Al_Nafuur
PlusCart (an inexpensive DIY WiFi multicart)
I finally encased my PlusCart, but as I needed to check communications, I drilled a hole and filled it with hot silicone glue. This was the result:
  • Like 6
Hi, I am just about to order my PlusCart, just not sure about this: Before you buy a PlusCart or a DIY kit here, make sure that a ESP8266-01s WiFi module, with stock AT-Firmware, can connect to the internet via your router's WiFi.
How do I find it out?
a google search with your routers name/model and ESP8266 (and maybe some more keywords like: connect, AT-Firmware) will give you a hint if there are others having trouble to connect.
@JetSetIlly has allowed Flappy Bird to be added to the high score club.
Stephen Illingworth did a wonderful job making this game, and It's a lot of fun to play!
Somehow I missed the game last year, but fortunately the game was nominated for the Atari 2600: Best ≤ 4K Homebrew (Port) - 3rd Annual Atari Homebrew Awards
As always, PlusCart user/tester can find the PAL60, and NTSC versions in the PlusStore directory "Public ROMs\PlusROMs\High Score Club"
The NTSC version can be played online in javatari.js. The ROM-file can also be played with Gopher2600 (which is also done by @JetSetIlly).
The "PlusCart High Score Club" page for Flappy Bird:
https://highscore.firmaplus.de/?game_id=34
  • Thanks 2
New firmware version v1.0.0 in PlusStore released for all PlusCart users:
  • New menu structure
  • Keyboard improvement
  • PAL color fixes
  • Line spacing
  • "System Info" page in "Setup" menu
  • UA bankswitching
  • Many bug fixes and code tweaks
  • Like 6
  • Thanks 2
Working in Switzerland as well...
I like to update firmware just with a click.
No need to copy files from PC to sd cards!
Thanks!
Not related to the firmware, but with the "My Recently Played ROMs" virtual menu in the root: if I play A, then B, C, and D, the list will be D-C-B-A which it is OK, but if I play A again, it remains as the oldest one... it will never be in the top again. Is that on purpose? How long is that list? What will happen when my favourite game A arrive to the end of the list? Will it be forgotten forever or will it be on top again?
Yes it is seems a bit strange, but playing games from the "My Recently Played ROMs" folder dosn't count for the ranking in this folder. This folder is only a "virtual" folder, so if you play the games from B-Z from "real" folders and your game A not, it will be passed down this list and disappear.
That makes sense, but elements can be added/ranked to that virtual folder from another virtual folder: "Recently Added ROMs"... 🧐
New firmware version v1.1.0 in PlusStore and GIT released for all PlusCart users:
  • Fixed UP in menu to go to last item on previous page
  • New kernel to fix TIA glitch on some machines
  • Bug fix in keyboard menu
Thing of beauty.
  • Like 5
15 minutes ago, juansolo said:
Thing of beauty.
Just hard work done by @Andrew Davie that included the use of alcohol and a hairdryer:
Looking and working well. Thanks to all!
New Pluscart owner here!
I've received today my DIY kit and it's up and running now!
Very easy to assemble, the instructions are very detailed. I successfully connected to my WIFI using the joystick with the on-screen keyboard, and registered to the PlusStore.
I modified an original case as per instructions and also did the "hotglue led lens" as suggested by @vitoco a few posts above (thanks for the tip!)
Wonderful device! 👍
  • Like 4
Welcome to the fun!
Looks great! Congrats!
I also did this simple trick with my 7800. The stock power led is hidden in a hole, and it is almost impossible to know if the console is tuned on without standing up and looking into that hole. Now, it looks like this:
  • Like 4
