dely #1 Posted October 5, 2019 I wrote a program which let you configure device, mount and create new ATR images into SIO2SD. It is not as sophisticated as Pajero's configurator, but I think, that it is easier to manage - as it is not required to remember a lot of keyboard shortcuts. Of course there is a possibility to use SIO2SD Manipulator as "configurator", simply rename sio2sdman05.xex to sio2sd.xex and upload it into root directory of SD card. sio2sdman05.xex sio2sdman05.atr 8 1 Quote Share this post Link to post Share on other sites
dely #2 Posted February 1, 2020 It turned out that SIO2SD creates files with a length of 0 bytes that cannot be formatted under SDX when mounted - we get the information "Drive not respond". Therefore, after creating the new ATR SIOSD, the Manipulator 06a asks whether to initialize such a file, giving the possibility to select several of the most popular densities. Have fun! sio2sdman06a.atr sio2sdman06a.xex 3 1 Quote Share this post Link to post Share on other sites
dely #3 Posted February 24, 2020 New version 0.6c. - fixed: navigating to the directories if their name was not uppercased always failed. sio2sdman06c.atr sio2sdman06c.xex 3 Quote Share this post Link to post Share on other sites
dely #4 Posted February 27, 2020 (edited) Version 0.7 New option that allows you to save mappings for drives 1-8 and quickly restore them: Save drive mappings to file / Enter drive mappings from file. It is useful when we want to recreate the environment for work or play. Files with sets are saved in the current directory / disk indicated by 😧 sio2sdman07.atr sio2sdman07.xex Edited February 27, 2020 by dely 4 Quote Share this post Link to post Share on other sites
dely #5 Posted March 6, 2020 (edited) Version 0.8 release candidate. - any command that requires entering a data record (also in the device configuration) can be exited using the BREAK key, - files with disk mapping sets are saved on the SD card in the ATARI directory instead of D device as before, - the program checks during loading whether the file with information about mapped drives is in the correct format, therefore, unfortunately, you should delete previous mapping sets and generate them again. - fix for 80 column modes users (error discovered by @Peri Noid). EOL was missing in the list of mounted drives. sio2sdman08rc4.atr sio2sdman08rc4.xex Edited March 6, 2020 by dely Smiles removal 1 Quote Share this post Link to post Share on other sites
dely #6 Posted March 9, 2020 Version 0.8 final Some minor fixes according to above mentioned release candidate, mainly for 80-column mode. sio2sdman08.atr sio2sdman08.xex Quote Share this post Link to post Share on other sites
tschak909 #7 Posted March 10, 2020 sigh. WHY DOESN'T ANYONE EVER RELEASE SOURCE CODE?! -Thom 2 Quote Share this post Link to post Share on other sites
