Atari 800 Space Bar not working
Lardo Boffin
My keyboard is back from being repaired and the space works nicely now! The whole keyboard was taken apart, the space bar fixed and all resoldered together.
But another day another issue -  the H key is now starting to stick down. I popped the keycap off and looking at the plastic part that moves up and down both corners are cracked. I assume when pushed down it splays out and wedges in place? A couple of the other keys are starting to do the same now. Argh.
Any suggestions?!?!?
  • 2 months later...
  • 3 months later...
I have one missing pin on pad 57 but couldn't get continuity with an inserted wire no matter how much I fiddled with it.
There seems to be a decent amount of room under the space bar.  Maybe I could stick a new switch under there, rig some sort of plunger to the underside of the space bar, and run wires from the new switch to the original pads?  If this sounds feasible, any suggestions on what kind of switch would work and fit?
