tschak909 #101 Posted November 19, 2019 Here is the WIFISCAN.BAS source: 100 REM WIFI SCAN TEST PROGRAM #11 101 DIM SCAN$(360) 110 GOSUB 1000:REM COPY CHARSET 120 ? CHR$(125) 130 ? "Scanning Network..." 140 DCB=768 150 POKE DCB,112:REM DEVICE $70 160 POKE DCB+1,1:REM DUNIT 1 170 POKE DCB+2,35:REM DCOMND = SCAN 180 POKE DCB+3,64:REM READ 190 ADDR=24576 200 ADDRH=INT(ADDR/256) 210 ADDRL=ADDR-(ADDRH*256) 220 POKE DCB+4,ADDRL:REM BUFFER LO 230 POKE DCB+5,ADDRH:REM BUFFER HI 240 POKE DCB+6,31:REM TIMEOUT 250 POKE DCB+8,74:REM 330 BYTES 260 POKE DCB+9,1 270 POKE DCB+10,0:REM AUX1=0 280 POKE DCB+11,0:REM AUX2=0 290 X=USR(ADR("h Yd`")) 300 FOR X=0 TO 9 310 IF PEEK((X*32)+ADDR)=0 THEN GOTO 400 320 ? X;": "; 330 FOR Y=0 TO 31 331 IF PEEK(X*32+Y+ADDR)=0 THEN GOTO 350 340 PRINT CHR$(PEEK(X*32+Y+ADDR)); 350 NEXT Y 360 RSSI=PEEK(ADDR+320+X):POSITION 32,X+ 2 370 IF RSSI>200 THEN ? "???":GOTO 400 380 IF RSSI>180 THEN ? "?? ":GOTO 400 390 ? "? " 400 NEXT X 410 END 1000 MEMTOP=PEEK(106) 1010 GRTOP=MEMTOP-4 1020 POKE 106,GRTOP 1030 GRAPHICS 0:REM RESET 1040 CHROM=PEEK(756)*256 1050 POKE 756,GRTOP 1060 CHRAM=GRTOP*256 1070 PRINT "PLEASE WAIT..." 1080 FOR N=0 TO 1023 1090 POKE CHRAM+N,PEEK(CHROM+N) 1100 NEXT N 1110 REM ADD BARS TO CHARSET. 1111 RESTORE 1200 1120 FOR N=0 TO 23 1130 READ B 1140 POKE CHRAM+520+N,B 1150 NEXT N 1160 RETURN 1200 DATA 0,0,0,0,0,0,3,51 1210 DATA 0,0,3,3,51,51,51,51 1220 DATA 48,48,48,48,48,48,48,48 C version coming shortly. -Thom Share this post Link to post Share on other sites
tschak909 #102 Posted November 19, 2019 To any Atari programming gods: One aspect of #FujiNet that needs to be dealt with, any DLI timing will go askew when SIO is being used. How can we best deal with that? Share this post Link to post Share on other sites
tschak909 #103 Posted November 19, 2019 (edited) Can anyone see something odd happening here? this is only happening with the C programs that I am writing, it seems that when calling SIOV after a certain point, the SIO output routine gets stuck waiting for something which never happens: /** * WIFISCAN - show WiFi networks returned * from a SIO WIFI SCAN call */ #include <atari.h> #include <6502.h> #include <string.h> #include <peekpoke.h> #define SetChar(x,y,a) video_ptr[(x)+(y)*40]=(a); #define GetChar(x,y) video_ptr[(x)+(y)*40] #define GRAPHICS_0_SCREEN_SIZE (40*25) #define DISPLAY_LIST 0x0600 #define DISPLAY_MEMORY 0x3C00 union { struct { char ssid[10][32]; char rssi[10]; }; unsigned char rawData[330]; } ssidInfo; void dlist= { DL_BLK8, DL_BLK8, DL_BLK8, DL_LMS(DL_CHR20x8x2), DISPLAY_MEMORY, DL_CHR20x8x2, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR40x8x1, DL_CHR20x8x2, DL_CHR20x8x2, DL_JVB, 0x600 }; static unsigned char* video_ptr; static unsigned char* dlist_ptr; static unsigned short screen_memory; const char* title=" WIFI NETWORKS: "; const char* scan="SCANNING NETWORKS..."; void clear_screen() { memset(video_ptr,0,GRAPHICS_0_SCREEN_SIZE); } /** * Print ATASCII string to display memory */ void print_string(unsigned char x,unsigned char y,char *s) { unsigned char inverse; char offset; do { inverse=*s&0x80; *s-=inverse; if (*s < 32) { offset=64; } else if (*s<96) { offset=-32; } else { offset=0; } *s+=inverse; SetChar(x++,y,*s+offset); ++s; } while(*s!=0); } /** * Setup screen */ void setup() { OS.coldst=1; // Reset coldstart flag to force coldstart on RESET. OS.sdmctl=0x00; // Turn off DMA memcpy((void *)DISPLAY_LIST,&dlist,sizeof(dlist)); // copy display list to $0600 OS.sdlst=(void *)DISPLAY_LIST; // and use it. dlist_ptr=(unsigned char *)OS.sdlst; // Set up the vars for the screen output macros screen_memory=PEEKW(560)+4; video_ptr=(unsigned char*)(PEEKW(screen_memory)); // TODO: come back here and set some colors // OS.color0=0x12; // OS.color1=0x34; // OS.color2=0x56; // OS.color3=0x78; OS.sdmctl=0x22; // Turn on DMA, normal playfield, no P/M. clear_screen(); print_string(0,0,(char *)title); print_string(0,21,(char *)scan); } /** * Do the WiFi Scan */ unsigned char sio_wifi_scan(void) { struct regs r; OS.dcb.ddevic=0x70; // Network Device OS.dcb.dunit=1; // OS.dcb.dcomnd='#'; // Network Scan OS.dcb.dstats=0x40; // Read from peripheral OS.dcb.dbuf=&ssidInfo.rawData; // The scan results buffer. OS.dcb.dtimlo=0x20; // Timeout OS.dcb.dbyt=330; // 330 byte payload OS.dcb.daux=0; // aux1/aux2 = 0 // Call SIOV r.pc=0xE459; _sys(&r); return OS.dcb.dstats; // Return command status } /** * Print the ssid at index i */ void print_ssid(unsigned char i) { char out[3]="0:"; out[0]=i+0x30; // Turn number into printable number. print_string(1,i+3,out); print_string(4,i+3,(char *)ssidInfo.ssid); } /** * Print the RSSI at index i */ void print_rssi(unsigned char i) { char out[4]={0x20,0x20,0x20}; if (ssidInfo.rssi[i]>200) { out[0]='*'; } else if (ssidInfo.rssi[i]>160) { out[0]='*'; out[1]='*'; } else if (ssidInfo.rssi[i]>140) { out[0]='*'; out[1]='*'; out[2]='*'; } print_string(35,i+3,out); } /** * Print the available networks */ void print_networks(void) { unsigned char i; for (i=0;i<10;i++) { if (ssidInfo.ssid[i][0]!