moulinaie
Printer and CF7
Hello,
When printing a program using
LIST "PIO"
on the CF7+, the last page is not ejected. The printer is still waiting to complete the 60 lines (more or less)... So I must send a FF (form feed) manually:
OPEN #1:"PIO"
print #1:chr$(12)
close #1
Is there a better way?
Guillaume.
Hi Guillaume,
Alas, I can't see in Basic how to send an ASCII CTRL-L, CHR$(12) or $0C command to the PIO with less number of instructions than the method above.
Maybe the solution is on the printer side? What is your model?
Edited by fabrice montupet
typo error
4 hours ago, moulinaie said:
Hello,
LIST "PIO"
OPEN #1:"PIO"
print #1:chr$(12)
close #1
Guillaume.
Does your editor allow you to embedded the control character (CTRL L) in the file at the end of the text?
Oops.  I think you are using BASIC's line editor.
Edited by TheBF
Challenge accepted...
Hmm, entering ctrl-L into a basic line with quotes gets you an >8C in the listing, not an >0C.
20 PRINT "<ctrl-L>"
LIST
... 22 8C 22
REM ctrl-L becomes tokens 9A 8C or REM  FOR.
CALL POKEV(14272,12)
don't ask me how I found that address..I just looked for the byte with >8C in it.
Now that puts a real 0C in the listing!
SO.. its just barely possible to put a form feed char in your BASIC program, assuming you have E/A and some way to find the darn byte in VDP.
18 hours ago, fabrice montupet said:
Hi Guillaume,
It is a HP Laserjet 2200DN.
Ah ah !!
Great!
Guillaume.
On a LJ2200, just pressing the round "Go" button should print the data stored in its buffer.
I tried.... But it doesn't work.
I found the manual and it says the same as you do.... Strange !
Guillaume.
Laser printers (and most modern inkjets) are page printers.  While they will not print until an entire page has been received, like the old line printers an incomplete printed page is not ejected from the printer  unless it receives a form feed control character or the FF button is pressed.
Usually pressing the GO button will do the same (it has on my HPs.)  If that does not work, well, I have tried nothing and I am all out of ideas.
Guillaume.
Have you tried to do a long "Go" button push?
Yes!
It prints a standard page with a beautiful HP logo on both sides.
Guillaume.
