Buckaroo
Cheap DIY 2600 Junior Select & Reset Tactile Momentary Fix
Saw a couple of other threads about fixing these buttons but none that were fixed in the same way.
This is a cheap fix as the buttons are really cheap and it works great.
You can press the button anywhere and it clicks every time.
It's non invasive so this can be reversed easily if you want to put your Atari back to stock.
I had a ribbon on a Junior that was beyond repair and didn't have any spares ribbons to hand so came up with this fix as I already had the buttons.
You'll need:
  • 2x tactile momentary switches
  • 30cm double core wire (roughly)
  • Soldering iron
  • Glue gun (or glue if you don't have one)
Remove the console case, unplug the ribbon cable then use something blunt to pop the buttons out of the casing.
Peel the soft backing off of the switches as this will no longer be needed.
Slide the ribbon cable out (we won't need it anymore)
There's a recess on the bottom of the switch, here's where we will seat the button
Solder roughly 15-20cm of cable to each of the 2 buttons, I used network cable but anything will do.
 Feed the wires through the holes on the sides where the ribbon used to be.
Glue the buttons into place in the centre at the bottom of the switch (be careful not to get glue on the sides as it will make the button feel spongey)
Here are the points I soldered to. I used a PAL Junior so the layout may be different on NTSC.
The points are easy to trace as only 3 tracks come from the ribbon connector.
Solder the wires into place
Close you case back up and you're ready to go.
The buttons feel way more responsive than any Junior I've ever had (even the one I had in the eighties)
To find the same type of buttons I used search for "Mini Micro Momentary Tactile Push Button Switch"
  • Like 5
Hey, thanks for this awesome idea! I just tried it out and it works wonderfully, now I can finally say goodbye to that godforsaken mylar strip. One question, I haven't yet glued the switches or replaced the select/reset covers, is there anything I specifically need to do in order to make it so the buttons click down sufficiently on the new switches? Thanks!
No there's nothing specific you need to do. Just make sure that the holes are clear of glue on the left and right and where the tabs to hold the button are.
Looking back at the pictures I used way too much glue.
Edited by Buckaroo
Typo
Hi Buckaroo
I want to take a moment to share my experience and gratefulness with you:  I have a NTSC version of the 2600 Jr.  I had the same issue as described, hence my being here :)   While the electronics boards appear to be slightly different, the C24 and C25 are still labelled as such and the connections are the same basic pattern flow.  So, with no prior electronic experience, I set out on an adventure to follow your idea.  I am very excited to say that I now have a fully functioning Atari again!  Thank you so much for the advice!  I am so excited!
On a side note: I guess not all Mini Micro Momentary Tactile Push Button Switches are designed exactly the same.  I ordered mine from Amazon.  They are slightly too tall for the factory buttons to be put perfectly back into place (so if the factory (external) buttons are perfectly in place, then the tactile buttons are pressed down).  So for me, I just hot glued one side of the (external) plastic button to the machine and the other side is slightly raised.  It is a minor inconvenience so long as you don't have a child that will think it may be fun to pull up on the portion that is slightly raised.
Thank you again.  You are the best!
On 3/9/2020 at 2:48 PM, f.z.prime said:
Hi Buckaroo
Sorry for the late reply, I didn't get a notification for some reason.
I'm glad you got it working.
I'm not sure about the size of the microswitches but there might be one step you missed.
I forgot to add photos of removing the sponge pad underneath the button.
If you don't remove this then the button still works but doesn't fit very well.
Hope it makes sense from the attached picture.
