mimo #1 Posted October 26, 2019 Is there an idiots guide to fitting a UAV board to a 1200xl? I looked in the UAV threads but the info is pretty sketchy imo Quote Share this post Link to post Share on other sites
+DrVenkman #2 Posted October 26, 2019 (DELETED) Quote Share this post Link to post Share on other sites
mimo #3 Posted October 26, 2019 Thanks @DrVenkman But thats for Ultimate 1meg not UAV isn't it? Quote Share this post Link to post Share on other sites
+DrVenkman #4 Posted October 26, 2019 8 minutes ago, mimo said: Thanks @DrVenkman But thats for Ultimate 1meg not UAV isn't it? Jeez, yes. I’m an idiot. 😛 (ALSO: I need more coffee ...). I’m going to delete my post to avoid cluttering the forum with confusing info. I’ve got a UAV in two of my 1200XL’s. I’ve got pics of that around somewhere. I’ll try to post them later. Quote Share this post Link to post Share on other sites
mimo #5 Posted October 26, 2019 @DrVenkman Thanks again, that would be most appreciated, no rush though I doubt I'll get any Atari time this weekend. And I'm glad it wasn't me going mad for a change 😁 Quote Share this post Link to post Share on other sites
mimo #7 Posted October 28, 2019 Thanks @cwc I have read that thread several times and I'm not fully confident, it's not detailed enough for me with regard to the 1200xl Quote Share this post Link to post Share on other sites
+DrVenkman #8 Posted October 28, 2019 1 hour ago, mimo said: Thanks @cwc I have read that thread several times and I'm not fully confident, it's not detailed enough for me with regard to the 1200xl I never did find my photos for you. What specifically isn’t detailed enough? First you remove the 4050 hex buffer chip, install the UAV into the existing socket. You then need to solder one wire from the leg of a resistor to pick up the Color signal and run that wire to the UAV terminal block. For the UAV outputs, you cut or desolder two ferrite bead inductors and lift them to isolate the DIN jack from the existing connections. You solder wires for the Composite and Luma lines from the UAV and connect those to the UAV terminal block. For the Chroma output you connect a wire to the UAV terminal block and run it to pin 5 (IIRC) of the DIN jack. You can solder to the back of the DIN or run the wire under the board and solder to the pin where it’s soldered through the via. Quote Share this post Link to post Share on other sites
mimo #9 Posted October 28, 2019 42 minutes ago, DrVenkman said: I never did find my photos for you. What specifically isn’t detailed enough? First you remove the 4050 hex buffer chip, install the UAV into the existing socket. You then need to solder one wire from the leg of a resistor to pick up the Color signal and run that wire to the UAV terminal block. For the UAV outputs, you cut or desolder two ferrite bead inductors and lift them to isolate the DIN jack from the existing connections. You solder wires for the Composite and Luma lines from the UAV and connect those to the UAV terminal block. For the Chroma output you connect a wire to the UAV terminal block and run it to pin 5 (IIRC) of the DIN jack. You can solder to the back of the DIN or run the wire under the board and solder to the pin where it’s soldered through the via. I guess I'm just a bit over cautious about doing this one, 1200XL's aren't easy to find in the UK. It's which end of the resistors/inductors to cut more than anything Quote Share this post Link to post Share on other sites
+DrVenkman #10 Posted October 28, 2019 57 minutes ago, mimo said: It's which end of the resistors/inductors to cut more than anything That’s pretty much up to you and whether you want to run the UAV outputs through them or not. If you do, lift the bottom legs (furthest from the DIN jack) and solder your outputs the lifted ends. The signal will travel through the inductors then out to the DIN. If you don’t care, lift the end closest to the DIN and solder the wires to the vacated vias. 1 Quote Share this post Link to post Share on other sites
