rietveld Posted September 26, 2019 Share Posted September 26, 2019 (edited) Hi. Can some one help me use TRLD from the command prompt. Not sure about the proper syntax Edited September 26, 2019 by rietveld Quote Link to comment Share on other sites More sharing options...
George Phillips Posted September 30, 2019 Share Posted September 30, 2019 Sure thing. What did you want to do? Quote Link to comment Share on other sites More sharing options...
rietveld Posted October 2, 2019 Author Share Posted October 2, 2019 i want to convert .BAS to .CAS and .CMD to .CAS I put the .BAS and .CMD files in the same directory as TRLD but it keeps saying that it cant find the files Quote Link to comment Share on other sites More sharing options...
George Phillips Posted October 2, 2019 Share Posted October 2, 2019 Hmmm, something like this should work: trld file.cmd out.cas I may need to see the exact command to see what's going wrong. Be warned that ".bas" to ".cas" conversion is not likely to do what you want. For details see: http://48k.ca/trld.html Quote Link to comment Share on other sites More sharing options...
rietveld Posted October 2, 2019 Author Share Posted October 2, 2019 54 minutes ago, George Phillips said: Hmmm, something like this should work: trld file.cmd out.cas I may need to see the exact command to see what's going wrong. Be warned that ".bas" to ".cas" conversion is not likely to do what you want. For details see: http://48k.ca/trld.html My Model 1 only has a tape drive to load games. I have an expansion interface but it's missing the 40pin cable so it's only being used as a monitor stand. I load my. CAS files from an old PC using the program 'PLAYCAS'. I was hoping to convert some. BAS into a format that can beloaded this way Quote Link to comment Share on other sites More sharing options...
