blainelocklair Posted October 11, 2019 Share Posted October 11, 2019 Hello everyone! Do you have a PS2 Phat that isn't reading the discs anymore? The answer MIGHT be simpler and more economical than you think. Try cleaning the laser lens. Unless you've cleaned out your PS2 in recent years, it might need it anyway. I have several and they get filthy inside! If you need this done, I hope this set of instructions is helpful along the way. Enjoy! Full guide here: 1 Quote Link to comment Share on other sites More sharing options...
solidus Posted October 11, 2019 Share Posted October 11, 2019 I bought one used on LetGo a few months ago. It wouldnt read a single disc. I opened it, use compressed air on everything, then cleaned the lens with 91% Isopropyl Alcohol and a cotton swab. It hasnt failed to read a single disc since. I highly recommend doing this yourself. Its very easy and fixes read errors pretty often it seems Quote Link to comment Share on other sites More sharing options...
RARusk Posted October 11, 2019 Share Posted October 11, 2019 I'm surprised that no one has come up with an SD Card reader replacement like there is for the Saturn and DreamCast consoles. Quote Link to comment Share on other sites More sharing options...
derFunkenstein Posted October 11, 2019 Share Posted October 11, 2019 11 hours ago, RARusk said: I'm surprised that no one has come up with an SD Card reader replacement like there is for the Saturn and DreamCast consoles. With the proliferation of PS2 phat SATA adapters, there's no need. And since many games are in excess of 3-5 GB, you're not fitting much on even the largest SD cards. It's so cost effective to just use a hard drive, I can't imagine PS2 ODEs are even a viable product. Also if you have a slim PS2 (or have a Sony-original network adapter), you can play images from an SMB share over Ethernet with OPL, so you don't even need a hard drive. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted October 12, 2019 Share Posted October 12, 2019 Also adjusting the infamous white gear can make it work. Basically it controls the focus distance and it's loose enough that it will come uncalibrated with use. But it's such a pain to get in there that I stopped bothering. At least you can use a lens cleaner disc without taking everything apart. Quote Link to comment Share on other sites More sharing options...
