Mehridian Sanders #1 Posted September 22 Just hooked up my newish TI-99/4a to an atx power supply. Bypassed the power board and fed it straight into the mainboard. I carefully placed the 12v, 5v, -5v, and the gnd cables as they were fed from the power board. I got power from the supply flowing and the av out went to a vizio TV av cable. Got no sound no pic. Pictures to follow shortly. Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #2 Posted September 22 Here we goSent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #3 Posted September 22 Better pics and connections: ◇Main pin 14 connected to Main pin 15◇Yellow wire from atx main pin 10 (12v)To TI mainboard ○●○○◇Red wire from Main pin 20 (5v) to TI mainboard ○○○●◇Black wire from Main pin 7 (GND) to TI mainboard ○○●○◇White wire from Main pin 18 (-5v) to TI mainboard ●○○○Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #4 Posted September 22 Sega genesis replacement adapter connections (while looking at the Male end)left to right. 1-NC2-Audio Out3-GND for Audio and Video4-NC5-Video OutSent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #5 Posted September 23 Apparently it helps when you plug the Audio out into the Audio instead if the video.. Sent from my SM-G955U using Tapatalk 3 Quote Share this post Link to post Share on other sites
wierd_w #6 Posted September 23 Excellent! This means a simple breakout board for a picoATX (20pin!! NO 24 pin!!) would work great with a Ti 99/A4. That would fit neatly inside the case. (PicoATX is smaller than the original power board.) 2 Quote Share this post Link to post Share on other sites
Mehridian Sanders #7 Posted September 23 It would work perfectly. I took your suggestion and found that old ATX 1 I had.Demo Link... don't judge too harshly. Playing 1 handed while filming.http://imgur.com/gallery/O2TrJOESent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
wierd_w #8 Posted September 23 External ATX is unelegant, but is a good showing that the signals will work fine. PicoATX is a mass produced consumer product, and a breakout board would be cheap to manufacture. Quote Share this post Link to post Share on other sites
tater1337 #9 Posted September 23 7 hours ago, wierd_w said: External ATX is unelegant, but is a good showing that the signals will work fine. PicoATX is a mass produced consumer product, and a breakout board would be cheap to manufacture. is there a thread here about Pico ATXconversion? 1 Quote Share this post Link to post Share on other sites
wierd_w #10 Posted September 23 No, I only recently mentioned it in the "PSU replacement?" Thread. I cited what pins in the 20 pin header you need, and what they go to. I am kinda surprised that the community designs custom VDUs, but there's no PicoATX breakout. It should be a drop in replacement with such a board. (Shrug) 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #11 Posted September 23 1 hour ago, tater1337 said: is there a thread here about Pico ATXconversion? It's surprisingly easy. I had my doubts at first but after taking a leap of faith ... works just fine. 8 hours ago, wierd_w said: External ATX is unelegant, but is a good showing that the signals will work fine. PicoATX is a mass produced consumer product, and a breakout board would be cheap to manufacture. I agree. It is. With the removal of the original power board, there is a LOT of space right up front. In truth, there is a lot of space in there, in general. 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #12 Posted September 23 Oh for anyone trying to get a replacement AV cable. I bought mine at a brick and mortar store. Sega Genesis Replacement cable. I think I paid $8 for it. Here is a link to a cheaper one : https://www.amazon.com/Mizar-Replacement-Sega-Genesis-Standard-Cable/dp/B002FY0CM0?th=1 Quote Share this post Link to post Share on other sites
GDMike #13 Posted September 24 I suppose the heat loss is min. Quote Share this post Link to post Share on other sites
wierd_w #14 Posted September 24 Upon further reading, I seem to find that pretty much every PicoATX (even the 20 pin versions) do not provide the -5v rail, because they consider it to be a legacy feature that nobody needs. That means that a breakout board for one will need one of these baked into it to provide the missing -5v rail. Should still be inexpensive though. Quote Share this post Link to post Share on other sites
+arcadeshopper #15 Posted September 24 or use this: https://www.digikey.com/product-detail/en/mean-well-usa-inc/GP25A13A-R1B/1866-1825-ND/7703336 Quote Share this post Link to post Share on other sites
