+Lee Stewart #351 Posted October 16, 2019 39 minutes ago, TheBF said: I think you could even define a custom SPLIT3, from the existing components and have just 1 line of text at the top for example making it 256x184 for plotting. Yes, except that the font would then be limited to 32 characters (ASCII 96..127), which would need manipulation similar to TI Basic’s offset to display whatever ASCII subset you desired. It might be possible to manipulate the Pattern Descriptor Table (PDT) to get more characters (at the expense of the already limited number of sprite patterns) if you placed the SPLIT3 text window at the bottom of the display. It still might require manipulation of the PDT. One problem is that the PDT must be on a 2-KiB boundary. If FILES were changed to 1, that would free up 518 bytes more above the Sprite Pattern Descriptor Table (SPDT) for a total of 123 character patterns starting at the bitmap-mode SPDT. I just do not remember whether the PDT can be moved to an arbitrary 2-KiB boundary or must be in the position analogous to its display position as is the case with SPLIT and SPLIT2 modes. ...lee 1 Quote Share this post Link to post Share on other sites
senior_falcon #352 Posted October 16, 2019 26 minutes ago, Asmusr said: The Missing Link (TML) is an assembly extension to XB that provides bitmap mode, but using that means you have less space for your program data, and the overall space ends up being closer to that of Cortex BASIC. Actually, you have the same 24K of room for the XB program. You do have considerably less room for the stack in the VDP which is where strings are kept and (as I remember) subprogram names. There is a section in the manual on how to conserve string space 1 2 Quote Share this post Link to post Share on other sites
+RXB #353 Posted October 16, 2019 31 minutes ago, Asmusr said: It doesn't look like Cortex BASIC has the ability to draw text at any point in bitmap mode (256x192), so drawing labels on the tick marks is not something I will attempt to do. Note that TI BASIC, XB, RXB, etc. don't support bitmap mode out-of-the-box. Bitmap mode is using 12K of the 16K video memory, leaving almost no space for program data (the disk DSR also uses some). Tursi showed how you can draw a limited bitmap-like image by redefining character patterns, but this technique is limited by the complexity of the image. The Missing Link (TML) is an assembly extension to XB that provides bitmap mode, but using that means you have less space for your program data, and the overall space ends up being closer to that of Cortex BASIC. If you use the SAMS in RXB I could move the normal BIT MAP mode to RAM into upper 24K (12K bit map mode), draw the screen in RAM and use RXB subroutine CALL MOVES to move that RAM to VDP memory. I do similar to this in RXB SAMS demos all the time, but not with Bitmap mode yet. New thing to do I guess. Of course normal location of Screen could not be used as that would overwrite all buffers but I guess I could copy them first and when done put them back. Would need to use CALL USER to do this as way to complicated to do from Programs mode, but Edit mode would work as only the file buffer is needed to keep running, all else in memory is just copied or replaced. 1 Quote Share this post Link to post Share on other sites
+RXB #354 Posted October 16, 2019 (edited) 4 hours ago, senior_falcon said: Mine is a 1997 SW2. Sadly the rust from the road salt used around here is really chewing up the steel underneath the car. It has 1 or maybe 2 years left before it shuffles off this mortal coil. Why don't you drive yours? LOL I bought a 2017 Chevy Cruz from Enterprise Car Rentals at a great price. And the SW passenger door is staved in from a car hitting me, how many 1993 SW 4 door Saturn's are there, almost none. I know of one in Portland but I only need that door. Edited October 16, 2019 by RXB Added Text. 1 Quote Share this post Link to post Share on other sites
