<0282> 6430 0F,7F           XML  CRUNCH            CRUNCH the input line
<0283> 6432 00              BYTE 0              *  Normal crunch mode
<0284> 6433 8A,23    TOPL42 CASE @ERRCOD+1
<0285> 6435 44,45           BR   TOPL45            No error detected
<0286> 6437 49,7C           BR   ERRSYN            *SYNTAX ERROR
<0287> 6439 49,90           BR   ERRBLN            *BAD LINE NUMBER
<0288> 643B 49,94           BR   ERRLTL            *LINE TOO LONG
<0289> 643D 49,86           BR   ERRNTL            *NAME TOO LONG
<0290> 643F 49,80           BR   ERRNQS            *UNMATCHED QUOTES
<0291> 6441 49,9A           BR   ERRCIP            *COMMAND ILLEGAL IN PROGRAM
<0292> 6443 49,A4           BR   ERRIVN            *UNRECOGNIZED CHARACTER
<0293> 6445 8F,4A    TOPL45 DCZ  @FAC              Line # present
<0294> 6447 64,62           BS   TOPL55
<0295> 6449 DA,45,01        CLOG >01,@FLAG         Not AUTONUM
<0296> 644C 44,5B           BR   G645B
<0297> 644E D6,75,0D        CEQ  >0D,@RKEY         Must be up or down
<0298> 6451 64,5B           BS   G645B
<0299> 6453 D6,42,01        CEQ  >01,@CHAT         Start EDIT mode
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0016
EDIT-359
<0300> 6456 44,5B           BR   G645B
<0301> 6458 05,D0,00        B    EDTZZ0
<0302> 645B 06,66,CF G645B  CALL EDITLN            EDIT the line into the progra
<0303> 645E 63,E9           BS   TOPL25            If didn't change the line
<0304> 6460 43,DA           BR   TOPL10
<0305>               *    Jump always
<0306> 6462 D6,42,01 TOPL55 CEQ  >01,@CHAT         If blank line - ignore
<0307> 6465 63,E9           BS   TOPL25
<0308> 6467 D6,A8,20        CEQ  >EB,[email protected]
       646A EB
<0309> 646B 65,C9           BS   SZSIZE
<0310> 646D C6,A8,20        CH   >08,[email protected]      If imperative
       6470 08
<0311>               * GKXB Branch code for new commands DEL, COPY, and MOVE.
<0312> 6471 77,59           BS   NEWCMD            Go here to test for new
<0313>               *                              keywords
<0314> 6473 BF,2C,08        DST  CRNBUF+1,@PGMPTR  Anticipate usage of PGMCHR
       6476 21
<0315> 6477 0F,79           XML  PGMCHR            Prepare CHAT for OLD and SAVE
<0316> 6479 8A,A8,20        CASE [email protected]          Select the keyword
<0317> 647C 43,A5           BR   SZNEW             NEW                 0
<0318> 647E 45,20           BR   SZCONT            CONTINUE            1
<0319> 6480 45,BE           BR   SZLIST            LIST                2
<0320> 6482 45,BA           BR   SZBYE             BYE                 3
<0321> 6484 45,60           BR   SZNUM             NUMBER              4
<0322> 6486 45,B7           BR   SZOLD             OLD                 5
<0323> 6488 46,25           BR   SZRES             RESEQUENCE          6
<0324> 648A 45,AF           BR   SZSAVE            SAVE                7
<0325> 648C 45,C6           BR   SZMERG            MERGE               8
<0326>               *    AUTO-BOOT - attempt a ---->   RUN "DSK1.LOAD"
<0327> 648E 31,00,0B AUTOLD MOVE 11,[email protected],[email protected]
       6491 A8,20,63
       6494 51
<0328> 6495 BF,2C,08        DST  CRNBUF,@PGMPTR    DSK1.LOAD is in crunch buffer
       6498 20
<0329>               * RXB PATCH CODE *************
<0330>               *      BR   SZRUNL            Go to the RUN "NAME" CODE
<0331> 6499 5A,97           BR   MYRUN
<0332>               ********************************* RUN *********************
<0333> 649B D6,42,C7 SZRUN  CEQ  >C7,@CHAT         Ready for 'RUN "NAME" ----
<0334> 649E 44,BF           BR   G64BF
<0335> 64A0 BD,58,2C SZRUNL DST  @PGMPTR,@FAC14    Save pointer to name
<0336> 64A3 0F,79           XML  PGMCHR            Get the length of the string
<0337> 64A5 BC,57,42        ST   @CHAT,@FAC13      Put it in FAC13
<0338> 64A8 86,56           CLR  @FAC12            Make it a double byte
<0339> 64AA A1,2C,56        DADD @FAC12,@PGMPTR    Skip the string
<0340> 64AD 0F,79           XML  PGMCHR            To see there is line no. ahea
<0341> 64AF 06,80,24        CALL G8024             Only RUN "NAME" ?
