jedimatt42 #1 Posted September 27, 2019 I didn't have access / patience to use a 8 pin mini din jack for my 130XE's VBXE installation... so I went with DB9.. But I also didn't have the heart to cut into the case... So I printed this little snap in adapter: rgbplug.stl I printed it in this upright position (with support on in the slicer) so that the round lip can flex a little on its strong axis. Thread your DB9 leads through the hole, then insert the tongue/flat end in first, and snap the round end in. [email protected] 11 2 Quote Share this post Link to post Share on other sites
+slx #2 Posted September 28, 2019 Very neat solution! 1 Quote Share this post Link to post Share on other sites
Rybags #3 Posted September 28, 2019 Looks a good solution for those wanting not to hack their case. The main issue I see though is that you'd need to have the adaptor in place before soldering the wires to the monitor plug. Although if you did a modular install with removable wiring to the VBXE and motherboard (that's what I did) then you could get away with not needing to do that. 1 Quote Share this post Link to post Share on other sites
jedimatt42 #4 Posted September 28, 2019 This whole thing is _ if _ using a DB9 port. I soldered leads to the DB9 connector first. The leads all have individual Dupont connectors. You're going to need to solder to the DB9 before attaching directly to a cut up case anyway. That's just the nature of a DB9, generally. [email protected] Quote Share this post Link to post Share on other sites