apersson850 #355 Posted October 16, 2019 The issue with the memory consumption of the bitmap mode is of course the same when using Pascal. The p-system has two code pools on the TI 99/4A. It can run user programs from either VDP RAM or from the 24 K RAM. When using bitmap, I set a pointer which will inform the system about where the available memory starts in VDP RAM. This means that the p-system will load more code in 24 K RAM instead. Fortunately, the p-system has a very good support for segmenting programs, so you don't need all of them in memory at the same time. Thus, with some planning when designing your program, you can still run large programs, without having to handle the memory swapping yourself. It was many years ago now, but if I remember correctly, I save the character patterns as they are in VDP RAM, prior to entering bitmap mode. Then I use these patterns when the special print routine in the graphics package is called. I think I saved characters in the range 32..127, but not outside that. It's at least all normal characters. When I restore to the normal text mode again, I reload these saved characters, but set those in the ranges 0..31 and 128..255 to blank. What's left to do in my turtlegraphics unit is some variations of how to write text. Now it only supports overwrite, i.e. writing by turning pixels on, so the foreground color is used. I did plan to allow underwriting too, i.e. write with the background color, so you can create a text also in a filled field. Plus some other variations. I've also not implemented the ability to store graphics in files, for later retrieval/reload. I haven't implemented the viewport concept either. It's a concept where you can limit the impacted part of a screen to a specific box, like from 100,100 to 150,150. Any graphics sent outside this box isn't printed on the screen. Handy to make a plot window at a part of a screen, without risking plotting into other areas by mistake. 1 Quote Share this post Link to post Share on other sites
Asmusr #356 Posted October 16, 2019 39 minutes ago, senior_falcon said: Actually, you have the same 24K of room for the XB program. You do have considerably less room for the stack in the VDP which is where strings are kept and (as I remember) subprogram names. There is a section in the manual on how to conserve string space String space is what I meant by program data. I couldn't remember what exactly the VDP memory was used for. 1 Quote Share this post Link to post Share on other sites
senior_falcon #357 Posted October 16, 2019 43 minutes ago, RXB said: LOL I bought a 2017 Chevy Cruz from Enterprise Car Rentals at a great price. And the SW passenger door is staved in from a car hitting me, how many 1993 SW 4 door Saturn's are there, almost none. I know of one in Portland but I only need that door. The Cruz is a nice car with good fuel economy too. http://www.car-part.com/ With this site (or similar) you can search for your door. They seem to go in the $100-200 range. A fellow whose nom-de-net is Richpin has excellent videos on how to fix Saturn S cars. 2 Quote Share this post Link to post Share on other sites
Sid1968 #358 Posted October 16, 2019 (edited) Nice to see you both, senior_falcon and Rich, talk in a companionate manner. 🙂 Rich, did I read you right, that you can solve the challenge (including the labeling of the Axis)? Would be nice to read your progamlisting. 🤑 If i read further right, Cortex Basic can not solve the full labeling. Till now we dont know if xb256 can solve the challenge. (Is this the right name of senior_falcons version?) Edited October 16, 2019 by Sid1968 1 Quote Share this post Link to post Share on other sites
senior_falcon #359 Posted October 16, 2019 44 minutes ago, Sid1968 said: Till now we dont know if xb256 can solve the challenge. (Is this the right name of senior_falcons version?) XB256 is no better at this than any other normal XB. The Missing Link can do it because it gives a full bit mapped screen. Download The Missing Link and run the demo program. (TMLDEMO) In Graphics you will see a sin, cos, tan plot with labelling. There is no mystery in this; all the information you need is in my earlier post. 1 Quote Share this post Link to post Share on other sites
Sid1968 #360 Posted October 16, 2019 11 minutes ago, senior_falcon said: XB256 is no better at this than any other normal XB. The Missing Link can do it because it gives a full bit mapped screen. Download The Missing Link and run the demo program. (TMLDEMO) In Graphics you will see a sin, cos, tan plot with labelling. There is no mystery in this; all the information you need is in my earlier post. Thank you. Certainly i accept that you dont want to face the challenge. Quote Share this post Link to post Share on other sites
+TheBF #361 Posted October 16, 2019 3 hours ago, Sid1968 said: Thank you. Certainly i accept that you dont want to face the challenge. I would say he faced it and beat it already. 2 Quote Share this post Link to post Share on other sites
