Sign in to follow this
moulinaie
Problem with Direct From Disk and Classic99 [SOLVED]
Hello,
I have a demo program called TINTIN that displays a little animation in the center of the screen until you press a key.
The program reads a data file, loads every frame as new char definitions, at end of file, it goes back to the beginning and again and again.
On real hardware, no problem as you can see on this animation (TINTIN and his dog are constantly running and the LED of the CF7+ is blinking, showing that data is read.
TINTIN and MILOU running
But with Classic99, you just see the first step of TINTIN, then nothing moves. But the program is not frozen as pressing a key returns correctly to XBasic.
What is the problem...?
I have attached a ZIP file with the sources and the DSK1 folder for CLASSIC99.
OLD DSK1.TINTIN
RUN
(then press a key to stop)
Guillaume.
seven_mlc.zip
Are you running the latest Classic99?  Also, Classic99 has a debugger.  If you open the debug window and run your program, there are file errors.  There is something going on trying to re-read the VIDEO file.  This is where things seem to go badly:
DSR opcode >2 on PAB >1CC7, filename DSK1.VIDEO
Seek past end of file VIDEO
Failed reading max 240 bytes DSK1.VIDEO on drive type FIAD
Setting file error 5 on file buffer 18
Releasing file buffer 18
Can't read from VIDEO as file is not opened for read.
Full log:
DSR opcode >5 on PAB >096E, filename DSK1.TINTIN
Loading to VDP >0971 DSK1.TINTIN on drive type FIAD
Detected .\DSK1\TINTIN as a TIFILES file
loading 0x857 bytes
DSR opcode >0 on PAB >368D, filename DSK1.NEWFLO
Opening DSK1.NEWFLO on drive type FIAD
PAB requested file type is DF0
Allocating file buffer 0
Detected .\DSK1\NEWFLO as a V9T9 file
.\DSK1\NEWFLO read 19 records
Restore set record number to 0
DSR opcode >2 on PAB >368D, filename DSK1.NEWFLO
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 0) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 1) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 2) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 3) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 4) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 5) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 6) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 7) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 8) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 9) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 10) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 11) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 12) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 13) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 14) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 15) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 16) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 17) to >3694
Read 0x50 bytes drive 1 file NEWFLO (Fixed record 18) to >3694
DSR opcode >1 on PAB >368D, filename DSK1.NEWFLO
Closing DSK1.NEWFLO on drive type FIAD
DSR opcode >5 on PAB >366B, filename DSK1.MLC1
Loading to VDP >1B4D DSK1.MLC1 on drive type FIAD
Detected .\DSK1\MLC1 as a V9T9 file
loading 0x1B10 bytes
Loading to VDP >1B4D DSK1.MLC2 on drive type FIAD
Detected .\DSK1\MLC2 as a V9T9 file
loading 0x492 bytes
This is where the scrolling text is happening, followed by
repeating errors on the VIDEO file access.
DSR opcode >0 on PAB >1CC7, filename DSK1.VIDEO
Opening DSK1.VIDEO on drive type FIAD
PAB requested file type is IF240
Detected .\DSK1\VIDEO as a V9T9 file
.\DSK1\VIDEO read 5 records
DSR opcode >4 on PAB >1CC7, filename DSK1.VIDEO
Restoring record 0 DSK1.VIDEO on drive type FIAD
Read 0xF0 bytes drive 1 file VIDEO (Fixed record 0) to >0600
Read 0xF0 bytes drive 1 file VIDEO (Fixed record 1) to >0600
Read 0xF0 bytes drive 1 file VIDEO (Fixed record 2) to >0600
Read 0xF0 bytes drive 1 file VIDEO (Fixed record 3) to >0600
Read 0xF0 bytes drive 1 file VIDEO (Fixed record 4) to >0600
Restoring record 5 DSK1.VIDEO on drive type FIAD
Setting file error 3 on file buffer 2680
Setting file error 3 on file buffer 2681
Setting file error 3 on file buffer 2682
Setting file error 3 on file buffer 2683
Can't restore VIDEO as file is not opened for read.
Setting file error 3 on file buffer 2684
Setting file error 3 on file buffer 2685
Thanks for posting a log. My first suspicion is in the above section - it looks like the restore didn't clear the end of file flag. I wouldn't expect a read after restore to record 0 to cause read past EOF. I'll check that in the code. (Everything after that is just the source program not catching the error...)
Although it's not clear to me why a restore of record 5 is going to 0, I need to see if that's a debug bug. ;)
Is that a correct understanding of the code flow? You read 5 records and then restore the file pointer back to 0? And that runs well enough from a real floppy disk?
Edited by Tursi
Full log:
Thanks a lot Matthew !
I didn't think of looking at the LOG in the debugger...!
Well, we'are approaching the solution.
Guillaume.
Hi Tursi,
The file is opened with FLAGS sequential, internal, fixed, input and lenght of 240 bytes.
This is correct : the program reads five records of 240 bytes each and then restore the postition to the beginning of the file. And so on.
It runs well on a CF7+ (I do not have a real floppy unit).
Guillaume.
Yeah, that's what I was curious about. The seeks would probably kill it. ;)
Anyway, yeah. The problem was my implementation of RESTORE didn't reset the record number in your PAB, the real one does. One line fix in Classic99. (My concern about the 5->0 was just the way the debug comes out, so I clarified that).
I'll post an updated version in a few minutes.
Edited by Tursi
I tested it, now it works ! (what a reactivity!)
Thanks a lot,
Guillaume.