<0342> 64B2 49,7C           BR   ERRSYN            No - junk on end so error
<0343> 64B4 BE,42,C7        ST   STRINZ,@CHAT      Prepare for LOAD routine
<0344> 64B7 BD,2C,58        DST  @FAC14,@PGMPTR    Restore the saved PGMPTR
<0345> 64BA 06,80,26        CALL OLD1              Load the program
<0346> 64BD 44,DA           BR   SZRUN0            Go ahead from here
<0347>               *                              No RUN "NAME" : just run the
<0348>               *                              current program in memory
<0349> 64BF D6,42,C9 G64BF  CEQ  >C9,@CHAT         Is there a line # after RUN?
<0350> 64C2 44,D5           BR   G64D5
<0351> 64C4 0F,79           XML  PGMCHR            Get the line number
<0352> 64C6 BC,4A,42        ST   @CHAT,@FAC        Put it in FAC for SEETWO
<0353> 64C9 0F,79           XML  PGMCHR
<0354> 64CB BC,4B,42        ST   @CHAT,@FAC1
<0355> 64CE 0F,79           XML  PGMCHR            Should be EOS now
<0357> 64D3 64,EA           BS   SZRUN2            Yes - Go ahead from here
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0017
EDIT-359
<0358>               *                              Just 'RUN'
<0359> 64D5 06,80,24 G64D5  CALL G8024             Should be EOS now
<0360> 64D8 49,7C           BR   ERRSYN            No-SYNTAX ERROR
<0361> 64DA D5,30,32 SZRUN0 DCEQ @ENLN,@STLN       Refuse without program
<0362> 64DD 64,EF           BS   ILLST
<0363> 64DF BD,A3,72        DST  @ENLN,[email protected]     Defualt to beginning
       64E2 32
<0364> 64E3 A7,A3,72        DSUB 3,[email protected]         Offset into the table
       64E6 00,03
<0365> 64E8 45,02           BR   SZRUN1            Merge in below
<0366>               *    Jump always
<0367> 64EA D5,30,32 SZRUN2 DCEQ @ENLN,@STLN       Refuse without program
<0370> 64F1 86,44           CLR  @PRGFLG           Prevent line # printing
<0371> 64F3 06,6A,82 WRNNPP CALL G6A82
<0372> 64F6 1D              BYTE 29                * NO PROGRAM PRESENT
<0373> 64F7 43,DD           BR   TOPL15
<0374>               *    Condition can never be set since line 0 is prohibited
<0375> 64F9 0F,7E    G64F9  XML  SPEED
<0376> 64FB 03              BYTE SEETWO          * Find the line in the program
<0377> 64FC 49,8C           BR   ERRLNF            * LINE NOT FOUND
<0378> 64FE BD,A3,72        DST  @EXTRAM,[email protected]   Program run starts here
       6501 2E
<0379>               * GKXB RUN code for color change.
<0380> 6502 57,74    SZRUN1 BR   RUNPAT            Change colors.
<0381> 6504 06,80,12 G6504  CALL CLSALL            Close any open files
<0382> 6507 92,44           DEC  @PRGFLG           Put it back in execution
<0383> 6509 BC,80,89        ST   @RAMTOP+1,@RAMFLG Set/reset RAMFLG flag -- when
       650C 80,85
<0384> 650E 87,A3,86        DCLR [email protected]           in program mode & ERAM exist
<0385> 6511 87,A3,8A        DCLR [email protected]           Disallow CONTINUE after RUN
<0386> 6514 06,68,DC        CALL KILSYM            Reset ERR handling to defualt
<0387> 6517 BE,73,88        ST   RSTK,@SUBSTK      Set the stack empty
<0388>               * RXB PATCH CODE ************ Turn off DSK#.LOAD search
<0389>               * SZRUN4 B    G6A70
<0390> 651A 05,7E,24 SZRUN4 B    SCHOFF            Turn off search first then G6
<0391> 651D 05,D0,0D EDTZ05 B    EDTZ00
<0392>               **************************** CONTINUE *********************
Edited by RXB
Add comments
I should add that FW fixed this issue later but BOOT or MENU never did fix this issue.
The address is 63D1, not 64d1.  BOOT checks this address for the gosub/branch to the autoload routine via 648e.(the comment is misleading). A special interrupt routine handles updating the load filename.
I'm pretty sure the person who provided the XB loader routine, Paolo Bagnaresi, knew a bit about GPL and XB.