Stuart #362 Posted October 16, 2019 7 hours ago, Asmusr said: It doesn't look like Cortex BASIC has the ability to draw text at any point in bitmap mode (256x192), so drawing labels on the tick marks is not something I will attempt to do. Note that TI BASIC, XB, RXB, etc. don't support bitmap mode out-of-the-box. Bitmap mode is using 12K of the 16K video memory, leaving almost no space for program data (the disk DSR also uses some). Tursi showed how you can draw a limited bitmap-like image by redefining character patterns, but this technique is limited by the complexity of the image. The Missing Link (TML) is an assembly extension to XB that provides bitmap mode, but using that means you have less space for your program data, and the overall space ends up being closer to that of Cortex BASIC. In bitmap mode you can display text on a 32 character by 24 row grid - so easy to add labels if the tick marks happen to align with the character grid (or possibly tweak your axis scales so that they do align). If they don't align, then you could define the label text character bitmaps as stationary sprites which can be positioned with pixel accuracy. 1 Quote Share this post Link to post Share on other sites
senior_falcon #363 Posted October 17, 2019 1 hour ago, Stuart said: In bitmap mode you can display text on a 32 character by 24 row grid - so easy to add labels if the tick marks happen to align with the character grid (or possibly tweak your axis scales so that they do align). If they don't align, then you could define the label text character bitmaps as stationary sprites which can be positioned with pixel accuracy. In The Missing Link text does not have to align with the 24x32 grid. If you wanted Hello World! at r153 and c121 you would use CALL LINK("PRINT",153,121,"Hello World!) No problem getting the axes and the characters aligned. Suppose you wanted to use a 5x7 font giving a screen of 48 rows. Like Prego spaghetti sauce, "It's in there." Quote Share this post Link to post Share on other sites
Tursi #364 Posted October 17, 2019 On 10/15/2019 at 4:07 PM, TheBF said: 130 REM DOTPLOT AT DOTROW,DOTCOL (0-based) This is very cool. I need to try it this way. Thanks for taking the rest of my week away Tursi. Glad you like. I wrote that subroutine more than 30 years ago, and it's always fun to pull it out. 1 Quote Share this post Link to post Share on other sites
Tursi #365 Posted October 17, 2019 17 hours ago, apersson850 said: I'm aware that there once was a sidecar p-code card for the TI 99/4A. When I asked for a reincarnation of the p-code card, I didn't really consider whether it would be for the box or a sidecar. Today, a sidecar can be quite a bit more compact than the original one, though. I started working on finding the references that would be needed to move the data to a cartridge, which would be great. But it's complex. Quote Share this post Link to post Share on other sites
Tursi #366 Posted October 17, 2019 On 10/15/2019 at 11:12 PM, Sid1968 said: Thank you Tursi, very good. Great! Is it possible to improve it? I don't think "improve" is the right word, you changed the rules after I posted it. There you go. However, until you actually sit and run it yourself, don't ask for more. Spoiler REM PROGRAM TO DRAW SINE FROM -5 to 5 REM WITH ALL THE LABELS AND WHATEVER REM - TURSI 2019 REM CC$ - hex codes for each definable character 33-159 REM HPAT$ - lookup tables for adding nibbles in hex REM FONT$ - 3x5 bit definitions for drawing the 1-5 digits 100 REM PROGRAM START 110 DIM CC$(127),HPAT$(4),FONT$(5) 120 GOTO 440 REM ************************************************** REM DOTPLOT IS HERE BASED ON THE MYTH THAT THE EARLY REM LINES OF CODE RUN FASTER. REM SET DOTROW,DOTCOL, and GOSUB to CALL IT REM RELIES ON: REM CURCHAR - the next unused char REM STARTCHAR - the first definable character (0 in CC$) REM LASTCHAR - the last definable character (ie: when we run out of ink!) REM FIXCHAR - special to this version - below are defined chars that we aren't allowed to change REM The operation is straight-forward. It calculates the screen position, and uses GCHAR to see REM what is there. If it's a character the subroutine owns (>=FIXCHAR), this means we have already REM defined it once, so we can just redefine it. REM If it's the space character (32), we know we can allocate a new character to