mimo #11 Posted October 28, 2019 Thanks for your help. that makes sense now Quote Share this post Link to post Share on other sites
cwc #12 Posted October 29, 2019 (edited) Some pictures of my 1200XL. (1) Remove 4050 IC (U27) from socket and insert UAV. (2) Lift the back pins of L1 + L3, and run wires from to the vacated pads to UAV "Luma" and UAV "Comp Video" respectively - See Pic 1 (lower part) (3) Lift one side of both C103 and C104 - See Pic 1 (upper part) (4) Run wires from Colour and GND points - See Pic 2 (Colour is the lower point, GND is the upper point) to UAV "Color In" and "GND" respectively (5) Run a wire from the empty pin on the video DIN connector (J2-5) on the back of the board to UAV "Chroma". Edited October 29, 2019 by cwc 3 Quote Share this post Link to post Share on other sites
mimo #13 Posted October 29, 2019 @cwc that is just what I needed. Thank you so much for taking the time to do this. I love this forum Quote Share this post Link to post Share on other sites
Xebec #14 Posted May 22, 2020 On 10/28/2019 at 8:07 PM, cwc said: Some pictures of my 1200XL. (5) Run a wire from the empty pin on the video DIN connector (J2-5) on the back of the board to UAV "Chroma". Hi! Another Idiot here -- for Step 5 -- "The empty pin on the video DIN connector" - I can't tell which are empty and which are full?? .. I *think* Chroma is the end pin from the right? (the one on the right sticking out the most, or just right of the center pin) Quote Share this post Link to post Share on other sites
+skr #15 Posted May 22, 2020 Frome the (German) ATARI Profibuch (revised mainly by GoodbyteXL) which is free for download there: http://www.abbuc.de/mitgliedschaft/downloads/viewdownload/5-public-downloads/1635-das-atari-profibuch Quote Share this post Link to post Share on other sites
Xebec #16 Posted May 22, 2020 5 minutes ago, skr said: Frome the (German) ATARI Profibuch (revised mainly by GoodbyteXL) which is free for download there: http://www.abbuc.de/mitgliedschaft/downloads/viewdownload/5-public-downloads/1635-das-atari-profibuch Thanks - That's actually what I was looking at -- just humor me for a double check -- to connect from the inside of the Atari, I'm soldering to the 4th pin from left / 2nd pin from right? Quote Share this post Link to post Share on other sites
+skr #17 Posted May 22, 2020 5 minutes ago, Xebec said: Thanks - That's actually what I was looking at -- just humor me for a double check -- to connect from the inside of the Atari, I'm soldering to the 4th pin from left / 2nd pin from right? Yes, that is correct. 1 Quote Share this post Link to post Share on other sites
+DrVenkman #18 Posted May 22, 2020 If you want an easier place to solder to, run your chroma line under the board and solder to the empty pin: 2 1 Quote Share this post Link to post Share on other sites
alortegac #19 Posted June 5, 2020 (edited) what do you do with the to RF shield? thanks! Edited June 5, 2020 by alortegac Quote Share this post Link to post Share on other sites
mimo #20 Posted June 5, 2020 Just now, alortegac said: what do you do with the to RF shield? thanks! Send it for recycling 😁 Quote Share this post Link to post Share on other sites
alortegac #21 Posted June 5, 2020 Freaking can opener style......:) Quote Share this post Link to post Share on other sites
+DrVenkman #22 Posted June 5, 2020 I don’t bother with RF shields on any of my Atari machines with a UAV. Quote Share this post Link to post Share on other sites
alortegac #23 Posted June 5, 2020 I was in the mood to destroy something.......)... thanks for this guide! it is really good step by step.....appreciated! Quote Share this post Link to post Share on other sites
gollumer #24 Posted January 25 (edited) Huge props to @cwc and others in this thread. I was able to use the instructions and very helpful photos to successfully install a UAV in my 1200XL over the weekend. I took some photos along the way, and have annotated them. (More pics can only help, right?) Edited January 25 by gollumer Incorrect photo 6 Quote Share this post Link to post Share on other sites
