GunNac Posted November 6, 2019 Share Posted November 6, 2019 This is the Sears Arcade System II controller (American version of the Japanese exclusive 2800). Does anyone have any experience trying to fix these controllers? In my case, everything works fine, except that you cannot turn left. All other directional buttons work as do the two triggers. I took it apart and there doesn't appear to be any difference (appearance-wise) with the button on the board. It also feels exactly the same as when depressing other buttons on the board. The wire connecting to the board doesn't seem loose and is indistinguishable from the other wire connection on the working buttons. I'm pretty confused at this point as generally, you open up a piece of electronics and it is very visibly clear what the issue is. Not so, in this case. Also, I have a working controller, so no, it isn't the system itself. The working controller works in all ports. Any ideas? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 6, 2019 Share Posted November 6, 2019 Sounds like it could be a bad wire in the cable. Mitch Quote Link to comment Share on other sites More sharing options...
GunNac Posted November 6, 2019 Author Share Posted November 6, 2019 14 hours ago, Mitch said: Sounds like it could be a bad wire in the cable. Mitch OK, that makes sense but is there any recourse for that kind of thing? I feel like if that were the issue, the controllers junk at that point. Also, thanks for your reply. Quote Link to comment Share on other sites More sharing options...
Lord Thag Posted November 6, 2019 Share Posted November 6, 2019 22 minutes ago, GunNac said: OK, that makes sense but is there any recourse for that kind of thing? I feel like if that were the issue, the controllers junk at that point. Also, thanks for your reply. They're not junk. You can use the cord from another stick or wire your own, just make sure you get the right wires to the right pins. My daily driver is a 2800/ SVA II, and you can fix anything on those controllers. Quote Link to comment Share on other sites More sharing options...
Jason_Atari Posted November 7, 2019 Share Posted November 7, 2019 I've found that most of the time joystick problems are due to the cable. Usually its at the plug end where the cable meets the plug. Quote Link to comment Share on other sites More sharing options...
RamrodHare Posted November 8, 2019 Share Posted November 8, 2019 As mentioned, it's probably the cable. Simple fix, just replace the cable. I never toss any controller that can be repaired, especially one that only needs a cable. Quote Link to comment Share on other sites More sharing options...