that location. REM If it's in our space at all (>=STARTCHAR), then we know it's fixed, otherwise we can't touch it. REM For a fixed char, we copy the definition that we have stored to a new character for modification. REM In this app, fixed chars are used for the axes. REM Finally, if it needed to allocate a new character, we check against LASTCHAR to see if we are REM out. If we are, then plots that require a new character are ignored, but old chars can still be REM redefined. REM Once we know what character to redefine, we calculate which nibble to alter, and based on which REM pixel inside that nibble we are setting, we use the HPOS lookup tables to add the new pixel to REM the old value. Then we patch the string back together, CALL CHAR it, and save the new pattern off. 130 REM DOTPLOT AT DOTROW,DOTCOL (0-based) REM Classify the character already on the screen 140 MR=INT(DOTROW/8)+1 150 MC=INT(DOTCOL/8)+1 160 CALL GCHAR(MR,MC,CH) 170 IF CH>=FIXCHAR THEN 290 180 IF CH=32 THEN 260 190 IF CH>=STARTCHAR THEN 210 REM If we get here, it was a character we can't change. 200 RETURN REM Here it is a fixed char, so copy out the pattern and assign a new character REM Give up if there are no more characters to assign 210 TC$=CC$(CH-STARTCHAR) 220 CH=CURCHAR 230 CURCHAR=CURCHAR+1 240 IF CURCHAR>=LASTCHAR THEN 200 250 GOTO 300 REM Here we're allocating a new empty char to replace a space character. REM Again, give up if there are no more characters to assign 260 CH=CURCHAR 270 CURCHAR=CURCHAR+1 280 IF CURCHAR>=LASTCHAR THEN 200 290 TC$=CC$(CH-STARTCHAR) REM Determine the internal row and column. We don't have masking, but this works REM Once we have that, we can determine which position in the string to change 300 XR=DOTROW-(MR-1)*8 310 XC=DOTCOL-(MC-1)*8 320 P=XR*2+1 330 IF XC<4 THEN 360 340 P=P+1 350 XC=XC-4 REM Now we extract the character from the working string, then use it and the REM pixel offset to lookup the new character. Then, insert it back into the string. 360 X$=SEG$(TC$,P,1) 370 TT$=SEG$(HPAT$(XC),POS(HEX$,X$,1),1) 380 TC$=SEG$(TC$,1,P-1)&TT$&SEG$(TC$,P+1,16-P) REM pretty much done! Assign the pattern, save it in our lookup table, REM plot it to the screen, and return to caller! 390 CALL CHAR(CH,TC$) 400 CC$(CH-STARTCHAR)=TC$ 410 CALL HCHAR(MR,MC,CH) 420 RETURN REM ************************************************** REM this block prepares the plot function. REM It resets the pattern lookup table to all blanks, REM sets the CURCHAR,STARTCHAR and LASTCHAR (we use REM ALL definable characters except space). Finally, REM We set the lookup tables for hexadecimal conversion REM and math. 430 REM INIT THE DOT PLOT 440 FOR A=0 TO 127 450 CC$(A)="0000000000000000" 460 NEXT A 470 CURCHAR=33 480 STARTCHAR=33 490 LASTCHAR=159 500 HEX$="0123456789ABCDEF" 510 HPAT$(0)="89ABCDEF89ABCDEF" 520 HPAT$(1)="45674567CDEFCDEF" 530 HPAT$(2)="23236767ABABEFEF" 540 HPAT$(3)="1133557799BBDDFF" REM Now we set the colors of all the color sets to black on grey REM and clear the screen to get started 550 FOR A=1 TO 16 560 CALL COLOR(A,2,15) 570 NEXT A 580 CALL CLEAR REM ************************************************** REM We were tasked to draw labelled X and Y axes. So first REM we define normal chars for drawing them. We manually REM allocate a couple by changing CURCHAR, and we reserve REM the first two (vertical and horizontal lines) by setting REM FIXCHAR. This lets the plot function copy our definition REM when drawing near the lines without changing the character REM pattern, which would change all of them. Note that the REM cross in the middle is not a fixed char, since there is REM only one of them, I don't care if the plot function updates it. 590 REM DRAW THE AXES 600 CURCHAR=36 610 FIXCHAR=35 620 CC$(0)="00000000000000FF" 630 CC$(1)="8080808080808080" 640 CC$(2)="80808080808080FF" 650 CALL CHAR(33,CC$(0)) 660 CALL CHAR(34,CC$(1)) 670 CALL CHAR(35,CC$(2)) 680 CALL HCHAR(12,1,33,32) 690 CALL VCHAR(1,17,34,24) 700 CALL HCHAR(12,17,35) REM Now we're going to start plotting pixels. I set the screen border REM to blue to show we're working, then gosub to the block which draws REM the tick marks and the numbers. It's a subroutine mostly cause REM it was added later. 