=0x00) // Only print if not empty. { print_ssid(i); print_rssi(i); } } } /** * Print error */ void print_error(unsigned char s) { if (s==138) { print_string(0,21," NO FUJINET FOUND "); } else if (s==139) { print_string(0,21," FUJINET NAK! "); } } /** * Sit and wait */ void sit_and_spin(void) { for (;;) { } } /** * main program */ void main(void) { unsigned char s; // status setup(); s=sio_wifi_scan(); if (s==1) { print_networks(); } else { print_error(s); } sit_and_spin(); } Binary is also attached, am I doing something unbelievably stupid to cause this? @sanny @phaeron -Thom wifiscan.com Edited November 19, 2019 by tschak909 whoops :) Share this post Link to post Share on other sites
flashjazzcat #104 Posted November 19, 2019 19 minutes ago, tschak909 said: Binary is also attached Where? Share this post Link to post Share on other sites
tschak909 #105 Posted November 19, 2019 3 minutes ago, flashjazzcat said: Where? oops! I forgot. I've attached it to the post. -Thom Share this post Link to post Share on other sites
flashjazzcat #106 Posted November 19, 2019 (edited) 9 minutes ago, tschak909 said: I've attached it to the post OK: I just ran it in Altirra and the interrupt disable flag is set by a PLP at $23D3. This causes the VBI to get stuck in a loop waiting for XMTDON ($3A) to be non-zero. Note sure what the code is doing but here it is: Just setting a breakpoint and forcibly clearing the I flag in the debugger allowed the program to execute correctly. Edited November 19, 2019 by flashjazzcat typo 1 Share this post Link to post Share on other sites
tschak909 #107 Posted November 19, 2019 That seems to me to be a bug in cc65, I'll work with them to try and fix it. Thanks! -Thom Share this post Link to post Share on other sites
tschak909 #108 Posted November 19, 2019 ok, so changing the _sys() call to just be: asm("CLI; JSR $E459"); was sufficient, to work through this now.. I will file a ticket with the CC65 ppls Thanks Jon! 1 Share this post Link to post Share on other sites
tschak909 #109 Posted November 19, 2019 Bug to CC65 posted here: https://github.com/cc65/cc65/issues/983 -Thom Share this post Link to post Share on other sites
flashjazzcat #110 Posted November 19, 2019 (edited) I'm not sure if I'm reading the CC65 _sys.s source right, but it seems to imply that it expects the user to set regs.flags. Since your struct is allocated off the stack, I assume the contents of the other struct fields are uninitialised. Edited November 19, 2019 by flashjazzcat Share this post Link to post Share on other sites
tschak909 #111 Posted November 19, 2019 That would make sense. For now, I will do the inline asm to do the JSR, going forward, espeically since adding _sys() is very generalized, and what I need can be done with fewer bytes. Share this post Link to post Share on other sites
flashjazzcat #112 Posted November 19, 2019 Yeah - I figure they'll just tell you to do this: r.flags=0; 1 Share this post Link to post Share on other sites
AtariGeezer #113 Posted November 20, 2019 Another bug: in setup() pinMode(PIN_INT, INPUT); pinMode(PIN_PROC, INPUT); should be: pinMode(PIN_INT, OUTPUT); // these are "inputs" on the Atari side... pinMode(PIN_PROC, OUTPUT); Share this post Link to post Share on other sites
tschak909 #114 Posted November 20, 2019 Just now, AtariGeezer said: Another bug: in setup() pinMode(PIN_INT, INPUT); pinMode(PIN_PROC, INPUT); should be: pinMode(PIN_INT, OUTPUT); // these are "inputs" on the Atari side... pinMode(PIN_PROC, OUTPUT); Ah, good catch, thanks -Thom Share this post Link to post Share on other sites
tschak909 #115 Posted November 20, 2019 As a contrast, here is the same program written in C, and spiced up slightly. You can see it is much faster. The protocol has also been amended so that it works better (sends one SSID at a time, with an indication if there is more). 5 Share this post Link to post Share on other sites
tschak909 #116 Posted November 20, 2019 With the Name change, this thread has been moved to here: I formally ask moderators to lock this thread. Thank you. -Thom Share this post Link to post Share on other sites
