root42
Mappy cartridge broken...?
Mappy is my favorite game on the 2600. Today I noticed that the left difficulty switch doesn't work anymore. It should toggle the placement of the loot. The loot is now always randomized, no matter what. The switch still works — for example in Scramble I can toggle the burst mode. I mostly just swap between Mappy and Scramble these days, sometimes with the occasional Harmony or original game (Missile Command) thrown in. I unplug the Atari after every session on the wall socket. Any ideas what might be wrong with the cart?
Update: now it’s working again. Maybe I should double check those switches. Might be they are a bit corroded? Will get some contact cleaner spray from a friend…
Good idea. Any hints for the cartridge port on how to best clean it? Contact cleaner spray? Isopropyl on something? It’s probably hard to get to the contacts.
Well lotsa ways to clean the slot. I cut down a credit card to size and use it to support a bit of paper wrapped/looped around the edge in a "U" shape. And I always prefer contact cleaner as it is also a lubricant that prolongs contact life.
Alcohol/water can cut through some grime, too. It can be used as a pre-cleaner. But it doesn't have any protective/lube capability. So you want to finish up with real contact cleaner. Like Deoxit.
Lazy, easiest way that's quite effective in a pinch... rubbing alcohol or contact cleaner like DeOxit on a Q-Tip, apply to the edge connector of the cartridge, then insert the cartridge wet into the system and insert/remove a few times. Wipe off excess grime on the cartridge afterwards.
Pretty much what I do, only I use an old white t-shirt wrapped around the CC section I have cut up. I have two pieces. Once for the 2600 and 7800 main central portion and a smaller one for the 7800s side PCB contacts. I first use alcohol, and then follow up with a spritz of de-ox-id (generic version), into the slot and use a different part of the t-shirt to clean and finish. Best part is that a t-shirt can be used many times in different spots and then tossed in the wash later for cleaning and reuse.