710 CALL SCREEN(5) 720 GOSUB 870 REM ************************************************** REM now we draw the actual plot. The positioning and the REM numbers are based on the fact that the ticks on the REM X axis are indented from the edges of the screen a REM bit (in order to fit the labels), so we only need to REM plot 250 pixels, rather than 256. This also lets us REM stay in integer counting land, with the ticks 25 REM pixels apart. REM Otherwise, the code is simple enough. We calculate a REM step (ST) and use that to step the floating point REM value of X (VALX). Then we just directly load the DOTCOL, REM and calculate the DOTROW. It's inverted because negative REM is up in mathland, the scale is 19 because that is the size REM of ticks on the Y axis, and the offset is 95.5 for two reasons: REM It's 95 because that is where I placed my origin, and .5 to REM give free rounding up when we convert it back to an integer. REM The DOTPLOT function can not deal with fractions so it REM must always be fed integers. 730 REM PLOT FROM -5 to +5 SIN(X) 740 FIRST=-5 750 LAST=5 760 ST=(LAST-FIRST)/250 770 VALX=FIRST 780 FOR X=3 TO 253 790 DOTCOL=X 800 DOTROW=INT(-SIN(VALX)*19+95.5) 810 GOSUB 140 820 VALX=VALX+ST 830 NEXT X REM ************************************************** REM Now we're done. Change the border to grey to indicate REM completion and then loop forever. 840 REM SIT FOREVER 850 CALL SCREEN(15) 860 GOTO 860 REM ************************************************** REM the axes are ticked and labelled here. The code is REM essentially duplicated for Y, then X, because it was REM quicker to code that way. ;) REM first we read in the font data for chars 1-5. The REM chars are defined as strings with '1' meaning draw REM a pixel, and anything else meaning don't. The data REM is arranged as 5 rows of 3 pixels, one string REM per character. 870 REM LABEL THE AXES 880 FOR X=1 TO 5 890 READ FONT$(X) 900 NEXT X REM Here we count down the Y axis, from -4 to +4 REM calculating that 192 could give us 10 steps REM with 2 to spare with a step of 19, I went for REM that, drawing only -4 to +4. L tracks this. REM the outer Y loop covers the whole shebang, REM providing the starting row for each tick. REM this first X loop draws 5 pixels for the tick itself, REM right across the axis 910 L=-4 920 FOR Y=19 TO 189 STEP 19 930 FOR X=126 TO 130 940 DOTROW=Y 950 DOTCOL=X 960 GOSUB 140 970 NEXT X REM next, we use the L counter to determine which character REM to draw, incrementing it afterwards. If we reach '1' REM (indicating that we were at 0), we skip the character draw 980 FS$=FONT$(ABS(L)) 990 L=L+1 1000 IF L=1 THEN 1170 REM otherwise, we will plot the character. A is used to REM count our way through the font pixel data. The Y2 REM loop counts through the rows, and the X loop counts REM through the columns. Then all we do is check the REM definition string. If it's not "1" we skip it, otherwise REM we load up the position and plot the dot. 1010 A=0 1020 FOR Y2=0 TO 4 1030 FOR X=0 TO 2 1040 A=A+1 1050 IF SEG$(FS$,A,1)<>"1" THEN 1090 1060 DOTROW=Y-2+Y2 1070 DOTCOL=122+X 1080 GOSUB 140 1090 NEXT X 1100 NEXT Y2 REM the next block plots the minus sign, so if L is greater REM than zero, we can skip it. Otherwise, we use the X loop REM to plot two pixels to the left of the digit. 1110 IF L>0 THEN 1170 1120 FOR X=0 TO 1 1130 DOTROW=Y 1140 DOTCOL=119+X 1150 GOSUB 140 1160 NEXT X 1170 NEXT Y REM this is for the X axis, the same as the Y. The step REM on the X axis is 25, and we push it in just a bit so REM that we have room for -5 and +5 as well. 1180 L=-5 1190 FOR X=3 TO 253 STEP 25 1200 FOR Y=93 TO 97 1210 DOTROW=Y 1220 DOTCOL=X 1230 GOSUB 140 1240 NEXT Y 1250 FS$=FONT$(ABS(L)) 1260 L=L+1 1270 IF L=1 THEN 1440 1280 A=0 1290 FOR Y=0 TO 4 1300 FOR X2=0 TO 2 1310 A=A+1 1320 IF SEG$(FS$,A,1)<>"1" THEN 1360 1330 DOTROW=99+Y 1340 DOTCOL=X+X2 1350 GOSUB 140 1360 NEXT X2 1370 NEXT Y 1380 IF L>0 THEN 1440 1390 FOR X2=0 TO 1 1400 DOTROW=101 1410 DOTCOL=X-3+X2 1420 GOSUB 140 1430 NEXT X2 1440 NEXT X 1450 RETURN REM ************************************************** REM and here are the font definitions themselves 1460 REM FONT 3x5, 1,2,3,4,5 1470 DATA "010110010010111","111001111100111" 1480 DATA "110001010001110","100101111001001","111100110001110" I've documented this one a little further, but most of the comments are NOT in the code. I'm not sure there's enough RAM left for them... might be. Anyway... 6 1 Quote Share this post Link to post Share on other sites
Sid1968 #367 Posted October 17, 2019 10 hours ago, TheBF said: I would say he faced it and beat it already. I cant see his listing, thats one part of the challenge! Quote Share this post Link to post Share on other sites
