BeeryMiller
Eprom for Geneve SCSI Booting
Tony Knerr released a SCSI Boot Eprom years ago.  I do not see the eprom image on WHT and I have not found it on YahooGroups.
Does anyone have the image I can burn?  I looked at Arcadeshopper thinking I may be able to order an eprom, however, all the eproms for ordering have seemed to disappeared, or I am not looking in the right location.
Preferably, if someone has the image or can point me to where it is, it would be appreciated as I can burn my own eproms.
Beery
Beery
You aren't looking in the right location
https://www.arcadeshopper.com/wp/?page_id=11#!/Hummingbird-Eeprom/p/33994194/category=12497082
Also unless it's the same as the v1 eprom it's not in the list.
Sent from my LM-G820 using Tapatalk
OK, I have that Eprom that I ordered long time ago from you.  Your response gave me a clue, I need to do some file renaming and find the appropriate LOAD/SYS utility.
Need to go and read some docs...……..
Once you get it booting with Tony's version of SCSI/SYS I'll email you an updated file that allows you to turn CRC on/off; it also employs a table-driven CRC routine I added to the Geneve OS CRC check utility. Thus bootup is a but faster as Shift838 can attest.  (I thought I posted v2.5 in the forums but the search engine isn't finding it).
Anyway, my platter and SCSI2SD device that contain the IDE/SYS and SCSI/SYS code were partially corrupted by MDOS 7.00 (presumably) fortunately I have copies on floppy for when I can put my own system back together. I also made a dump of the image to PC but it isn't the final rev.
OK, made quite a bit of progress.  The SCSI system is booting from the V1.00 eprom.  Updated files when you get a chance is appreciated whenever you get a chance.
Beery
Excellent work.
Hmm, now that I think about it the updated SCIS/SYS executable might be on the Heatwave BBS platter that I had to retire (and the reason file transfers are offline).   If Shift838 has a copy and wants to share here that's fine. I'll scout around this week as time permits.
10 minutes ago, InsaneMultitasker said:
Excellent work.
No hurry Tim as I know you are busy.  Today is my day off this week, so doing some posting here documenting things, etc.
