Sign in to follow this
Porkchops & Applesauce
SIO issues: Cannot use peripherals
can you show us a picture of your power supply? Can you check voltage under load... lastly do you see distortion / noise in the video or audio?
28 minutes ago, _The Doctor__ said:
clean and work the drive selector switches
Thanks again!  I already did a thorough cleaning on the regular 810, blasting the selector switches with contact cleaner.  Next, I'll do the Happy drive, and keep everyone posted on what happens.  Cheers friend!
2 hours ago, Porkchops & Applesauce said:
What's this magic you speak of?
I went through this for my 800XL, which looks like it has the same PCB version/layout as yours: https://atariage.com/forums/topic/290397-atari-sio-transmission-oscillogram/?do=findComment&comment=4262610
In short, desolder (or just cut out) C77 and C78. With various software and patches, this will allow faster SIO data rates when using an SIO2PC-USB, SIO2SD, etc. Optionally adding a 4k7 pullup resistor as pictured will allow the fastest speeds:
If your 810's are earlier production units that still have the older combined power/analog function, they may have their own issues. A very high number of them failed very prematurely, and if they survived were not reliable. The "Grass Valley" set of upgrades included a new sideboard, ROM, data separator, and separate power & analog boards. (pretty much everything but the mech lol). If you look inside from the front of the drive and see a PCB mounted above the mech, that is a good sign some or all of those upgrades are present in that 810...
There is more than one way to enjoy a cassette....
and depending on what it is you are loading, you have to pick the correct method to get it Running
A. holding the START key on power up
B. CLOAD                       loads programs saved with CSAVE
C. LOAD "C:"                  loads programs saved with SAVE "C:"
D. ENTER "C:"                 loads programs saved with LIST "C:"
E. RUN "C:"                    loads and runs programs saved with SAVE "C:"
Maybe more or other because of loader and speeder and such.... some require user input..
Remember folks, he can’t print to a 1025, no boot error on power on with a disk drive.  So I’m thinking the PIA command line, or pokey data out.  I can’t remember if the 5v line has to active too.
Sure thing!
Steady 5.11VDC from all three + pins to motherboard ground while on.
Hmmm... Audio from self test sounds crisp and clean.  For video, that's tough for me to answer.  I haven't seen this computer on in 20+ years, and have been using a 4K laptop monitor daily for the past two years.  Everything else looks distorted and noisy to me.  :) However, I've attached my best pic without the moire effect I could get so you can tell me what you think?
Cheers friend!
@Nezgar
Thanks for the clarification and link.  Cool!  I'll keep this in mind once I get this thing back up and running properly.  Also, I do plan to get a SIO2PC-USB as I currently have no means to transfer files to/from my PC and Atari.  I have a disk set, Lightspeed C, that I want backed up since I've not seen it anywhere on the webs.  Cheers friend!
Edited by Porkchops & Applesauce
Wrong reference.
4 hours ago, Mathy said:
CLOADing a commercially purchased cassette?
Well I don't know, man.  Trying to relearn all this stuff, ya know.
Thanks, super helpful!
Cheers friends!
Thanks!  Yes, that seems to be the consensus, PIA and/or POKEY.  I found a source, Best Electronics that seem to have both at a comparably reasonable price. They're local too so hopefully I'll update everyone soon if it worked.  *fingers crossed*  Cheers friend!
Interesting.  Looks like I got lucky with both!  I did a little research... D1 (left) side board has red "C" sticker and says Tandon on the cast mech.  D2 (Happy - still needs cleaning to be truly :)) side board says "DSC". Doesn't say "Tandon" on the mech like the other, but does have the latch type door that I understand came later.  Cheers friend!
Oh yeah, those are both the later Tandon mechanisms, so you're pretty much guaranteed to have all the updated electronics inside!
That PSU is the Ingot, by the way. When it fails - as it almost inevitably will at some point - it’s likely to take your machine down with it through over-voltage. Replace it with one of the other much more reliable XL/XE PSUs.
It oils also be a passive component in the path to the SIO port that is broken. Rare but has happened.
It's the ingot PS that turns computers into boat anchors.... cut the cords off and use them on a newer safer power supply or buy a complete replacement...
On 9/23/2019 at 12:22 AM, Caterpiggle said:
That is strange, almost none of mine 800XL has that yellow wires. Strange enough ...
Two of my 800XLs have the factory installed wire, one does not.  The two with the wire are earlier, fully socketed Hong Kong made models and the one without it is a later, partially soldered Twain made board.
10 minutes ago, Caterpiggle said:
As for me, I need to open all Atari 800XL and see if it has add-on 1 or 2 wires , whatever the color is. Honesty, I do not remember any of mine 800XL has any wires ...
It’s normal.  Look away.    Atari played with multiple power feeds over there.  The changes are incorporated into later board revisions.  This was discussed in another thread. Possibly the prototype 130XE in an 800XL thread.
@DrVenkman @_The Doctor__  RE: Ingot.  Isn't that swell?  Oh well, guess I'm in the market for a new power supply.  Or, if I'm feeling ambitious enough, I do happen to have an XL style black power supply for the 520ST I may gut/convert.  Anything about my peripheral power supplies I should be concerned with?  Cheers friends!
These PSU's you show are all 9V AC units. They are all safe, simple transformers. If one is dead, it's most likely just a blown fuse inside. Replacing the fuse is usually all that's needed, but "getting in" requires a lot of effort to cut it open, and it won't "look pretty" afterwards. :) The one in the middle likely has a lower VA/amperage rating, maybe 15.3VA, since it was intended for a 400/800 computer with much lower demand than a disk drive. The disk drives mostly came with 31VA PSU's, except maybe the earliest 810's. Just don't use the lower rated PSU on a disk drive or you'll burn it out.
  • Haha 1
1 hour ago, Caterpiggle said:
all Atari 800XL
All!? I'm getting the impression I may be the only guy around here with one Atari computer.  But, it's the same one I worked summer jobs and saved birthday money to get, and have kept all these years so it's special to me. ;)  Cheers friend!