Sid1968 #368 Posted October 17, 2019 (edited) 10 hours ago, Stuart said: In bitmap mode you can display text on a 32 character by 24 row grid - so easy to add labels if the tick marks happen to align with the character grid (or possibly tweak your axis scales so that they do align). If they don't align, then you could define the label text character bitmaps as stationary sprites which can be positioned with pixel accuracy. Stuart that are good news. Why do yourself not face the challenge and show us what Cortex Basic can perform? So far as i can see the labeling of the axis is a more or less hudge problem in some dialects/languages. 🙂 Edited October 17, 2019 by Sid1968 Quote Share this post Link to post Share on other sites
Sid1968 #369 Posted October 17, 2019 (edited) 2 hours ago, Tursi said: I don't think "improve" is the right word, you changed the rules after I posted it. There you go. However, until you actually sit and run it yourself, don't ask for more. Reveal hidden contents REM PROGRAM TO DRAW SINE FROM -5 to 5 REM WITH ALL THE LABELS AND WHATEVER REM - TURSI 2019 REM CC$ - hex codes for each definable character 33-159 REM HPAT$ - lookup tables for adding nibbles in hex REM FONT$ - 3x5 bit definitions for drawing the 1-5 digits 100 REM PROGRAM START 110 DIM CC$(127),HPAT$(4),FONT$(5) 120 GOTO 440 REM ************************************************** REM DOTPLOT IS HERE BASED ON THE MYTH THAT THE EARLY REM LINES OF CODE RUN FASTER. REM SET DOTROW,DOTCOL, and GOSUB to CALL IT REM RELIES ON: REM CURCHAR - the next unused char REM STARTCHAR - the first definable character (0 in CC$) REM LASTCHAR - the last definable character (ie: when we run out of ink!) REM FIXCHAR - special to this version - below are defined chars that we aren't allowed to change REM The operation is straight-forward. It calculates the screen position, and uses GCHAR to see REM what is there. If it's a character the subroutine owns (>=FIXCHAR), this means we have already REM defined it once, so we can just redefine it. REM If it's the space character (32), we know we can allocate a new character to that location. REM If it's in our space at all (>=STARTCHAR), then we know it's fixed, otherwise we can't touch it. REM For a fixed char, we copy the definition that we have stored to a new character for modification. REM In this app, fixed chars are used for the axes. REM Finally, if it needed to allocate a new character, we check against LASTCHAR to see if we are REM out. If we are, then plots that require a new character are ignored, but old chars can still be REM redefined. REM Once we know what character to redefine, we calculate which nibble to alter, and based on which REM pixel inside that nibble we are setting, we use the HPOS lookup tables to add the new pixel to REM the old value. Then we patch the string back together, CALL CHAR it, and save the new pattern off. 130 REM DOTPLOT AT DOTROW,DOTCOL (0-based) REM Classify the character already on the screen 140 MR=INT(DOTROW/8)+1 150 MC=INT(DOTCOL/8)+1 160 CALL GCHAR(MR,MC,CH) 170 IF CH>=FIXCHAR THEN 290 180 IF CH=32 THEN 260 190 IF CH>=STARTCHAR THEN 210 REM If we get here, it was a character we can't change. 200 RETURN REM Here it is a fixed char, so copy out the pattern and assign a new character REM Give up if there are no more characters to assign 210 TC$=CC$(CH-STARTCHAR) 220 CH=CURCHAR 230 CURCHAR=CURCHAR+1 240 IF CURCHAR>=LASTCHAR THEN 200 250 GOTO 300 REM Here we're allocating a new empty char to replace a space character. REM Again, give up if there are no more characters to assign 260 CH=CURCHAR 270 CURCHAR=CURCHAR+1 280 IF CURCHAR>=LASTCHAR THEN 200 290 TC$=CC$(CH-STARTCHAR) REM Determine the internal row and column. We don't have masking, but this works REM Once we have that, we can determine which position in the string to change 300 XR=DOTROW-(MR-1)*8 310 XC=DOTCOL-(MC-1)*8 320 P=XR*2+1 330 IF XC<4 THEN 360 340 P=P+1 350 XC=XC-4 REM Now we extract the character from the working string, then use it and the REM pixel offset to lookup the new character. Then, insert it back into the string. 360 X$=SEG$(TC$,P,1) 370 TT$=SEG$(HPAT$(XC),POS(HEX$,X$,1),1) 380 TC$=SEG$(TC$,1,P-1)&TT$&SEG$(TC$,P+1,16-P) REM pretty much done! Assign the pattern, save it in our lookup table, REM plot it to the screen, and return to caller! 390 CALL CHAR(CH,TC$) 400 CC$(CH-STARTCHAR)=TC$ 410 CALL HCHAR(MR,MC,CH) 420 RETURN REM ************************************************** REM this block prepares the plot function. REM It resets the pattern lookup table to all blanks, REM sets the CURCHAR,STARTCHAR and LASTCHAR (we use REM ALL definable characters except space). Finally, REM We set the lookup tables for hexadecimal conversion REM and math. 430 REM INIT THE DOT PLOT 440 FOR A=0 TO 127 450 CC$(A)="0000000000000000" 460 NEXT A 470 CURCHAR=33 480 STARTCHAR=33 490 LASTCHAR=159 500 HEX$="0123456789ABCDEF" 510 HPAT$(0)="89ABCDEF89ABCDEF" 520 HPAT$(1)="45674567CDEFCDEF" 530 HPAT$(2)="23236767ABABEFEF" 540 HPAT$(3)="1133557799BBDDFF" REM Now we set the colors of all the color sets to black on grey REM and clear the screen to get started 550 FOR A=1 TO 16 560 CALL COLOR(A,2,15) 570 NEXT A 580 CALL CLEAR REM ************************************************** REM We were tasked to draw labelled X and Y axes. So first REM we define normal chars for drawing them. We manually REM allocate a couple by changing CURCHAR, and we reserve REM the first two (vertical and horizontal lines) by setting REM FIXCHAR. This lets the plot function copy our definition REM when drawing near the lines without changing the character REM pattern, which would change all of them. Note that the REM cross in the middle is not a fixed char, since there is REM only one of them, I don't care if the plot function updates it. 590 REM DRAW THE AXES 600 CURCHAR=36 610 FIXCHAR=35 620 CC$(0)="00000000000000FF" 630 CC$(1)="8080808080808080" 640 CC$(2)="80808080808080FF" 650 CALL CHAR(33,CC$(0)) 660 CALL CHAR(34,CC$(1)) 670 CALL CHAR(35,CC$(2)) 680 CALL HCHAR(12,1,33,32) 690 CALL VCHAR(1,17,34,24) 700 CALL HCHAR(12,17,35) REM Now we're going to start plotting pixels. I set the screen border REM to blue to show we're working, then gosub to the block which draws REM the tick marks and the numbers. It's a subroutine mostly cause REM it was added later. 710 CALL SCREEN(5) 720 GOSUB 870 REM ************************************************** REM now we draw the actual plot. The positioning and the REM numbers are based on the fact that the ticks on the REM X axis are indented from the edges of the screen a REM bit (in order to fit the labels), so we only need to REM plot 250 pixels, rather than 256. This also lets us REM stay in integer counting land, with the ticks 25 REM pixels apart. REM Otherwise, the code is simple enough. We calculate a REM step (ST) and use that to step the floating point REM value of X (VALX). Then we just directly load the DOTCOL, REM and calculate the DOTROW. It's inverted because negative REM is up in mathland, the scale is 19 because that is the size REM of ticks on the Y axis, and the offset is 95.5 for two reasons: REM It's 95 because that is where I placed my origin, and .5 to REM give free rounding up when we convert it back to an integer. REM The DOTPLOT function can not deal with fractions so it REM must always be fed integers. 730 REM PLOT FROM -5 to +5 SIN(X) 740 FIRST=-5 750 LAST=5 760 ST=(LAST-FIRST)/250 770 VALX=FIRST 780 FOR X=3 TO 253 790 DOTCOL=X 800 DOTROW=INT(-SIN(VALX)*19+95.5) 810 GOSUB 140 820 VALX=VALX+ST 830 NEXT X REM ************************************************** REM Now we're done. Change the border to grey to indicate REM completion and then loop forever. 840 REM SIT FOREVER 850 CALL SCREEN(15) 860 GOTO 860 REM ************************************************** REM the axes are ticked and labelled here. The code is REM essentially duplicated for Y, then X, because it was REM quicker to code that way. ;) REM first we read in the font data for chars 1-5. The REM chars are defined as strings with '1' meaning draw REM a pixel, and anything else meaning don't. The data REM is arranged as 5 rows of 3 pixels, one string REM per character. 870 REM LABEL THE AXES 880 FOR X=1 TO 5 890 READ FONT$(X) 900 NEXT X REM Here we count down the Y axis, from -4 to +4 REM calculating that 192 could give us 10 steps REM with 2 to spare with a step of 19, I went for REM that, drawing only -4 to +4. L tracks this. REM the outer Y loop covers the whole shebang, REM providing the starting row for each tick. REM this first X loop draws 5 pixels for the tick itself, REM right across the axis 910 L=-4 920 FOR Y=19 TO 189 STEP 19 930 FOR X=126 TO 130 940 DOTROW=Y 950 DOTCOL=X 960 GOSUB 140 970 NEXT X REM next, we use the L counter to determine which character REM to draw, incrementing it afterwards. If we reach '1' REM (indicating that we were at 0), we skip the character draw 980 FS$=FONT$(ABS(L)) 990 L=L+1 1000 IF L=1 THEN 1170 REM otherwise, we will plot the character. A is used to REM count our way through the font pixel data. The Y2 REM loop counts through the rows, and the X loop counts REM through the columns. Then all we do is check the REM definition string. If it's not "1" we skip it, otherwise REM we load up the position and plot the dot. 1010 A=0 1020 FOR Y2=0 TO 4 1030 FOR X=0 TO 2 1040 A=A+1 1050 IF SEG$(FS$,A,1)<>"1" THEN 1090 1060 DOTROW=Y-2+Y2 1070 DOTCOL=122+X 1080 GOSUB 140 1090 NEXT X 1100 NEXT Y2 REM the next block plots the minus sign, so if L is greater REM than zero, we can skip it. Otherwise, we use the X loop REM to plot two pixels to the left of the digit. 1110 IF L>0 THEN 1170 1120 FOR X=0 TO 1 1130 DOTROW=Y 1140 DOTCOL=119+X 1150 GOSUB 140 1160 NEXT X 1170 NEXT Y REM this is for the X axis, the same as the Y. The step REM on the X axis is 25, and we push it in just a bit so REM that we have room for -5 and +5 as well. 1180 L=-5 1190 FOR X=3 TO 253 STEP 25 1200 FOR Y=93 TO 97 1210 DOTROW=Y 1220 DOTCOL=X 1230 GOSUB 140 1240 NEXT Y 1250 FS$=FONT$(ABS(L)) 1260 L=L+1 1270 IF L=1 THEN 1440 1280 A=0 1290 FOR Y=0 TO 4 1300 FOR X2=0 TO 2 1310 A=A+1 1320 IF SEG$(FS$,A,1)<>"1" THEN 1360 1330 DOTROW=99+Y 1340 DOTCOL=X+X2 1350 GOSUB 140 1360 NEXT X2 1370 NEXT Y 1380 IF L>0 THEN 1440 1390 FOR X2=0 TO 1 1400 DOTROW=101 1410 DOTCOL=X-3+X2 1420 GOSUB 140 1430 NEXT X2 1440 NEXT X 1450 RETURN REM ************************************************** REM and here are the font definitions themselves 1460 REM FONT 3x5, 1,2,3,4,5 1470 DATA "010110010010111","111001111100111" 1480 DATA "110001010001110","100101111001001","111100110001110" I've documented this one a little further, but most of the comments are NOT in the code. I'm not sure there's enough RAM left for them... might be. Anyway... Tursi i dont have to ask for more... ahhh not at least the next challenge comes. 😉 My verdict of your work.... Perfect, i bow to you! Thank you very much! 🤑 I like most that you descibed in the comments what you are doing. This is what this thread is about... LEARNING from each other and SEEING where a dialect/language could need some improvements. Cheers Sid Edited October 17, 2019 by Sid1968 1 Quote Share this post Link to post Share on other sites
apersson850 #370 Posted October 17, 2019 He told you were to find a listing. Don't expect everybody else to do all the work for you. 1 1 Quote Share this post Link to post Share on other sites
Sid1968 #371 Posted October 17, 2019 Just now, apersson850 said: He told you were to find a listing. Don't expect everybody else to do all the work for you. Sorry man, the rules of this challenge are clear. Nobody must face it. Like the others too, listings have to give in this thread. Quote Share this post Link to post Share on other sites
apersson850 #372 Posted October 17, 2019 3 hours ago, Tursi said: I started working on finding the references that would be needed to move the data to a cartridge, which would be great. But it's complex. Indeed it is. And it's not any easier when you consider that there's an assembly code repositiory in GROM, code which should be transferred to RAM, and run there, and have the correct references to the p-code card when needed. 1 Quote Share this post Link to post Share on other sites
apersson850 #373 Posted October 17, 2019 1 minute ago, Sid1968 said: Sorry man, the rules of this challenge are clear. Nobody must face it. Like the others too, listings have to give in this thread. Sorry man, but this is a forum. You don't set the rules. If you want to make challenges, fine. If somebody solves them in a different way than you thought, face it. 1 1 Quote Share this post Link to post Share on other sites
Sid1968 #374 Posted October 17, 2019 (edited) I have to face nothing. If someone wants to face the challenge fine. If not its OK. I dont understand your whining and will not answer any more of those "posts" from you. Edited October 17, 2019 by Sid1968 Quote Share this post Link to post Share on other sites
apersson850 #375 Posted October 17, 2019 That's one part of the challenge in a forum. Not everybody dances to your tune. The major whining you've done yourself here. But never mind, back to the regular program in this thread. 2 Quote Share this post Link to post Share on other sites
